Apparently its illegal to install a gear knob if it does not have on it a gear pattern indicator on it eg
1 3 5
|-|-| :mellow:
2 4 R
does anyone know were u can get stickers or indicators to place near the gear stick like on the ashtray, as sti's have (i think). I was told nismo gear sticks come with it, but can u get it seperatey or from another place?
https://www.sau.com.au/forums/topic/93834-gear-shift-sticker/
Haha, well the H pattern was faded on my GTR (that was before I bought my shiney new silver RAZO shifter :mellow:)
I got a RAZO H Pattern sticker with the shifter, heres a pic of the H pattern (couldn't be bothered fitting the actual shifter yet back then, lol in case you're wondering where the Razo shifter is)
If you want you can buy the shifter/h pattern off ebay.
Also, guys that make decals/windscreen stickers usually have H patterns.
If you're cheap, you can make your own crummy looking one as well. LoL.
Edited by IOWNU
I have asked an engineer this question as i also thought this was the case but he said there is no ADR that requires a car with a manual transmission to have a H pattern or sticker on or near the gear stick only Autos require the markings D etc along the side.
I do believe that if you don't have an H pattern on your manual gear stick - you do need one located nearby - this is probably a safety thing as well.. maybe in case someone needs to drive your car?? bit strange - but could be like the turbo timer law's...
either 1) make one with a post-it note or 2) i'd suggest getting one printed at a sticker place..
If you need H pattern diagram to know how to drive a manual car should you really even be attempting to drive a manual car?? Shouldn't that be more the point??? Last time i checked the gears in a manual car are always the same way......
plenty of cars have different shift patterns. some cars i have driven have reverse up where first would be (although you have to push the stick down and shift up for reverse to engage), and also remember some cars have only 4spd or 6spd gearboxes.
i got the shift pattern stickers with my nismo knob, stuck the appropriate one on near the ashtray, still have a spare 6 speed sticker left over.
Thank you.
When I was getting my car engineered the guy laughed and said it's the biggest urban myth. People just tell someone else and so on and so forth.. kinda like this thread.
    • Ok so after much research and talking with knowledgeable people I've got my turbo conversion done and it's all running great other than 1 small issue.  Car has remained auto with the na auto and tcm, I've used a stagea ecu with. NIstune board and everything is great other than my gear selection on the dash. It illuminates park, reverse, neutral, 3rd and 2nd. But nothing drive or what gear your in when you pop it into tiptronic.  I'm sure there is may e 1 wire in the ecu plug I need to move to rectify this. Dose anyone here have any ideas?   Cheers guys
    • Sorry I haven't been following all the detail, so you may have tried this. Does it idle with the tiniest bit of throttle you can add? You've mentioned the IACV, does it have an AAC valve and have you adjusted it at all (ie, screw the idle adjust screw all the way in, then back it out a couple of turns until idle is stable)?
    • My bad, I unplugged the one underlined in red instead of yellow before. With the car started, after unplugging the IACV (the one underlined in yellow), it idled at around 400/500 for 3 seconds before stalling. Attempting to start the car without the IACV will not start the car.   It does stutter and sputter for around 5 seconds before dying. However, immediately after starting it, you can already hear some slight sputters from the exhaust.   It won't start with the AFM unplugged. If it is when the car has already started, it stalls in a few seconds.   Yesterday, I did take some logs using Nistune of 3 scenarios. Car idling till it stalls Car idling and unplugging the IACV Car idling and removing the AFM I also have some previous logs of when the Car is idling till it stalls and when driving and it cuts. I am not really knowledgeable enough to understand what to look for. After every test, car idles rougher and rougher, until I have to stop. It will be fine the day after.
    • There is no difference between a 17x8 and an 18x8. The total diameter of the tyre needs to remain +/- the same (so you don't mess up the gearing, speedo reading, and clearance when turning front wheels..... so you just need to use a lower profile tyre on th 18 than you do on the 17. /rocket surgery.
    • I thought the same to start with. But then I thought it was one of those LCAs where the end of the ARB goes through a bushing in the LCA itself, instead of having an end link.
