Heck yeah. as long as above isn't sarcasm.
Affordable means they can live on a daily.
How much poke if any are people gettiing on 19x9.5 +15s on manual C34s.
I want as little as possible, as mentioned its a daily.
Also how much scrubbing, and guard work is needed.
By my dodgey maths, it seems like as long as i dont go too low should be sweet.
I run 19x9.5 +12 with 245's
The rear clear bilstein struts by 7-9mm and no guard rolling at all with a low ride height of 320mm (too low and chews tyres every 6-8000 km)
You should be right with 9.5 +15....pretty common on R4s....if tyres hit struts, just use a 3mm spacer to get to +12
Cheers guys, looks like its go once the guy I sold my pupra to comes to picks it up...
My V35 17" (I think 8" +30) rears rub my coilover collars without spacers (it came with massive 1" bolt ons), I really dont want to have to put different ones back for new rims.
I also dont want to over tyre with anything bigger than a 245 so should be win.
My car is stock barring exhaust so any wider is just a fun canceller.
guys, i need someone to confirm if these will fit my car.
Fronts are 19x8.5 and rears are 19x9.5 +22 offset.
buy some posts in here, there were some confirmation that the rears would be ok. Just not 100% about the front.
cheers
cheers
If you plan on running it with the Attesa system, then no, they won't work. They need to be the same width (different offset is fine) on all four corners.
Ahhhh... ok ok.. why do they need to be same width?
I had 17x7 front and 17x8 rear with same size tyres with no problems. I believe as long as the tyre circumference is close it should be fine.
I tried the same on my S1 and it hated life. Haven't tried it on the M35's but apparently they are more pedantic about it again than the C34's.
That was a good read(s). Had to go over it a few times! lol
Its still 50/50 on whether or not the wheels im looking for is still safe to purchase. By what I gathered from reading the above mentioned thread, it SHOULD be ok just aslong as the circumference is within a tolerable range.
My honest opinion is the age old, if in doubt, don't. It is something I have considered while looking for rims but undecided yet, best talk with a workshop that deals with this type of thing for best advice. My other thought is if it were such a problem, why the space saver tyre? All of its dimensions are different to stock size.
The important thing is to keep the same rolling diameter/circumference on the front and rear. Otherwise, it creates variations because the front and rear wheels are rolling at different speeds, then the ATTESA computer tries to constantly correct it, and it creates extra (and unnecessary) wear on the transfer case, leading to expensive repairs.
Cool. So pretty much, all I need to ensure is that the rubber is all the same? the fact that front and rears widths are different shouldnt impact the ATTESA.
If widths DID impact it, then staggered sets would be obsolete. right?
Can I please get some help here, as mentioned previously I am looking at getting some 19 x 9.5 +12s for my rs4s.
So I did a trial muck around with a mates set or vskfs which are 9.5 +28.
I took some measurements with my 26 mm wheel spacers for total offset of +2 and I was around 10mm poked at the back which will end up fine with +12s.
Up front though there was like 30 mm of poke.
How poked out are people running 9.5 +12 or +15s up front.
Photo proof with spacer.
This ones upside down so imagine I can take a photo properly....
I don't know how your 2wd differs from my awd formerly auto but if I were you I would bolt them on and modify the guards to suit (not put too small tyres on). I started off with a guard roller but found a length of iron pipe worked best. You will lose paint in the process - I don't think the heat gun approach prevents that. Mine are 17 x 9 +30 with a 20mm spacer on the front.
    • I don't understand how this hasn't boiled down to - Upgrade the turbo when you have everything required. ECU, injectors, fuel pump, turbo, etc. Do it all at once.  If you don't have everything required, just enjoy the car as it is and keep saving up your pennies.
    • Sounds like you've got an interesting adventure ahead here with local support if you have trouble! My guess is that, unboosted, you will be OK with a small upgrade like -9. What will happen is that once the stock ECU sees more airflow than it expects it will add a heap of fuel and pull a heap of timing to be safe because it can't understand how it could get that much air without there being an issue. You will see clouds of black smoke and it won't pull hard through the midrange and top end. So, overall it will be a bit frustrating but should be OK. If you are still nervous set the base timing back 2o through the CAS, but it will be even more sluggish everywhere. As said above through...this is not my guarantee your engine won't be blown into a million pieces, leaving you looking for very hard to find parts A better idea is get a computer with logging ASAP, wire in a wide band O2 sensor and a use remote tuner. I've done multiple cars this way and while it is not as good as a specific tune on a dyno they can get it 90% right. I'd suggest if you can afford an R33 GTR these days you can afford an ECU and tune. And if you can't afford that you sure won't be able to afford the rebuild if it goes bad in the meantime,.
    • Yeah it would be nice if someone took the time to put that sort of information together, but there are a lot of variations in looms. I think you are making this way hard for yourself if you just want to get it running....sourcing an SR20 with the right wiring will be a billion times easier than matching the RB loom to an S15 chassis. If you do end up going this way, you just need to trace every wire in the loom with a multimeter, 95% of them will go to a location you can confirm at the ECU.....and then post it up for the next person who needs it
    • Just top it up with water, and keep a general idea of how much you added. It is normal for water to be pushed into and pulled out of the reservoir through the cap, and it should not be more than half full or it will be likely to overflow when hot. Any decent mechanic can do a pressure test of the cooling system to confirm if you have a leak. Keep in mind if it is only leaking a little and when hot it may well evaporate before you see it hit the ground
    • I'd ask the shop what they used and use that. Mixing coolants is sometimes OK, sometimes not, and you have know the details of each coolant to know whether it's a good idea or not.
