Apparently its illegal to install a gear knob if it does not have on it a gear pattern indicator on it eg
1 3 5
|-|-| :mellow:
2 4 R
does anyone know were u can get stickers or indicators to place near the gear stick like on the ashtray, as sti's have (i think). I was told nismo gear sticks come with it, but can u get it seperatey or from another place?
https://www.sau.com.au/forums/topic/93834-gear-shift-sticker/
Haha, well the H pattern was faded on my GTR (that was before I bought my shiney new silver RAZO shifter :mellow:)
I got a RAZO H Pattern sticker with the shifter, heres a pic of the H pattern (couldn't be bothered fitting the actual shifter yet back then, lol in case you're wondering where the Razo shifter is)
If you want you can buy the shifter/h pattern off ebay.
Also, guys that make decals/windscreen stickers usually have H patterns.
If you're cheap, you can make your own crummy looking one as well. LoL.
Edited by IOWNU
I have asked an engineer this question as i also thought this was the case but he said there is no ADR that requires a car with a manual transmission to have a H pattern or sticker on or near the gear stick only Autos require the markings D etc along the side.
I do believe that if you don't have an H pattern on your manual gear stick - you do need one located nearby - this is probably a safety thing as well.. maybe in case someone needs to drive your car?? bit strange - but could be like the turbo timer law's...
either 1) make one with a post-it note or 2) i'd suggest getting one printed at a sticker place..
If you need H pattern diagram to know how to drive a manual car should you really even be attempting to drive a manual car?? Shouldn't that be more the point??? Last time i checked the gears in a manual car are always the same way......
plenty of cars have different shift patterns. some cars i have driven have reverse up where first would be (although you have to push the stick down and shift up for reverse to engage), and also remember some cars have only 4spd or 6spd gearboxes.
i got the shift pattern stickers with my nismo knob, stuck the appropriate one on near the ashtray, still have a spare 6 speed sticker left over.
Thank you.
When I was getting my car engineered the guy laughed and said it's the biggest urban myth. People just tell someone else and so on and so forth.. kinda like this thread.
    • Skyline R33 Series 2 sedan tail lights in excellent condition. These are becoming harder to find, especially in this state.    BOTH SETS ARE IN FANTASTIC CONDITION (REFER TO PHOTOS)    ✅ No broken covers or cracks ✅ Lenses are in flawless condition ✅ All rear mounting lugs intact ✅ Comes complete as pictured ✅ Perfect for restoration, replacement, or upgrade   These lights are ready to go, no surprises just quality OEM parts.   These are definitely one of the better sets we have seen in a while. With minimal wear and tear they will come as you see. Bear in mind they are not brand new they are almost 30 years old now. To find them in this condition isn’t easy they can only be obtained on the second hand market.   Australia Wide Postage Available At Buyers Expense. Silver Set:$850 Grey Set:$850 PM Me for purchase or any other questions  IMG_2166.dng IMG_2165.dng IMG_2172.dng IMG_2173.dng IMG_2174.dng IMG_2179.dng IMG_2180.dng IMG_2260.dng IMG_2258.dng IMG_2259.dng IMG_2261.dng IMG_2266.dng IMG_2273.dng IMG_2274.dng IMG_2276.dng
    • Unsolicited advice? Keep the engine as close to stock as you can. Nothing wrong with adding some boost and making a little more power, but given where you are, you really don't want to try to make it into a monster. I can't imagine the roads are up to it, and the lack of locla support when it grenades will be a ball ache. FWIW, If there is a dyno around that you can access, then brand new injectors are a good idea, which will lead you to (at least) putting a Nistune in it, which will allow you to put an R35 AFM on it, all of which will make it possible to make it much much nicer to drive and live with.
    • List all of your mods. It sounds like an aftermarket ECU hitting rev limiter. Like a valet mode, or a cold rpm limiter?
    • @Kapr Haha yeah thats the one. I missed that you had a built up engine, I wouldn't want to run it on there either then. It was good in my situation just to replace the original turbo on a stock engine. @MBS206Yep definitely not a replacement for anything name brand
