R33 gtst
TRACK - WSID
ET : 12.175
MPH: 118.14
60' : 1.881
FUEL: optimax and ooctane booster
TYRES: 235/60/15 MT drag radials
very very hot, viscous fan cut in constanly. was 39 degres at 5pm
Edited by OFENSV
R34 GTT
Auto
ET 13.582
60' 2.172
MPH 103.93
Fuel optimax probably
Tyres Nittos which were slipping because I couldn't warm them up because I am hopeless at doing burnouts.
Boost about 13psi
Power 228rwkw
Pipe from AFM to turbo was sucking closed above 6000rpm.
  • 1 month later...
  • 4 weeks later...
