Actually, I should do that.....
Take some pics etc and make a decision after looking over the pics too...
For some reason I keep thinking I would just buy them online and then have them fitted in town.
Oh, I dont think they will be right for me then as I would prefer to fill the guards out and will be getting cool overs etc.
Any suggestions for rims? I would ideally like to get Nismo rims.... Anyone know of a Nismo rim to suit?
Problem is I don't really want to do too many mods and stuffing around..... Trying to just find rims that will fit best.
Thanks for the replies do far, really appreciate the help.
If you want to fill the guards a bit then something like R34 GTR wheels might be a better bet, they are 18x9+30. They come up for sale on this site every now and then.
Alternately you could probably find a set of Nismo LMGT4's in a similar size to that, however since they are discontinued it may take a bit of searching to find good condition ones in the right size for the right price.
As bentwagon said, see if you can get some wheel places to trial fit some different wheels on your car, it will give you a bit better idea of what you are looking for.
This is 18x9+18 on a s1 automatic, so you can see you do have a decent amount of room to play with if you want to fill the guards.
I actually like both those rims pictured............
But I am after 18s, so 180fan - Is that your car? If so, did you have to lower the car, roll the guards or use spacers for them rims? and for it to sit like that? I am guessing you'd have to lower it, but what else have you had to do?
Where can I get those rims? I do like them.
Yeah its my car. The rims are Volk Racing GT-7's, i bought them used from JImports, a business who bring in heaps of different parts from Japan. I havent seen many sets of them for sale since I bought my ones, if you wanted to try and find some i think your best chance would be looking through Yahoo Japan auctions for them. Check out www.importmonster.com.au, it will let you search through the auctions for all sorts of things and will also translate it to english.
The car is lowered on coilovers, the rear guards have been rolled, but not the front ones. Not using any spacers, the front wheels could actually be spaced out about 15-20mm because of how much room the c34 front guards have, i just havent ever gotten around to doing it. Tyres are 235/40, i have had the wheels on for almost 2 years now and havent had any scrubbing problems or anything like that.
Hi everyone,
Just wanting some help if possible. I have been a long time reader on here but have only just signed up as I really would like to know if a particular rim would fit my RS4 Stagea........ Can someone tell me if the rims in the link will fit my car? Better make sure they will fit before I click the 'buy it now' etc. Thanks in advance :)
I actually wanted the Nismo LMGT4s but I have been told they won't fit??
http://www.ebay.com....b#ht_2030wt_911
if somebody told u LMGT4's wont fit they are high! if you just buy a set that is 9inches all round they'll fit fine. you want an offset somewhere close to +20 all round give or take 5mm
Ray I disagree
Are you quoting a auto or manual stagea 9 inch +20 all round?
If you look at Kiwirs4t photo he has 17x9 +30 on an "auto" and the rears are already hanging out the guards
If you go +20 or +15 you will be hanging out even more.
LMGT4 may or not fit..........it depends what caliper clearance they are......like Disk "A" or "B" or "C" etc.
    • Well you could certainly buy or build an enclosure for a pod in that corner of the bay. It is absolutely vital that there is a nice big opening to let cold air in to it from the front or underside, otherwise it will just pull air in around the edges from the bay, and if that air is hot, you gain nothing from enclosing the pod. There is lots of good evidence around (including on here, see posts by @Kinkstaah for example) showing that pods pulling hot air from the bay is only a problem when you're static or slow in traffic, and that as soon as you get the car up and moving the air being grabbed by the pod cools down. Although that will obviously vary from car to car, whether there is a flow of cold air to the pod or if it all has to come through the radiator area, etc etc. Obviously, the whole exercise requires as much thought as anything else does. Doing the lazy thing will often end up being the dumb thing. The stock GTT airbox has a cold air snorkel to feed it from over the radiator. Shows that Nissan were thinking. The GT airbox is upside down compared to the turbo one, yeah? Inlet at the bottom, AFM/exit on the lid? That might make it harder to route the turbo inlet pipe using the GT airbox than a turbo one. That would probably be the main reason I'd consider not using it, not that it is too small and restrictive. I'm looking at a photo of one now and the inlet opening seems nice and large. Also seems to have the same type of snorkel that the turbo one has. Maybe all that's required is to make a less restrictive snorkel/cold air inlet, perhaps by punching down through the guard like I did.
    • Also seen this as an option
    • I get you, we’ll see I’m aiming for 200ish kw now and hopefully 300rwkw down the line after some upgrades maybe like headstuds, E85 flex fuel etc  so trying to make it final for that now, I can get a GTT airbox for $280 so it’s not too bad but not sure if there’s better ways to spend that money. I seen online they say pod filter which isn’t enclosed isn’t good especially for a plus T.      hard to say what to do
    • Meh. How much power can you make from a +T anyway? I wouldn't have though it would be enough to challenge the airbox. It's not as if it's tiny compared with the turbo one. As to putting a pod in a stock airbox .... it's not the filter element that would be restrictive. It would be the air inlet to the box that would be the narrow point, which you could open up regardless of what element was inside. On my R32 I opened up the sort of triangular opening in the bottom front corner of the box, deformed (heated, moulded) some 4" stormwater pipe to fit to that opening and punched a 4" hole down through the inner guard to the spot where the stock intercooler used to be. This was purely in the search for a cold intake, but you could do something similar if you need to open up the inlet side of it. The AFM tube size is the same for both NA and turbo, so the outlet from the airbox is same same anyway. If you're going to do the right thing, then an aftermarket ECU won't care about the AFM (ie, you can get rid of it). But even if it was still there, people pull >300rwkW through them all day, and I suspect you won't be going there.
    • R34 RB25de Neo by the way ^
