the original 260rs wheels are 17 x7 bbs .. front are +30 offset,rear +20 offset,you need spacers and longer wheels studs for rear to use 34or 33 gtr rims from my experience ..finding the right rims for my car has been a real pain ..so left them std ...too hard
The R33GTR wheels fit perfectly on the RSFour, standard studs and no spacers. I wonder what the difference is compared to the 260RS.
:P cheers :(
not sure but std 7jj 20/30wheels will fit on front to back but car handles funny...different..18x9 34gtr rims +30...hit shockies on inside rear
Now I am confused;
A 9" rim (229 mm) with 30 mm offset is 144 mm in and 85 mm out
A 7" rim (178 mm) with 30 mm offset is 119 mm in and 59 mm out
A 7" rim (178 mm) with 20 mm offset is 109 mm in and 69 mm out
So a 7" rim with 30 mm offset is 25 mm further away from the shock than a 9" rim with a 30 mm offset. A 7" rim with a 20 mm offset is even further away, 35 mm in fact.
It can't be the shock that they are hitting, unless the bottom spring seat is lower on the 260RS's than the S1 or S2 RSFours. The picture of Brad's R33GTR rear ended Stagea shows what happens when the spring seat is too low, it fouls the tyre.
The other alternative problem is too tall a profile tyre, but that would also have serious speedo error issues as well.
:P cheers :(
Here's an interesting link to some guff on wheels. tyres, and all things offset.
Even has a calculator to determine what should be running - if you know what is standard in the first place!
http://www.chris-longhurst.com/carbibles/tyre_bible.html
can anyone with an s2 rs four s (manual) (ie comes with 17" rims standard) check their placard on the drivers side door jamb to see the specs including offset and width of the original rims.
...Cheers
Now I am confused;
:) cheers :)
re: the std 7jj rim
if i put rear + 20 on front ..they stick out of guards to much
if i put front + 30 on rear ..they fit but not much clearance to shock/spring
9jj + 30 is perfect for front but hits rear shock without spacers.. on my car anyway
I've only got an S2 2wd and the drivers door placard looks exactly like the photo further back in this thread. The car came with a users manual from JPNZ covering WC34 models - 2 and 4wd. It's tyre chart looks like this
Tyre Rim Size PCD OFFSET
195 / 65R 15 91S
15 X 6JJ
205 / 60R 15 91H
15 X 6.5JJ 114.3mm x 5 holes 40 mm
205 / 55R 16 89V 16 X 7JJ
dont know if this is any help - it makes no mention of 17' rims
thanks anyway guys but i really need the info for the 17" rim, is there anybody on the forums with an s2 rs four s manual?
(other than "thedriver" as i already PM'ed him but he hasnt been online for about two weeks.)
Mighty ford falcon! Finally good for something!
the rims i am getting are 18" by 7.5, with 235 wide tyres. 114.3x5 stud (obviously enough).
youll find that any set of rims up to 18 inch designed to suit an AU or BA falcon will fit. same stud pattern offset, caliper clearance, you name it. i had the boys at superior tyres at aspley fit 4 sets of wheels, each for an AU/BA falcon to see how they look, and they all fit. both on the hoist and on the ground. dont foul on anything. you have my word!
Sorry, I've been on a desserted island for the last 2 weeks and have only just made it back to the mainland.
I don't have the original tyre placard on my car. I guess it was replaced during compliance. The placard on my door lists:
205/55 R16 tyres on a rim size of 6 1/2 JJ 16
225/50 R16 tyres on a rim size of 7 JJ 16
However my car is fitted with 17" Nissan OEM rims that I have also seen fitted to other S2 RS Four S model Stageas in Japan. I have a feeling there is more info in the compliance documentation so I'll check that when I get back home.
Yep. Wifes out in it at the moment, but according to the compliance papers -
Rim size and profile: 7.5 JJ 17
Rim Offset: +40mm
Wheel track front 1450mm
Wheel track rear 1515mm
Wheel Center to top of wheel arch -
Front Unladen 400mm, Full bump: 310mm
Rear: 380mm, 300mm
- and I have 225/50 tires on (obviously on all 4 wheels!). Works fine :-)
That's for a 2001 S2 four S. :-)
I can pull a wheel off and check what is says on the inside next weekend if you want.
Edit: Wife home, but the label on the side of the door doesn't say (just gives the tire size and preasure). So I'd have to pull a wheel off and see if it was actually the same as stated in the compliance papers..
Ian
Edited by ian
I was wondering about using the spare if you have larger wheels than normal and you get a puncture.
Would doing this have an adverse effect on the 4WD system?
Would I be better of carrying a puncture repair system (e.g. Slime) and a 12V compressor in place of the spare?
What sort of size difference can the system cope with?
lol, cheers but i wouldnt worry too much about it ian, you have pretty much given me all the info i needed (for compliance reasons)
muchly appreciated, oh and by the way your RS FOUR S is awesome, i love the colour!
Just wondering why those running 18" rims are using 235/40/18 tyres as opposed to 22/40/18 tyres that have a closer rolling radius to the standard 225/50/16 tyre, apart from the fact they are wider?
Wouldn't the 225/40 have a narrower sidewall than the 235/40 - this is purely visual difference
    • Maybe also really stiffly sprung track cars. Get the inside wheel up in a corner and all the fun stops. Also me sometimes (rarely) when I have to stand on the brake to convince the diff to drive the wheel that is still on the ground when I'm trying to diagonally get over severe driveway entrance, etc.
    • I feel like I'm missing something. You had an authorised installer come out and install a new alarm. Post install the car doesn't start, and you aren't getting the installer back to fix what they did wrong?
    • So either way it is gearbox out and look what is wrong?  I know about the input shaft bearing. Even before swap/new clutch the it sounded exactly like this: So is that inout shaft bearing or the other was installed backwards?  And can some please tell me the part number for that input shaft bearing? The gearbox is small box from R34 N/A and number is FS5W71C. Thank you
    • I am yet to see anyone ever regret a quaife or helical. ...other than drifting/skidpan duties. I kind of want to upgrade my factory helical with a Quaife (but really it's not ultimately that different, and is a MASSIVE UNDERTAKING), that's how good the hype is about them, that I want to try them 'just to see'
    • D2 and Ksport are essentially the same thing and basically just generic Taiwanese manufacture. Better than ChinaBay crap, but... not top shelf. Öhlins have got to be some of the best dampers around, so likely to be a good option. It's going to get to the point though where I suggest you buy from Oz. We have at least 2x excellent options here. If I were you though, I'd be talking to KW about doing something for the R33. There's bugger all difference between that and the 32. In GTR land, anyway.
