Actually, I should do that.....
Take some pics etc and make a decision after looking over the pics too...
For some reason I keep thinking I would just buy them online and then have them fitted in town.
Oh, I dont think they will be right for me then as I would prefer to fill the guards out and will be getting cool overs etc.
Any suggestions for rims? I would ideally like to get Nismo rims.... Anyone know of a Nismo rim to suit?
Problem is I don't really want to do too many mods and stuffing around..... Trying to just find rims that will fit best.
Thanks for the replies do far, really appreciate the help.
If you want to fill the guards a bit then something like R34 GTR wheels might be a better bet, they are 18x9+30. They come up for sale on this site every now and then.
Alternately you could probably find a set of Nismo LMGT4's in a similar size to that, however since they are discontinued it may take a bit of searching to find good condition ones in the right size for the right price.
As bentwagon said, see if you can get some wheel places to trial fit some different wheels on your car, it will give you a bit better idea of what you are looking for.
This is 18x9+18 on a s1 automatic, so you can see you do have a decent amount of room to play with if you want to fill the guards.
I actually like both those rims pictured............
But I am after 18s, so 180fan - Is that your car? If so, did you have to lower the car, roll the guards or use spacers for them rims? and for it to sit like that? I am guessing you'd have to lower it, but what else have you had to do?
Where can I get those rims? I do like them.
Yeah its my car. The rims are Volk Racing GT-7's, i bought them used from JImports, a business who bring in heaps of different parts from Japan. I havent seen many sets of them for sale since I bought my ones, if you wanted to try and find some i think your best chance would be looking through Yahoo Japan auctions for them. Check out www.importmonster.com.au, it will let you search through the auctions for all sorts of things and will also translate it to english.
The car is lowered on coilovers, the rear guards have been rolled, but not the front ones. Not using any spacers, the front wheels could actually be spaced out about 15-20mm because of how much room the c34 front guards have, i just havent ever gotten around to doing it. Tyres are 235/40, i have had the wheels on for almost 2 years now and havent had any scrubbing problems or anything like that.
Hi everyone,
Just wanting some help if possible. I have been a long time reader on here but have only just signed up as I really would like to know if a particular rim would fit my RS4 Stagea........ Can someone tell me if the rims in the link will fit my car? Better make sure they will fit before I click the 'buy it now' etc. Thanks in advance :)
I actually wanted the Nismo LMGT4s but I have been told they won't fit??
http://www.ebay.com....b#ht_2030wt_911
if somebody told u LMGT4's wont fit they are high! if you just buy a set that is 9inches all round they'll fit fine. you want an offset somewhere close to +20 all round give or take 5mm
Ray I disagree
Are you quoting a auto or manual stagea 9 inch +20 all round?
If you look at Kiwirs4t photo he has 17x9 +30 on an "auto" and the rears are already hanging out the guards
If you go +20 or +15 you will be hanging out even more.
LMGT4 may or not fit..........it depends what caliper clearance they are......like Disk "A" or "B" or "C" etc.
    • Hi. Sry iam not a mechanic and iam not at the car atm so i dont know 100% but they told they measure those and even try to change those. AFM they have two. Coils are new a they have my old one too. Plugs too. ECU...we have 25 NEO stock and Nistune 25 NEO.   But i dont know if any one those could be the problem and why/if/what can cause this, Only thing they did not check is fuel...but that walbro 255 is new(like 1,5 years)... That fuel pressure gauge idk...but i let them know Any suggestions?   EDIT: how can they know if it is like you say he ECU pull power when it reaches a specific boost level that is too high? Tha car has boost controler
    • Can you clarify what you mean by boost cut, do you mean it misfires both when under load (driving) and when stationary and out of gear? Or does the ECU pull power when it reaches a specific boost level that is too high (boost control issue)? Does it occur at idle with no throttle? When you say "the ECU is OK", what ECU is it and why do you think it is OK? Have you used the NEO ECU, and if so do you have a MAP sensor attached? Same for the AFM, why do you think it is OK? Do you have any way to put a fuel pressure gauge on it (even just a mechanical one between the fuel filter and fuel rail)?
    • Hi.. Just another problem. So maybe you can help. I(my mechanic) done swap from my RB20DE NEO to RB25DET NEO. Everything is OK but we have a boost cut. Coils/Plugs are ok...AFM is ok. ECU is ok. I have Walbro 255 but it "changed" sound few months ago(you can hear it ouside) you did not hear that when it was new(maybe faulty?) Sooo...what now? What can cause this boost cut? It is even when you standing still...
