Dear people,
I have conducted a search and found no info, so i need your oppinion.
I am currently building a meduim to high hp rb 30 /26.
I have assembled the bottom end and all good gear has been used .
BUT dam it i did not get the crank oil pump collar widend.
No one over here in WA does it any way.
I have just been informed that this was a crucial mistake and my N1 on the standard crank will not last 5 minutes , i tend to disagree.
Is it mainly in tired r32 rb26 engines that they let go ?
If this is the case what if i replace every , say x amount of km's.
Will this help or is it simply an hp issue.
Sometimes i wonder if some things i get told from tune shops are simply a "turnover factor " . Please enlighten me on this if you would not mind , are there any alternative measures i can take . some one mention a collar that can be bought or made .
Thanx
https://www.sau.com.au/forums/topic/94864-oil-pump-crank-collar-r32-rb26/
Dave has an RB30 bottom end but yes a new crank is the best.
far comment guys , only trouble is , the crank has been metalaxed ( spellings wrong ), balanced , journals opened etc etc.
fare comment guys , only trouble is , the crank has been metalaxed ( spellings wrong ), balanced , journals opened etc etc.
The external pump that you suggested Steve sounds viabel , need more info if you don't mind Steve.
Edited by exXU1
guy its a rb30 crank so he cant use a rb26 crank as the stoke would be wrong and the whole point of using the rb30 block is for the longer stroke.
Dave i think your only really opinion is to buy a jun collar and fit it to your crank Proengines stated it takes a couple of hours to fit. As you have treated the crank it would seem a wait to weld it up and regrind so best bet buy the jun collar.
pete
ps i would definitly address this weakness for what you are trying to do
Dave it should not be a problem and its easy to do for any machining shop, it shouldnt hurt your bottom end to drop the cradle and big ends take the crank out and get the collar fitted @ around $500 its a cheaper alternative to new rebuild!!!
If I need this done to my R32, and the engine is in the car. How much do you think it would cost to get done? Is it a complete engine removal to do? (I assume it is..)
This is all a bit of a worry. I have heard of stock oil pumps failing, needing this collar fitted, having to fit a Tomei oil restrictor and a baffled sump. Sounds like any R32 making 350-450 hp at the fly more or less needs to be pulled apart and these things done before you can be 'safe' yeah? Assuming you want to drive it at the 'occasional' track day?
I guess the question is - "how often do these things fail?"
Am I better off just driving it and only pulling it out after a failure?
Peter, Steve , Daniel,
thanks for your input. Welding the crank ( even with top crank specialist is not an option to me )
purchased a jun collar today and crank is out.
For those that have seen a problem with the smaller drive, has that been on a new oil pump, or on an old worn one?
I have looked at a couple of old pumps and they definately show wear from the smaller collar.....but how long until it would actually fail?
Does anyone have a first hand experience?
I have one here at the moment that is looking pretty close to letting go. I have some photos if you're interested. I also have some photos of the process of fitting a crank collar, I did one on an RB30 crank not long ago. It's a good couple of hours work to do but comes up really well. It does add up a bit though, the cost of the collar plus around $200 labour to fit it.
I would definately run the bigger drive, the early R32 one doesn't engage a lot of the pump gear.
    • Well GTSBoy, prepare yourself further. I did a track day with 1/2 a day prep on Friday, inpromptu. The good news is that I got home, and didn't drive the car into a wall. Everything seemed mostly okay. The car was even a little faster than it was last time. I also got to get some good datalog data too. I also noticed a tiny bit of knock which was (luckily?) recorded. All I know is the knock sensors got recalibrated.... and are notorious for false knock. So I don't know if they are too sensitive, not sensitive enough... or some other third option. But I reduced timing anyway. It wasn't every pull through the session either. Think along the lines of -1 degree of timing for say, three instances while at the top of 4th in a 20 minute all-hot-lap session. Unfortunately at the end of session 2... I noticed a little oil. I borrowed some jack stands and a jack and took a look under there, but as is often the case, messing around with it kinda half cleaned it up, it was not conclusive where it was coming from. I decided to give it another go and see how it was. The amount of oil was maybe one/two small drops. I did another 20 minute session and car went well, and I was just starting to get into it and not be terrified of driving on track. I pulled over and checked in the pits and saw this: This is where I called it, packed up and went home as I live ~20 min from the track with a VERY VERY CLOSE EYE on Oil Pressure on the way home. The volume wasn't much but you never know. I checked it today when I had my own space/tools/time to find out what was going on, wanted to clean it up, run the car and see if any of the fittings from around the oil filter were causing it. I have like.. 5 fittings there, so I suspected one was (hopefully?) the culprit. It became immediately apparent as soon as I looked around more closely. 795d266d-a034-4b8c-89c9-d83860f5d00a.mp4       This is the R34 GTT oil sender connected via an adapter to an oil cooler block I have installed which runs AN lines to my cooler (and back). There's also an oil temp sensor on top.  Just after that video, I attempted to unthread the sensor to see if it's loose/worn and it disintegrated in my hand. So yes. I am glad I noticed that oil because it would appear that complete and utter catastrophic engine failure was about 1 second of engine runtime away. I did try to drill the fitting out, and only succeeded in drilling the middle hole much larger and now there's a... smooth hole in there with what looks like a damn sleeve still incredibly tight in there. Not really sure how to proceed from here. My options: 1) Find someone who can remove the stuck fitting, and use a steel adapter so it won't fatigue? (Female BSPT for the R34 sender to 1/8NPT male - HARD to find). IF it isn't possible to remove - Buy a new block ($320) and have someone tap a new 1/8NPT in the top of it ($????) and hope the steel adapter works better. 2) Buy a new block and give up on the OEM pressure sender for the dash entirely, and use the supplied 1/8 NPT for the oil temp sender. Having the oil pressure read 0 in the dash with the warning lamp will give me a lot of anxiety driving around. I do have the actual GM sensor/sender working, but it needs OBD2 as a gauge. If I'm datalogging I don't actually have a readout of what the gauge is currently displaying. 3) Other? Find a new location for the OEM sender? Though I don't know of anywhere that will work. I also don't know if a steel adapter is actually functionally smart here. It's clearly leveraged itself through vibration of the motor and snapped in half. This doesn't seem like a setup a smart person would replicate given the weight of the OEM sender. Still pretty happy being lucky for once and seeing this at the absolute last moment before bye bye motor in a big way, even if an adapter is apparently 6 weeks+ delivery and I have no way to free the current stuck/potentially destroyed threads in the current oil block.
