I had a Gates installed on Thursday. Today I noticed an annoying amount of noise, so I thought I would look on the forum to see if it's common.
"i have heard of people complaining that the gates belts are quite noisy... "
Well, there you go... :(
Edited by clayoth
word up, i agree stocker oem item should be fine, brand prolly doesnt mean. to have timing belt changed is usually around $450 in labour. as have you basically pull heaps of crap out of the way to get it done
Hi, just wondering what sort of noise people are hearing with Gates belts?
I had a nissan belt on my R32(when Nissan were about the only choice available here) and it was quiet, the only noise that came from area was the squeak/whirring sound from the worn out tensioner bearing before I replaced it. I have a Gates on my R31 and it makes no noise.
Gates have made good quality belts for a very long time, my old man always used them on the engines he rebuilt. Possibly some of the noise being heard now could be tensioner bearings. The only other ways a belt can make a noise is if the teeth on it are slightly different profile(i.e. gears worn or belt profile not matching) to that on the cam/crank gears or its rubbing on the guard because it isn't dentralised on the gears.
I seriously doubt that Nissan or HKS make its own belts so they will be coming from a parts supplier like Gates anyway.
The noise I have is a whirring noise. After listening to it again tonight, I think you might be on the money with tooth profile or something similar. I have a Gates belt and new OS Giken gears. Perhaps you wouldn't get the noise with the original gears???
    • Hi Guys, Does anyone know any aftermarket part numbers for a starter motor to suit the VQ25DET? I can find lots of alternative part number for the VQ35DE, which I assume would fit, but there is a lot of conflicting information out there. Thanks..
    • I don't understand how this hasn't boiled down to - Upgrade the turbo when you have everything required. ECU, injectors, fuel pump, turbo, etc. Do it all at once.  If you don't have everything required, just enjoy the car as it is and keep saving up your pennies.
    • Sounds like you've got an interesting adventure ahead here with local support if you have trouble! My guess is that, unboosted, you will be OK with a small upgrade like -9. What will happen is that once the stock ECU sees more airflow than it expects it will add a heap of fuel and pull a heap of timing to be safe because it can't understand how it could get that much air without there being an issue. You will see clouds of black smoke and it won't pull hard through the midrange and top end. So, overall it will be a bit frustrating but should be OK. If you are still nervous set the base timing back 2o through the CAS, but it will be even more sluggish everywhere. As said above through...this is not my guarantee your engine won't be blown into a million pieces, leaving you looking for very hard to find parts A better idea is get a computer with logging ASAP, wire in a wide band O2 sensor and a use remote tuner. I've done multiple cars this way and while it is not as good as a specific tune on a dyno they can get it 90% right. I'd suggest if you can afford an R33 GTR these days you can afford an ECU and tune. And if you can't afford that you sure won't be able to afford the rebuild if it goes bad in the meantime,.
    • Yeah it would be nice if someone took the time to put that sort of information together, but there are a lot of variations in looms. I think you are making this way hard for yourself if you just want to get it running....sourcing an SR20 with the right wiring will be a billion times easier than matching the RB loom to an S15 chassis. If you do end up going this way, you just need to trace every wire in the loom with a multimeter, 95% of them will go to a location you can confirm at the ECU.....and then post it up for the next person who needs it
    • Just top it up with water, and keep a general idea of how much you added. It is normal for water to be pushed into and pulled out of the reservoir through the cap, and it should not be more than half full or it will be likely to overflow when hot. Any decent mechanic can do a pressure test of the cooling system to confirm if you have a leak. Keep in mind if it is only leaking a little and when hot it may well evaporate before you see it hit the ground
