Stagea Wheel Dimensions?
thedriver
I too have this question My S2 came with some nice Volk racing wheels and they say they have a +30 offset but they also have about a 30mm adapter which I believe is illegal if the offset is correct why is it that they need the spacer also the wheels have a totally different stud pattern to the car it seems like the spacers may be made for the wheels, could this make them Legal ?
Phill
The wheel sticker you have shown says the stud pattern is 5H 114.3 which is the same as the stagea, so they are they same stud pattern
At a guess is your car a manual?
18x8 +30 will fit fine if it is a "auto" as the rear track is wider by 50mm than a manual
If your car is a "manual" than it has the narrower track rear end, so the spacers will make the wheels sit out further so they fit (clear they rear shocks) and look better by filling the guards out
Any spacer is illegal
If you are worried about it, sell the rims and get a lower offset wheel.
Hi Thanks for that and yes it is a Manual, I tried to fit them without the spacers but the stud pattern was different ? they are closer together than the Cars hubs
Also who would buy them if they are Illegal ?
Phill
Phill
That is strange the wheel stud pattern will not fit without the spacers
Are the wheels multi stud pattern, ie do they have 10 holes?
Sell the spacers seperatly to the wheels
Many people mod their cars and not worry about it being legal
Not sure who would do that thou :D
Early Volk Jap wheels had small (approx 5/100) bolt pattern + big positive offset and then spacers/adaptors to suit different vehicle bolt pattern's.
Seen a staggered set of subaru wheels like this and personally replaced a set on a supra.
ok, new wheels are FINALLY on.. yet to get it wheel aligned so still some tweaking to do
s14 cradle fitted in the rear with cusco adjustables all round, cusco arms up front too
standard metal guards lipped but not flared
work vs-kf
18x9.5+2 R disk (95mm dish) 235/40/18 silverstone
18x9.5+1 O disk (120mm dish) 235/40/18 federal
why is the track on manuals narrower?
does this mean 'shorter' drive-shafts?
what other shafts fit?
thanks
work vs-kf
just wondering why you put the 14 cradle in?
was it a straight bolt in?
any other things you had to change to do this?
thanks
thanks
thanks
A s14 craddle is the same width as the stagea manual cradle.
The main difference is the S14,S15 and R33 GTS (non turbo) cradles do not have Hicas, so it is the best ones to use when reusing as much as possible of the stagea auto rear end.
Generally you change it to get the narrower rear track so it matches the front end and you can fit better wider and lower offset wheels.
Drive shaft length is shorter. Stagea have 3 different styles plus 2 different tail shafts. So use either skyline or s14/15 that suits your cars diff bolt pattern
The reason the manual has the narrower track is nissan was saving money and reused the rear end out of r33 GTR's. The manual also has stronger drive shafts etc, hence nissan used these in manual stagea's
Mike can fill in what he had to do to make this work.
nice thanks for that!
so stageas do not have hicas?
so manual stageas have the diff and driveshaft out of the 33 gtr, ie. big 6 bolt half/drive shafts?
doesnt the gtr diff have hicas also though?
"So use either skyline or s14/15 that suits your cars diff bolt pattern" : do you mean half shalf bolt pattern or tailshaft bolt pattern?
thanks!
darrin pretty much answered everything
i went s14 cradle myself because my car does not have hicas, and i didn't want to fit a manual stagea cradle that has it (means i can run aftermarket adjustabletoe rods, which i am)
the part you have put in quotation marks, he is talking about half shaft bolt pattern. the gtr rear end is a 6x1 bolt from memory, s14/s14 is 3x2 bolt and r33 is 5x1 bolt (which i am using to match my 2 way diff in r33 housing)
My auto stagea series 2 had 5x1.
The stagea manual one I have now is 6x1
Both had the same diameter drive shafts
There is 2 different tail shaft sizes as well. My car had a fairly heavy looking one and a I was also given a much lighter one, but thru it in the bin
ive read all 15 pages and nobody has tried or is running 17x9+35. my 18x9+20 bbs rims are a perfect fit. im just wondering if the extra 15mm further inwards would make the wheel scrub on anything?? shocks, inner guards etc.??
that's 5mm less than an r33/34 gtr wheel. should be fine
