i just thought i'd get someone to clarify this before i start hacking away on my power steering lines.
on a r32 gtst, looking at the hicas solenoid in the drivers side of the engine bay...
Line 1 goes from oil cooler to hicas solenoid.
Line 2 comes from bottom of engine bay into the hicas solenoid.
What is the best way to make the connection to line 2? there are no rubber hose sections that I can find, they are all metal screw fittings. Do I unscrew one of the fittings and just hacksaw the screw bit off? What's the best way to approach this?
From what I understood of what sydneykid posted, you can just hoseclamp the rubber hose onto both line 1 and line2, but i can't find where on line 2 that this can be done without hacksawing off one of the screw fittings.
You need to go further back along the pipework, towards the power steering pump.
>_< cheers :)
Gary,
There is a aluminium fitting (17mm bolt thingo) as shown in the diagram about 1cm from the bottom of the red line in the diagram (there is a bracket just above it, I'm currently trying to undo this bolt, but it's being a bitch). I'm assuming this is where we hook up the line. I was expecting to see a rubber hose (like the ones on line 1). How does the new rubber hose hook up to this line? do you need a special fitting, or can you just move back the 17mm bolt/thing and slip the rubber hose over the line?
Edited by MerlinTheHapyPig
Gary,
That's the wrong picture, the right one shows the connection further down the pipe work towards the subframe.
:yucky: Cheers :laugh:
Edited by Sydneykid
sweet, thanks for the help guys.
I just cut the damn thing in the end. All works fine now (though steering pump made a nice grinding noise when i turned it on, but i turned the wheel a few times and it went away)
I'm having issues removing the tie rods from the rack, if i turn one, the other side turns, i think i'll just remove the rack with the rods attached. Anyway that's something for tomorrow. I better get this working! drift practice at winton on saturday!
I had the same problem. Mine was on a hoist, so i got 2 bits of pipe to fit over my spanners to get some more leaverage. Then you start undoing one of the tierod ends. Inbetween the tierod end and the big black HICAS bar you will see a smaller silver rod, that rod has 2 sides flattened. Undo the tierod end just enough so you can fit a spaner in there (onto the flattened sides), but leaving the tierod end still on (otherwise the spanner will keep falling off and round the grip off), find someone/somthing to hold that spanner in place. Then you can uncrack the other end.
loktite is great untill you have to undo someting.
It took me ~30mins to do the removing and replacing of the bar, and 3-4 hours trying to undo those stupid tierod ends.
Edited by sav man
still struggling with the tie rod end....
I have one end off, and the other end i can't crack, because when i turn it with the shifter, it turns the thing on the opposite end. Can't get a good grip on the flattened sides of the rack.....
thats why you need boah ends on, cause the loose end keeps the spanner from slipping. you probably need somthing narrower than a shifter, I used a 17mm open-ended spanner.
Edited by sav man
yeah, all done! fark that was a pain
i ended up taking off the rod end on the other side and once i had it out, i could get a good grip on both ends and it came eventually.
car is ready for tomorrow's drift practice at winton! now i might pack the car, then relax with a beer. 3am start tomorrow morning :)
Can I ask If anyone has encountered any P/S leaks at the new hose joint?
As all the factory hydralic lines have a sealing beed on the end of the pipe work to prevent leaks occuring but by cutting the pipe work it doesn't have this feature!
Pretty sure i have the tool to "squish" the pipe longitudinally but was curious wether any one had had any leakage?
i've been checking for leaks regularly, and drove on the track on the weekend. No leaks at all. Geoff's lock bar works a treat also i might add.
Just remember to get a wheel alignment, I knew my alignment was out by a fair bit before i put the lock bar, i think i slightly bent one of the tie rods removing the thing, and we did a rough alignment at the track on saturday (using a tape measure). It was running about 30mm toe on the rear, we fixed that up.... was alot better after that!!
  • 3 weeks later...
ok, so ive been wonderin about lockin hicas on my gts-t with shims like the tomei kit supplies
what size shim do you need?
are lock bars really that much lighter than the old rack?
and after the rack is locked up im assuming you can take all the lines etc off it?
    • Gday Thought it was about time I started a build thread! As expected this project has snowballed into a huge financial liability, but unless you’re strong willed and responsible, it’s not a surprise. Background -  My first turbo car was an R32 GTS-4, got my full license and then totalled my Au Falcon a week later, so while trying to sell my RMZ450 dirtbike to buy another car a bloke offered to swap the R32 which at the time I felt like I was ripped off but looking back and seeing prices of those now ($40kish) it was a good deal, I didn’t know enough about these cars to appreciate what I had so sold it before the RB20 blew up. Between here and there, out of 12 cars I’ve owned the note worthy ones are a V8 Lexus SC400 (soarer), a couple of XR6 Turbos and my beloved S15 which I had for about 3 years, picked it up for $12500, repairable write off but she was fine, gun metal grey/pewter and bone stock/unmolested until I got my hands on it. Ended up spending about the value of the car and 280kw, 2 demerit points by the time I got defected and sold it for $14500 (also $40kish in today’s market, rip) Fast forward to the present day, I’m in a much better position financially and daily an MQ Triton (great cars, pipe down Ranger Bois), I cruised marketplace and car sales for a few months looking for another R32, the best deal I could find was an absolute rust bucket half finished project for $12000, until this R33 popped up in Port Macquarie for $18k - unregistered and barely running but decent shape, kept an eye on it for a few weeks and the price steadily dropped, $16k then $15k then $14k, that was the point where I was like shit someone’s gonna snatch this up! It was owned by a young bloke who had big plans but him and his missus just had a baby so smartest move financially for them but big gain for me. So 2 days later I’m towing a car trailer to pick this thing up. Roughly 2 weeks and $3500 later I’m cruising around Newcastle in my beat up R33 all smiles and dose noises! It only needed some basic shit to get it going, coil packs and air flow meter, electrical stuff and all fluids changed, 158k kms and running pretty good, nice smooth engine after oil and coolant flush - when I say coolant I mean it had been filled up with tap water, every gallery and heater element was filled with rust, 8-9 flushes later and still had brown liquid coming out but she’ll be right. The car was painted R34 Bayside Blue at some point but whether it was a cheap job or just not looked after is anyone’s guess, clear coat flaking like sausage roll.  Was rethinking my choices and contemplating life, had it up for sale for $22k - still cheaper than any registered R33 but got little interest, next minute I had an opportunity at work - 6 months overseas for good money, so that was a no brainer, fast forward again and here we are with a 50% finished project. Current Mods - 200ish KW according to butt dyno Was tuned with Apexi PowerFC EBC (old school Greddy Profec)  Stock turbo (more shaft play than a Tinder date gone right) 3inch turbo back Varex muffler  Aftermarket injectors of mystery size, Power FC showed 36% duty cycle at full boost so not behd good size Someone had good intentions but stuck with the stock R33 MAF so we had misfires at 6000rpm due to the MAF hitting 5.2V So far I’ve redone the entire interior with carpet form Car Mats Direct, new Seats and steering wheel from Autotechnica, also sound system by Autobarn (mainly Kicker) Also MCA pro comfort coil overs - Hands down best purchase yet, worlds of improvement over the tired 30yrold shocks Goals - 450kw/600hp on flex tune New paint job - Midnight Purple 2 Engine is at the shop getting rebuilt with forged rods a pistons, new valves and springs, ATI Harmonic balancer, Aeroflow 7.5L sump, rear head drain and oil restrictors as per oil control thread* and cam covers modded for larger breathers, other stuff I can’t recall of the top of my head Parts purchased and to be installed once the engine is done -  Engine loom from Wiring Specialties including these options: Haltech Nexus S3 R35 Coil pack conversion  PRP Dual Trigger kit Fan controller  Other Parts -  262 Kelford Cams Turbo - Hypergear ATR43SS3-ProS with T51R mod (whistly boi) 6 boost manifold (high mount) 50mm Turbosmart Pro gate (plumbed back for legal reasons) HKS Super Turbo Exhaust with High Flow Cat Custom 3.5inch dump and front pipe 1500cc Bosch injectors  Fuel Pump walbro 525 Haltech MAP and IAT sensors Haltech Flex Sensor Fenix Radiator with dual thermo fans LS1 Alternator Kit Oil Filter Relocation from EFI solutions and Cooling pro oil cooler Many other things sitting in my garage waiting for that engine to come back. Progress pics to follow -
    • Losses have to be less with DC coupling. Provided the battery inverter has decent MPP tracking ability - which really shouldn't be a problem. It's not 2005 any more.
    • Hi, Will the R33 GTR rear brake backing plates fit a GTST? I'm struggling to find GTST ones but can find new GTR ones.   Thanks.
    • I also got the same floor mats for a bit of extra bazzaz haha
    • Some more close up pics now that I’m back to working on the car, the loop pile is nice but again haven’t compared it to the other types in person, it’s hard to tell from the pics on the website. View of the hemming on the edges too, it comes in 2 pieces - front and back, honestly very happy with it for anyone on the fence.  Also attached my previous pics from further up as it didn’t let me post them directly before. (Nothing worse than photo bucket pics that aren’t hosted anymore years later)
