Hey guys, i just replaced my standard rb20 injectors with gtr ones, had to take 35% off the overall fuel trim on the wolf 3d so it wouldnt blow clouds of black smoke, the af ratio on the apexi turbo timer reads 13-1 with a 4000rpm jab of the gas, dont no how acurate it is but. Would you just drive it nice and easy to the dyno or pay the $150 to put it on a tow truck, thanks.
https://www.sau.com.au/forums/topic/94068-drive-or-tow-it/
If it starts and runs, and seems to drive o/k, then driving it will not do any damage AT SMALL THROTTLE OPENINGS.
If it is dangerously out of tune, you will know because of the stalling, hesitations, missing, or jerkiness, and it will let you know something is desperately wrong. But even then it will not damage the motor unless you really thrash it.
It is like running out of petrol. The car coughs a bit and stops. You don't melt pistons, break rings, or burn valves just because you run out of petrol.
Take it real easy, and it will be fine.
https://www.sau.com.au/forums/topic/94068-drive-or-tow-it/#findComment-1699899
i would drive it
BUT - keep it off boost. I had to do the same sort of thing when i changed my afm's and injectors, amongst other things. Added enough fuel so it idled and ran, but i kept way off boost. God knows what would have happened with an untuned pfc, larger injectors and some boost
https://www.sau.com.au/forums/topic/94068-drive-or-tow-it/#findComment-1736317
thanks guys, as this was replied to again i thought id let you no that it drove fine. when the turbo started to spool it was blowing a bit of black smoke so i took a fraction more fuel out and just drove it nice and easy.
https://www.sau.com.au/forums/topic/94068-drive-or-tow-it/#findComment-1738111
    • Hi,  Just joined the forum so I could share my "fix" of this problem. Might be of use to someone. Had the same hunting at idle issue on my V36 with VQ35HR engine after swapping the engine because the original one got overheated.  While changing the engine I made the mistake of cleaning the throttle bodies and tried all the tricks i could find to do a throttle relearn with no luck. Gave in and took it to a shop and they couldn't sort it. Then took it to my local Nissan dealership and they couldn't get it to idle properly. They said I'd need to replace the throttle bodies and the ecu probably costing more than the car is worth. So I had the idea of replacing the carbon I cleaned out with a thin layer of super glue and it's back to normal idle now. Bit rough but saved the car from the wreckers 🤣
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
