  • Replies 97
Hey this dyno day stuff sounds mad, couldn't make it this time, when will the next one be?
Next SAU-one will be next year sometime.
Usually every 6-12 months. Everyone should dyno thier line @ least once every 12 at a min IMO... just to make sure everything is going as it should be :P
mine goes on every service usually. just to check
no shame in getting beaten by animal XR6T's though...or typhoons for that matter.....mmmmmmmmmmmmmmmmmmm typhoon....sex on wheels
those wang busters sound like shit lol. i tried to try guiness once...couldnt get through the cream on top. feral shit
    • @Kapr Haha yeah thats the one. I missed that you had a built up engine, I wouldn't want to run it on there either then. It was good in my situation just to replace the original turbo on a stock engine. @MBS206Yep definitely not a replacement for anything name brand
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
Ă—
Ă—
