If they are 7+40 vs 9.5+12 you will have 4mm less inner clearence and extend out wards by 60mm
Shit.
This means on the rears on 18x9.5 +12 I would need to run maby a 15m spacer. That's not cool.
Surely sonething is not right here.
Has anyone else ran these specs on an rs4s
From this thread they seemed to be ideal specs...
This is what I'm getting with stock R34gtt wheels
You can see where it touches. Mainly going up a driveway on an angle when there is flex.
I'm assuming the specs for the R34gtt wheels are right. I got them from the skyline wheel specks thread, I will check the wheel itself tomorow when it's light.
Anyone else running 18x9.5 +12 on their rs4s who can check their strut clearence?
Edited by GH05T
I thought gtt 34 where 7.5 et 40 which means you will gain 3mm clearance on the inside and a further 53 mm on out so yeah you will have to run spacers inner clearences to strut must be vastly diff on manual hmmm
gaining clearance is good....
gonna use some slipons for the time being...hopefully 8mm will be enough to clear.
it only touches when angeling spoon drains and driveways.
will check the offset when i get the wheels off at work today to confirm their specs
also im sure the lowering has added a little bit of camber which will be sucked out when i fit the new wheels
the kms i do anything other than 0-0 camber is madness
Edited by GH05T
Yeah lowering will add camber, and then with the slip on spacer and new wheels you should have over 12 mm inner clearence ;) will be fine a bit of extra poke out the back won't hurt anyway
ok stamped on the R34 wheels i can confirm is
17X7 JJ +40
so im going to loose a further 4mm clearance from the inside on the new wheels.
hmmm so 18X9.5+12 DO NOT FIT RS4-S stageas
when the new wheels arrive i will need to test fit them without tires and see what is going to need to be done to clear them to my liking and how much outer extension im going to get.
the wheels will naturally add 60mm (from the R34 wheels not stock stag wheels) and im assuming im going to need maby a 15mm hubcentric spacer to properly clear them.
maby less once the wheels lift the car a bit and the camber is taken out.
so spacers, roll the guards 235/40 tires, 0 camber and we should be ok, gonna look fat either way.
a tiny bit worried about the extra strain on the bearings but meh.
amazed that the issue was with the rears on the 4WD seing as i understand they have a narrower subframe (more like the R33gtr?? )
and the fronts are happy as larry.
Edited by GH05T
yeah thats what i have been reading too.
well the truth will come out when they arrive i guessshould be early next week.
im hoping i have missed somethig, mis calculated something misread something, and they fit without further modification but i dont see how.
i cannot imagine the coilovers would make that much of a difference, they may be thicker but their is only so much difference they could make.
Well I'm perplexed jet r31 is running 9.5 + 20 on his auto with Bc coilovers "the rim to coilover should be the same between autos and manuals just the out side diffrent " he has 5to 6mm clearence at I think neg 2 camber so if we look at that you at 9.5+12 should have 8mm more clearence on the inside so a total of 13mm clear and stick out 8mm more but ya got heaps of rm that way :) !!!! Then if I look at me I'm attempting to run a 10+5 so
Just took a pic of mine for you (sorry it's sideways, uploading from phone and it rotated it). As you can see there's quite a bit of clearance with the stock shocks, I'd say a good 15mm. Obviously BC's are thicker though. I'm not sure how much but you can work that out. Mine is as stated earlier s2 rs4s running 18x9.5 +12 with 245 40's.
well wtf is goin on here. i cant work it out.
is their anything that could be different on my model?
1998 Series 2 RS4-S manual 4wd
everything looks stock appart from the BCs, unless my wheels have been tampered with...nah im just pulling at straws now.
i will be VERY interested when the wheels arrive for test fit.
    • Scenic roads, stunning skylines, and Chickos to finish it off! Join SAU NSW as we cruise through the Royal National Park and along Lawrence Hargrave Drive to Figtree! Sunday 26th October 2025 4:30PM Meeting Waterfall Station Parking 5:00PM Cruise Departure Royal National Park > Lawrence Hargrave Dr > Memorial Dr > Sid Parrish Park 6:15PM Arrival at Sid Parrish Park Figtree Meet Location: Waterfall Station Parking Final Destination: Sid Parrish Park RSVP: https://forms.gle/E4s5SiRKQfDdypky8 *Disclaimer* There will be a lead and follow car so no one should get lost. If you would like to attend or bring others along please put your name down and a +1 as numbers will be needed prior! This is NOT a race and we will all be adhering to all road rules. If this is what you want please come to one of our many track days. This is an official SAU:NSW event and will be run under a CAMS permit. One of the things that really sets our club apart is our commitment to being true enthusiasts. When on normal roads we strive to maintain good relations with the authorities as well as the public in general. When attending one of Skylines Australia NSW events please try to: • Be aware of surrounding environment and act accordingly. • Drive courteously on the state’s roads as a true enthusiast should. • Understand how important it is to maintain the good name of SAU NSW and thus, treat others accordingly. • Any misbehavior will not be tolerated and you will be asked to leave.
    • It's funny, as Ive seen plenty of people use them in cheap builds on YT. And they actually go okay, even though a lot of other maxspeedingrods stuff is terrible. Those turbos seem reliable enough, the only part being, a good quality turbo that is "identical" to it, will out perform it day in and day out. In both a lower boost threshold, and the ability to flow more air at the same boost pressure. As a cheap cheap replacement, not a terrible choice. For cheap and shouldn't blow in a day, not terrible (like other eBay/Temu turbos) for low cost and still decent performance, that's where the question comes in to play from the results I've seen. I'd actually find it hilarious to buy one, and strap it to a paddock basher or some other cheap as POS originally NA car, and send it to the moon!
    • The maxpeedingrods turbo is cheap and bolts on to stock parts. I think you just need a bigger silicone coupler for the intake. Its a cheap china turbo, but it's been running on mine for almost 3 years at 16-19 psi.
    • What do they look like right after you've tried to start it with everything connected? Also post photos of what they actually look like.
    • Also wanted to say, my new spark plugs are blackened looks like it's very rich. I have splitfire coilpacks but stock coilpack loom and ignitor. I tried directly grounding the ignitor ground to body as well.
