Sau Timeslip Registry
BU5TER
  • 1 month later...
  • 3 weeks later...
  • 4 weeks later...
ET:12.467
MPH:103 (have run as high as 115 car lost power at 1000ft it was low on fuel)
60':1.898
Tyres: kumho SPT 225/50/16
Nitrous:no
Fuel: VP 103
Nissan:R32 GTS-T rb20 stock long block
timeslip http://www.dragtimes.com/Nissan-Skyline-Timeslip-9513.html
t3/t4 60 trim 18psi
550cc injectors
retuned ecu
z32 maf
FMIC 9x24x2.5
safcII
warblor 255lph pump
full 3" exzost with side pipe video ---->
more things comming this year
Edited by TheLast
  • 3 weeks later...
NISSAN SKYLINE R33 GTS25t Series 2
POWER: Approx 220rwkw
60ft: 2.062
ET: 12.964
MPH: 111.86
Shell V-Power Racing 100 Octane
TYRES: Stock GTR32 rims with 225/50/r16 Toyo T1R's running 25psi <consistent 2.1-2.2 60fts>
  • 4 weeks later...
32 GTR
WSID 28 Mar 07
60' 1.792
ET 12.430
MPH 106.35
K/mh 171.16
NOS:no
BP ultimate, 255/35R18s yoko GP's back, Hankook ventusports, front
Slowest was 23.148 @45.69mph, NA (intercooler hose blew off)
    • A31 is pretty much the same thing without HiAIDS I mean CAS, no improvement lol. Not to late to send it.
    • Thanks for all the replies! I also wanted to ask if wheels that were fitted on Ford Falcons would fit the 350GTs as well? In the area I'm at there aren't that many options for secondhand wheels and new ones here are way out of my budget. From what I've seen, most of the wheels that are available that were fitted on Ford Falcons have an offset of +33 to +36, with a centre bore of 70.5mm whereas the stock 350GT's ones are 66mm, can't seem to find any hubcentric rings that fit that difference though.
    • 215/45/18 tyres are probably a little on the low side compared to the factory tyre, it should be closer to a 245/45/19, which will get you about an extra 11mm of height, and should make you speedo read a bit closer to reality. 245/45/19s will be a bit too far the other way and you risk a speeding ticket as your speedo might read slower than your actual speed.  245/40/19s would be correct if you are going to 19in rims, they will give you a similar total diameter to the 245/45/18 tyres.
    • That's something I forgot to put in my list. The aggressive anti-squat in R32 is a f**king menace. I still need to decide if I'm going to drag the subframe out of my car and weld in the GKTech corrector kit. The main reason to dither is the need to switch to spherical joints in the lower arm to account for the twist induced in the rear pivot caused by lowering the front pivot. And yes...we do put better subframes in R32s, and I wish I'd gotten an S14 one instead of an A31 when I did the "take off and nuke it from orbit" HICAS delete all those years ago.
    • I have been looking at some setting on the alarms for the Q60 and what buttons do and so and also been looking for details on the alarm in my V37 which is a standard issue with the car. settings like window roll up and a few others seem to not work at all. i cant seem to find exact info on V37 alarms so Q60 is all i can really go off i have not tried 400Z alarm settings or info yet so that will be next. any one got like a sheet of info on the alarm system in the V37 as all my documents are in japanese but i thought the system would basically be like standard through similar models?
