Hi all,
well ive seen a few threads of the type recently, so thought i might post one up also for those intrested.
R32 GTR tunning a HKS T04R with a 0.96 exh 18psi.
415kw at 4 wheels
Will be out at willowbank as soon as i can hunting to flog my current pb.
thanks
Michael
https://www.sau.com.au/forums/topic/93091-hks-t04r-dyno-results-400kw/
  • Replies 146
absolutely awesome
and to all the haters get bent. lol
it stays on boost between gear changes 5500-8000 is all i need.
hehehe
nah seriously, car doesnt get driven around town, i have a charade for that, this is for racing :)
yeah for sure, i was expetcing to need a little more boost for 400kw.
but im happy obviously.
it has the 0.96 exh side thats more top end etc.
for the track no cat (as on dyno) 4inch exhaust, 60mm hks gt wastegate, mani, strong motor with head work and mild cams.
it done many runs, all over 400kw once tuned etc.
mick
yeah defo
like i say on paper, it shows little mid range etc and doesnt look the best tbh.
but on the street when going hard it stays on boost so thats all that matters from my standpoint. keeps pulling through all gears.
really a 9k rev limit might help out as the turbo really looks like it wants to keep going hey...
michael
I thought I might have a bit of fun with this power graph using a couple of data logs that I have seen recently as a basis. What the following numbers do is simulate what it would look like if you have a video camera pointed at your tacho during a perfect run.
1st gear average power assuming 5,000 rpm held at launch
8,000 415 rwkw
7,500 410 rwkw
7,000 380 rwkw
6,500 340 rwkw
6,000 275 rwkw
5,500 200 rwkw
5,000 140 rwkw
Total 2,160 rwkw
Average 309 rwkw
1st to 2 gear average power assuming 2/10th second gearshift
8,000 415 rwkw
7,500 410 rwkw
7,000 380 rwkw
6,500 340 rwkw
6,000 275 rwkw
5,500 200 rwkw
5,000 140 rwkw
Total 2,160 rwkw
Average 309 rwkw
2nd to 3rd gear average power assuming 2/10th second gearshift
8,000 415 rwkw
7,500 410 rwkw
7,000 380 rwkw
6,500 340 rwkw
6,000 275 rwkw
5,500 200 rwkw
Total 2,020 rwkw
Average 337 rwkw
3rd to 4th gear average power assuming 2/10th second gearshift
7,500 410 rwkw
7,000 380 rwkw
6,500 340 rwkw
6,000 275 rwkw
Total 1,405 rwkw
Average 351 rwkw
Average of all 4 gears = 326 rwkw
If the above result is actualy achieved you are looking at an ET of ~10.6 seconds with a TS of ~210 kph. If you can speed up the gearshift by 50% you are looking at an ET of ~10.4 seconds.
It will be interesting to compare the actual results after you have had a couple of runs.
:angry: Cheers :P
PS; I have assumed standard R32GTR gearbox and diff ratios and a tyre circumference of 2,050 mm (ie; = 245/45/17).
Edited by Sydneykid
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
    • Legend. I ended up finding the facebook account of the owner of the first car i sent but sadly he deactivated the account. I think you’re right in saying it’s some sort of well done custom job. Really appreciate your help anyways.
    • Totally equivalent. Stock often goes from the comp cover because that's where the actuator is also installed and the factory needs 2" of hose to make the connection - and it comes as a pre-assembled unit. They totally have a boost reference from somewhere between the turbo and the throttle(s). Oh, jeez. Just do it in M12 then. We don't actually care that much. I would expect any such AN converter fitting to rely on an o-ring or some other seal onto a flat surface under the flange of the hex**, because bolt threads are no intended to provide a pressure seal. unlike..... pipe threads. **which also requires a suitably flat and smooth surface on the turbo's boss to provide the seal.
