  • Replies 41
Id say its a good thing to do while the heads off.
Remember boost is a measurement of restriction of airflow. Anything that helps the motor breathe better is good imho.
You will get better power out of it for the same boost that you had before....
On a side note, the guys who did mine and Cubes did it for roughly $200 ish...anymore spent wasnt worth the $ to power gain....
https://www.sau.com.au/forums/topic/94018-port-and-polish/#findComment-1698640
As you guys were saying, porting isn't really necessary or needed at mild modding.
But, wouldn't polishing the combustion chamber be a nice measure to help control Knock if and when he plans on upping the boost?
I bet that would be rather inexpensive to just polish without porting.
https://www.sau.com.au/forums/topic/94018-port-and-polish/#findComment-1699787
I agree with RB240av and clayoth
better flow = more power, more efficiently (free kilowatts so to speak)
the amount of power an engine can develop is dependent on the mass of air it can breathe per unit of time – a simple mathematical fact of life for an engine builder.
I have seen (or read about) up to 30% gains when porting the RB25 head, and I'd think it would be worth while no matter what the boost level (IMHO)
Modern heads may be good - but they are still mass manufactured and include castings and dags.
At a minimum you should look at port matching, a polish up of the combustion chambers (for a cleaner burn) and a polish up of the inlet and exhaust valve bowls. Keep in mind you may also need to replace valve seats and seam seals at the same time (if you are not doing so already)
get it tidied up - you know you should ;)
https://www.sau.com.au/forums/topic/94018-port-and-polish/#findComment-1703742
yeah I don't see the point at mr crusts level of modification... unless bigger turbo and fuel system are waiting in the wings... even then I would be looking at cams instead... however it all changes if the head is stuffed and needs a recondition or you plan on running sky high revlimits
in a GTR its a different story
https://www.sau.com.au/forums/topic/94018-port-and-polish/#findComment-1703835
Its not really free kilowatts at all. Same could be said by adding 1-2psi in, doesnt "cost" you anything.
With a better flowing head, itll make same power @ less boost, potentially...
But if you want to make more power you need to screw more in anyway.
On a stock turbo your limited to the boost you can run, so there is no benefit either way that can be justified. Even a mild 2530 upgrade or something to 220-240rwkw
I mean i ran a 100% stock head, flowed fine for the 270rwkw on 17psi outta the gt30, 330rwkw on some 104/24psi
I was on a budget then, and i couldnt justify the cost at all.
I didnt do cams for that reason either.
It was $1000+ that could be better much spent on a PowerFC/AFM/Fuel system IMO, and it was ;)
https://www.sau.com.au/forums/topic/94018-port-and-polish/#findComment-1703864
totally... I spent a grand on cams and there is no contest between the effect of that mod vs when the cooler went in... the cooler won hands down! but I kinda knew that would be the case;)
so yeah, save your money
https://www.sau.com.au/forums/topic/94018-port-and-polish/#findComment-1703900
My head has been ported and has a set of Tomei cams. Was advised NOT to polish the head, something to do with the fuel spray, this came from the porter.
Unlike those that have not experienced the benefits of porting and cams, but still like to talk it down, i can not speak highly enough of the benefits i have felt and gained.
BUT: As stated b4, this should be done after a turbo upgrade. Wether you decide on just a "hi-flow rb25/vg30 turbo" or go crazy with a "T78", gains can be had with porting and cams.
My "hi-flow rb25/vg30 turbo", with porting and cams is making 270rwkw@15psi, compared to Ash's GT30 making 270rwkw@17psi. I have also the added bonus of looking standard, as the turbo has the factory comp cover/housing and factory shields.
Once again: these should be one of your last power mods, but i beleive that they shouldn't be overlooked.
https://www.sau.com.au/forums/topic/94018-port-and-polish/#findComment-1704230
But you did all the mods at once, but hard to judge how good one thing is when you do a complete package of mods.
We made the same power (although would loved to have tested that same dyno to compare much more accurately) but i saved what... $1500? :D
More beer money for meeeeeeeeeeeeeeeeee :lol:
https://www.sau.com.au/forums/topic/94018-port-and-polish/#findComment-1704562
We made the same power (although would loved to have tested that same dyno to compare much more accurately) but i saved what... $1500?  :)
I too would have liked to see a same dyno, same day, comparison, As i believe that dyno charts aren't really worth much. Mind you my car is only fully tunned to run 255rwkw, as i never intended to run over this power, with a std bottom end. :D
Note: Little off track :blink:
Did you save that $1500?
What about the new ic piping, oil and water lines, most people require a new exhaust manifold (You were lucky and has the GTS-R manifold), maybe an ext. wastegate, etc. When you add all these up, just to acheive a similar figure, how much are you really saving, you'll probably find you are actually spending more :)
Lets not forget all the hidden costs:
- More boost=less reliablity
- EPA: You mods stuck out and were obvious, the officer will really have to know his stuff to pick up on my mods. B)
https://www.sau.com.au/forums/topic/94018-port-and-polish/#findComment-1705588
now now - lets settle it down girls
let's agree that port and polishing is a good thing - but only when it's justified, and I mean in terms of cost and desired performance
Let's also agree that to REALLY see the benefits - you need the other supporting mods, EG exhaust, dumps, AFMs CAMS and the list goes on
My opinion is that once these other mods ARE done - that you will see better results if the proper prep work has also been done
I also ggree - $1500 is a lot of beer (or scotch in my case :))
https://www.sau.com.au/forums/topic/94018-port-and-polish/#findComment-1705636
    • Drain it. I got official Matic D but you can get whatever is listed as Matic D compatible.
    • Thanks guys,  Yeah I should at least have them dynoed, at least then I know what I've got as a starting point.  The springs on these are hard as rocks. I vaguely remember Russman saying he was going to sell the shocks to me with the rocks fitted, as he was keeping the softer springs for his new setup.  I didn't click at the time but of course that was to let me know the shock/spring wouldn't be matched.  I also remember pricing up new springs around 2014-15, but, house, money etc. it never happened. So that was another reason to have them rebuilt. I have rebuilt the forks on many motorcycles so I think I could handle the seals on these easily enough, but getting the valving right would be a rabbit hole I cbf exploring.  Duncan, interesting to hear RP was tuning these back then. I might give them a call.  In the mean time I have been busy fitting sway bars. The Whiteline rear sway bar I purchased 15 years ago finally got fitted, along with the Whiteline front bar that showed up last week. Just waiting on new links for the front sway bar to finish that off.  And my spare set of advan AVS VS5's should be back from the powder coaters in a Pearl White finish sometime this week, with a set of Hankook RS4's lined up for fitting.  And then I just have all the suspension bushes to do. A comprehensive kit is on the way... Lots to do before the Ararat hill climb. Cheers guys 🍻
    • Nice car! I’m glad folks in the US have gotten past the FnF and are buying real cool cars like the 260RS I was with a bunch of mates in Portland about a year ago and spotted a green Stagea (just a regular 2.5T AWD) parked about 2 blocks away and they were like “a what?” So I made a bet with them for a round of beers and said “ok one of you run down there and tell me if the steering wheel is on the correct side” 5 mins later the American comes trudging back up the hill and goes “he’s right guys. Ok what beer do you want?”
    • Should replace OR drop the tank, give it's good clean. Might be worth replacing that entire fuel level/pump/cradle thing with this: https://frenchysperformancegarage.com/products/fpg-s13-180sx-r32gtst-single-pump-hanger-kit-billet-hat-6-v3-fpg-089?gQT=2
    • Thank you so much for the help
