Has anybody fitted a cooler that has in and out on the same side (not having a pipe run at the bottem) ? Wile using the standed piping
I think it would look quite good, as when you open the bonnet it will look standed.
  • 2 months later...
  • Replies 254
Posted Images
I'm also wanting to know if anyone has one fitted like this
from what i can find there's a blitz intercooler that may use the standard pipes? (not sure), part number is 13101.
Has anyone used this kit or have any pictures of it installed?
the layout is shown on the top of the 4th page Here
Can anyone translate the remarks section?
return flow front mount? im getting one of these in the next few weeks. i think these are a blitz or hks copy
http://justjap.com/s...355&cat=&page=1 - alloy kit
http://justjap.com/s...944&cat=&page=1 - black stealth kit
Edited by RS4-S
  • 9 months later...
how come all these stagea owners love the commodore,ive been noticing it in many pics and comments that its not only me that owns a stagea and love hsvs[got 2 sv90s]vk group3][calais director]and my beloved stagea series 2.5.
sorrry for getting of subject.but had to comment.peace, love the thread.and the group a
yes front bar support needs chop chop as it blocks about 30% of the top section of the cooler from airflow.
this is the original shape of the support bar (thought the centre bit was cut abit from the previous owner making me think it had a fmic on it b4 in japan)
and this is the original bumper shape without a numberplate on
i reckon the bumper is worth cutting abit to get rid of the number plate solid block of plastic setup, checkout my bumper and how much of the cooler is visable, though i know u dont like to be showing it off but for airflow it must be heaps better than stock. and u could always paint the cooler black (if it isnt already).
lastly heres a pic of the cooler piping in alluminium (3 of the pipes are polished and the last one hadnt been polished in the photo to show the difference)
Note: this is for rb26 so piping is alot different.
cheers
Brad
Hi everyone. I haven't gotten around to writing up the build but here is a vertical intercooler I installed a few months ago. A couple of new pipes join up to the factory piping before entering the engine bay. Rated at "663HP-1002HP at max efficiency 1.5psi pressure drop". Yet to install Profec B and Nistune however! Should suit skylines aswell?
Buy it now while the exchange rate is good! Shipping is about $100.
http://www.treadstoneperformance.com/product.phtml?p=34&cat_key=63&prodname=TRV25+Series+Intercooler
i used to have a cooling pro(just jap) black stealth intercooler on my R33, was making decent flow and i made 225rwkw before upgrading to a bigger fmic - not due to lack of flow i believe people are getting 300rwkw with the stealth, but a much larger setup on my engine inc a bar and plate fmic and i dont think the stealth would flow 400+rwkw with my automatic box.
mmm tidy setup.... but the lag pipe(return to the stock pipe) is really not beneficial.... u put a good high flowing fmic, into a setup like that which if you go for a decent sized turbo will cause you some degree of lag. i had that problem with less pipe than you have got and my t67 with .82 rear, i gained boost nearly 500rpm earlier from taking out the return flow style setup. just some food for thought, but nice and tidy i will admit.
  • 1 month later...
  • 1 month later...
Hey fellas...
I have a 98 WGNC34 series 2 stagea RB25DET
I want an intercooler that will support 300 rwkw and will run through the factory piping
any suggestions?
Does the PWR R34 GTT fit?
Thanks
Edited by Wildanimals
Never sen one but if it fits a R34 GTT you should be able to make it fit.
I had a cooling pro return flow but it struggled after about 250kw. They say the Blitz return flow is good for 300kw although I would have thought that was pushing it. I have a normal Hybrid fmic now. What is the size of the PWR core?
Hey fellas...
any suggestions?
Thanks
I had one on my old Stagea series 2 it was putting out 330kw at the wheels with ease...
PWR reconds the r34 gtt one supports 600hp at flywheel - 350kw at wheels
i assume there are no bolt in fmic available for wgnc34 stagea? anyone know?
also any suggestions on what size injectors or mas air flow sensor (air flow meter) i would require to achieve 300 rwkw in wgnc34 neo rb25det stagea?
cheers
    • From my youth: GTi-R clutch change is a massive pain. The gearboxes are fragile? But the car is super cool and I want one 😢
    • Remember this is 1988 tech.
    • Driveline vibration is resolved. I ended up loosening all my engine mount and trans mount bolts, giving it a good shake then retightening everything and it's gone... Let's just say I was surprised that fixed it.  I've been happily driving it around again but unfortunately put zero time into my direct port/constant pressure WMI setup. I'm on vacation next week, so I'll try and finalize it then.  On a different note, I spent all week fuel/ignition mapping 2x 216L V16 engines. Turbo's were burning glycol and we swapped them out for larger units. We also had planned emissions testing on site, so I figured I'd be there the same week to use their instrumentation and massage any emissions issues out if needed. This was a first for me. Fuel management is similar in certain ways to automotive (i.e air density as load variable) but very different in others. It's all PLC based and AFR's are controlled by air and not fuel. They use a control valve between the turbo and air manifold to control pressure which in turn controls AFR's. Due to this, target AFR tables supplied by the OEM are in pressures and not mass which really through me off. They use air pressure vs fuel pressure tables. I also relied on an O2 concentration sensor the emissions team had in the exhaust. Ignition timing was also all over the place and we were losing a fair bit of power. They're now happily sitting at 16-40BTDC depending on load. We were making about 1600kw at 900rpm at 90% load. Engines were running a lot smoother as well.
    • heh, aint no R32 ever meeting modern targa cage rules unless the driver is veeeery short OP, good luck with the sale, since its already in the land of freedom I'm sure you will find a good buyer.
    • meh, it was a good video, clear about the issue and how he dealt with it. A bit heavy on the RTV and very brave to put an RB in anything without rebuilding it first, but otherwise I thought it was good Dose, I'm not sure that having the pickup forward is a big issue; yes of course the oil could shift under brakes but the sump should never be empty enough for that to be a problem (unless you also have a higher volume oil pump, and that oil can't return from the head to the sump quickly enough)
