Had a viper alarm put in fairly recently... i got the guy to wire the alarm up so that when you arm the car and the mirrors are open, the mirrors will fold in but he couldn't do it so that when you disarm the car the mirrors will open?
He mentioned something like a timer delay module, something like that, that's how he thought they worked on cars which had the option from factory.
He was going to run constant power line, but said even with the car off, it would drain the battery.
So yeah, anyone got their mirrors hooked to their alarms to open and close? I think Noof had done it, but i can't remember exactly.
laterz
https://www.sau.com.au/forums/topic/92139-wiring-fold-in-mirrors-to-alarm/
autotrust has it on his (along with sunroof control)... but then he's a Viper alarm specialist so he should know how to do it :)
I haven't seen him around for so long, what's he up to?
cool, i got a viper alarm, nice. Yeah, i haven't seen Danny popup for ages? i think i got his mb#, i might give him a buzz..
anyone know what he's up to?
anyone else got an idea of how to go about?
Hey Ash, will your alarm mate come out and do an install on site? Does he also do stereos?
he will, but its going to cost you.
He works from home afterhours and has his garage all setup with tools.
To pack crap up and what not is a pain for anyone if you forget even one tool or dont bring enough wire or whatever
PM me guys if you want his number, im lazy, its easier to reply than me send one out :lol: :lol: :lol: :lol: :lol: :lol:
u referring to alarm or compliance?
the fold out was something he hadn't done before... and it's something that no one seems to have a straight answer for either, so i'm guessing it's not that straight forward
I'd recommend this guy any time to do an alarm install, he did a great job and know's his stuff well. He's even got a V8 RX7 that he built himself, one of these self taught ppl :(
but yeah, the fold-out had him stumped, but if you gave him a day and access to any Jaycar kit he wanted, i'm sure he'd get it going ;)
Spoke to danny about it last night. He's been busy with his new Celsior and other cock-smoking activities. He said his fold in/fold out was hooked up to his sunroof control (which he controlled with the Viper alarm).
He also warned that due to the nature of the power mirror switch, you could fry the switch/relay/fuse if you tried to use the feature through the remote while the car was running (something about the car wanting the mirrors out while the alarm was trying to fold em in).
Best to call him and talk to him about it.
