i just thought i'd get someone to clarify this before i start hacking away on my power steering lines.
on a r32 gtst, looking at the hicas solenoid in the drivers side of the engine bay...
Line 1 goes from oil cooler to hicas solenoid.
Line 2 comes from bottom of engine bay into the hicas solenoid.
What is the best way to make the connection to line 2? there are no rubber hose sections that I can find, they are all metal screw fittings. Do I unscrew one of the fittings and just hacksaw the screw bit off? What's the best way to approach this?
From what I understood of what sydneykid posted, you can just hoseclamp the rubber hose onto both line 1 and line2, but i can't find where on line 2 that this can be done without hacksawing off one of the screw fittings.
You need to go further back along the pipework, towards the power steering pump.
>_< cheers :)
Gary,
There is a aluminium fitting (17mm bolt thingo) as shown in the diagram about 1cm from the bottom of the red line in the diagram (there is a bracket just above it, I'm currently trying to undo this bolt, but it's being a bitch). I'm assuming this is where we hook up the line. I was expecting to see a rubber hose (like the ones on line 1). How does the new rubber hose hook up to this line? do you need a special fitting, or can you just move back the 17mm bolt/thing and slip the rubber hose over the line?
Edited by MerlinTheHapyPig
Gary,
That's the wrong picture, the right one shows the connection further down the pipe work towards the subframe.
:yucky: Cheers :laugh:
Edited by Sydneykid
sweet, thanks for the help guys.
I just cut the damn thing in the end. All works fine now (though steering pump made a nice grinding noise when i turned it on, but i turned the wheel a few times and it went away)
I'm having issues removing the tie rods from the rack, if i turn one, the other side turns, i think i'll just remove the rack with the rods attached. Anyway that's something for tomorrow. I better get this working! drift practice at winton on saturday!
I had the same problem. Mine was on a hoist, so i got 2 bits of pipe to fit over my spanners to get some more leaverage. Then you start undoing one of the tierod ends. Inbetween the tierod end and the big black HICAS bar you will see a smaller silver rod, that rod has 2 sides flattened. Undo the tierod end just enough so you can fit a spaner in there (onto the flattened sides), but leaving the tierod end still on (otherwise the spanner will keep falling off and round the grip off), find someone/somthing to hold that spanner in place. Then you can uncrack the other end.
loktite is great untill you have to undo someting.
It took me ~30mins to do the removing and replacing of the bar, and 3-4 hours trying to undo those stupid tierod ends.
Edited by sav man
still struggling with the tie rod end....
I have one end off, and the other end i can't crack, because when i turn it with the shifter, it turns the thing on the opposite end. Can't get a good grip on the flattened sides of the rack.....
thats why you need boah ends on, cause the loose end keeps the spanner from slipping. you probably need somthing narrower than a shifter, I used a 17mm open-ended spanner.
Edited by sav man
yeah, all done! fark that was a pain
i ended up taking off the rod end on the other side and once i had it out, i could get a good grip on both ends and it came eventually.
car is ready for tomorrow's drift practice at winton! now i might pack the car, then relax with a beer. 3am start tomorrow morning :)
Can I ask If anyone has encountered any P/S leaks at the new hose joint?
As all the factory hydralic lines have a sealing beed on the end of the pipe work to prevent leaks occuring but by cutting the pipe work it doesn't have this feature!
Pretty sure i have the tool to "squish" the pipe longitudinally but was curious wether any one had had any leakage?
i've been checking for leaks regularly, and drove on the track on the weekend. No leaks at all. Geoff's lock bar works a treat also i might add.
Just remember to get a wheel alignment, I knew my alignment was out by a fair bit before i put the lock bar, i think i slightly bent one of the tie rods removing the thing, and we did a rough alignment at the track on saturday (using a tape measure). It was running about 30mm toe on the rear, we fixed that up.... was alot better after that!!
  • 3 weeks later...
ok, so ive been wonderin about lockin hicas on my gts-t with shims like the tomei kit supplies
what size shim do you need?
are lock bars really that much lighter than the old rack?
and after the rack is locked up im assuming you can take all the lines etc off it?
    • Lock me in mate, although I'm not sure if I'll be heading up from Goulburn or down from Sydney, either way, return will be back to Goulburn
    • Sounds good, we will aim to be there! @The Bogan I'll give you a shout if you are heading up to campbelltown for the meet too.
    • Before I get to the test day, just to finish off the android head unit. This is a demo from car start up....the standard/host system takes a few seconds to boot (same as all v37) but Android comes up quickly. In this vid I'm using the delivered launcher but have set the default to Agami since which is easier to navigate when if use primarily 5 apps. You can see the host system still takes over when required eg putting it in reverse, and you can switch between Android and not by holding the back button 3 sec. It is pretty responsive (fast) but you can see I had to press harder than expected a couple of times.  I still have the phone connected to the stock system, and that also seamlessly takes over Android music playing. v37-android-demo.mp4 The bigger reason that I put this in though is so that I can use Ecutek directly on the head unit. That gives me a dash with logging (up to 20MB only), high and low value warnings on any parameter etc etc. I've run a USB cable from the Ecutek OBD dongle to a USB input on the unit, easy. v37-ecutek-demo.mp4   The unit did freeze on the launcher the other day, I think Agami was trying to verify the license when it didn't have a data connection...will monitor and report back if there are any other problems but so far I'm very happy with the upgrade.
    • Nah that is just crappy GPS mapping, I did have a small excursion (cold tyres, damp track, surprise!), will post up that when I get a chance.
    • So 10/10 times that code is coil packs? I mean if that's the case ill drop the $400USD or so to replace them. I didn't know these cars threw codes before the issue became an issue.
