Peter, thankyou for your superfast delivery & excellent product.
We've checked & changed so many things over the past year and then when the car started stalling in the middle of the freeway etc it got very dangerous. The interface has been invaluable, being able to log everything, we diagnosed the problem very quickly.
Now we can get on with the fixing and stop stuffing around :)
Cheers
Kaz
  • Replies 91
AFM voltage all over the place.. should be at 1.1v at idle or some such.. voltage drops out whilst driving, car stalls, voltage goes back up (even when car still not running).. I'm sure Michael can be more specific. :)
I'm sure Michael can be more specific. :(
heh...more to the point..it's shagged ;)
Seemed to be either connections in the afm or the loom. as kaz said the data logging showed the afm voltage would drop off (showed 0.5V) just before the car stalled. Voltage specs also didn't match what was detailed in engine manual when cranking / idling etc (idle should show 1.1V and I can't remember the others off the top of my head).
Swapped it with a friend's AFM and logged it, and it showed everything as it should be.
The data logging function + the engine manual together are invaluable :) I just needs to find a better program to graph the data logged (excel is terrible unless you've taken a really short sample). Any suggestions would be great :)
datalog viewer (for datascan logs?) is $us20 from here: http://www.blazt.biz/products/dviewer.htm
haha the top of the page reads:
"Having trouble reading your datalog files?
Sick of converting numbers to graphs in Excel?"
Sums it up in one :D thanks for that.
Michael
Peter, I put mine together and discovered it didn't work. A first for me with a kit. I had a look at 46n2's board last night and discovered there is a small error in the instructions. My fault for not looking at the pics enough but I normally go off the diagram. The board diagram has male marked as the 2 led end and female as the capacitor end, and so too do your instructions but the actual picture shows them around the other way (unless I'm having some identity issues with what constitutes male and female :P).
As soon as I swapped them it was running perfect.
sorry im not sure which component you're talking about? the serial connectors? the female end goes on the left of the board (near capacitors and red led). i guess the pic showing the board upsidedown doesnt help? (ive removed it cause it doesnt really show anything as its too blurry)
Edited by NewKleer
Yeah I guess it's what you define female and male, and I was talking about the serial connectors sorry. I was looking at the overall plug, and not the pins but considered that way it makes sense to me.
Here's a few more pics that may be of use.
post-6392-1131841861.jpgpost-6392-1131841924.jpgpost-6392-1131841975.jpgpost-6392-1131842038.jpg
just reached the 24 limit today - i do have more parts (not packaged together yet) but ill leave accepting any more orders till ive put them together and confirmed all parts etc are there.
id guess maybe another 20 worth of parts, so dont be too concerned if you missed out just now, as i should know by at latest end of this weekend whether i have all needed parts (but maybe next day or two, depends when i have the time)
when i get a chance ill also look towards some common troubleshooting tips such as checking voltages and so on for when the interface doesnt work.
Put my together last night..
Surprisingly seemed to work first go.. although one of the biggest problems was sorting the pins in the consult plug cable..
Mine has some problems of losing the signal occasionally as the plug doesn't appear to 'lock in' fully to the car's port... even though the pins are at the same level as the inner plastic. Might try and pull them forward.
Oh, and calumsult doesn't work on win98 :P and my ancient laptop.. damn.. Conzult does though :)
good to see most people are getting it to work first time. if ur having any issues (eg the plug) see if u can take a pic and post it here and i can have a look at see whether anything seems out of the ordinary. the plug should fit in quite firmly in the car's socket.
its good to have o2 sensor fluctuating - its bad if it stays the same. when it fluctuates ur hovering around the 14.7:1 AFR which is ideal for cruising/non power conditions - when ur travelling constant speed ur o2 should definitely be fluctuating continuously up and down, almost 0 to 100 and back and forth
Edited by NewKleer
hey pete, i recieved mine today, and im very happy with it, just finished soldering it up on the work bench and its bloody well designed, give ya self a pat on the back, can wait to try it out tomorrow......
cheers... Pete
hope to have more kits available by end of weekend
just a note about the software - ive added a link to an old calumsult.exe - this should be used if theres any issues with rom dumping as the author said he may have messed up the routine a bit in the latest version.
just a reminder about the parts - not all kits have the same parts as the construction guide - some kits have 27 or 33pf capacitors (both work fine), and some have electrolytic or tantalum capacitors (for the 5x1uf and 1x10uf) - with a few having a combination thereof (eg 5 elec and the 10uf being tantalum).
check the picture in section 10 of the construction guide to identify them.
OK, who's a computer wiz that can quickly tell me how to get this thing to work with a laptop that has no serial ports. I have a USB to serial cable, but I can't find where to tell the latop that I want the USB to see/emulate/ look like/be com port 4.
:P cheers :D
    • What an awesome idea to fit the facelift Lamborghini Diablo headlights. They are a perfect fit!
    • An update regarding the registration with the DVLA I sent off the paperwork the day after I collected the car from the port, two weeks later it was all returned with a letter explaining they have rejected the application. This was because the cheque was £20 short for the road tax (I used a price list I found online). Nevermind it is what it is, it was sent back to them the following day with a new cheque. Fast forward another 2 weeks or so, I called them for an update to be told it had been rejected. Yesterday (16th September) I received the documents back along with another letter, this time it was because I didn't put an X in one box on the V750 (personalised number plate certificate), which declared that I had the rights to the personalised number plate. Why this wasn't mentioned in the first rejection letter, I don't know, but it could have saved this headache. The documents were sent back today, so fingers crossed third times a charm and it'll FINALLY be registered on the road just in time for the bad weather (woohoo!) To cheer myself up I lowered the front 25mm, was sick of seeing it sit like a monster truck. No idea how much clearance I'll have getting on and off the driveway, I'll worry about that when I can actually drive it
    • You're going to miss not worrying about rust in the strut towers like the Skyline shitboxes out there
    • A few little updates that weren't filmed due to not taking long to do or not interesting enough for their own video. My new K&N Air Filter arrived, I went with an RU-4180 which matched the dimensions of the universal cone filter the car originally had.  The battery had gone flat, while that was charging I tidied up the spaghetti wiring at the bulk head and down the sides of the engine Next job was to swap the stereo The Kenwood harness had the female ISO plugs cut off and the male ISO plugs cut off the adaptor loom and joined with bullet connectors. I ordered in a repair loom through work and re-did it all. New Kenwood unit installed (Android Auto, DAB, Bluetooth, Reverse Camera) The bonnet/hood gas struts have been poor since collecting the car. I couldn't find any suitable replacements locally so took a chance on a pair from AliExpress.  The originals don't use a retaining clip to secure the cup onto the ball fixture, would explain why I struggled for 10-15mins trying to pry off the cups. The ball fixtures unscrew using a 12mm spanner, new ones are the same size. Sadly no photo of them fitted, you're not missing much lol The dished Momo steering wheel got replaced with my Momo Tuner, turns out I ordered counter sunk bolts for the horn trim ring (like they normally are for the steering wheel) instead of allen cap (flat seat)  A terrible photo of a Quaife style gear shift knob I've had stashed in my tool box for many years after purchasing the incorrect thread size (I can see a pattern emerging with ordering incorrect parts...) Also threw in a cup holder and a (empty) Boss Coffee can, because why not
    • GT-R clearly the better choice! The 300 is certainly not insaly fast but has a decent amount of poke. Does a nice little drift around the corners with a decent amount of throttle. It's VERY predictable in a slide too.  Feels so progressive! People probably presume there's a 25 year old driving it based on my behaviour this week! 🤣
