The full Du Luck kit front, rear bar side skirts and rear boot spoiler is $3900 plus freight and duty and gst would be around $6000
Try http://www.takakaira.com/aerokits/aerokiti...emenu.asp?cat=4
The GP Sports i got a copy in Brisbane from ARES Speed for $1200 supply only
They have since closed their shop, so I am not sure if they are still operating, but they did have moulds
I only have 1 photo of my car at work, which does do the kit justice.
https://www.sau.com.au/forums/topic/94896-body-kits/page/2/#findComment-1716827
Hey isn't there a company in Queensland somewhere that does widebody kits for R33 Skylines that looks similar to the Kaikimoto one? I think they cost something massive though, cause you have to send your car to them; they won't supply the kit so you can get it fitted elsewhere. I'm a fan of the 400R kit, looks the goods I reckon. Not too over the top.
"There's very little meat in these gym mats!"
https://www.sau.com.au/forums/topic/94896-body-kits/page/2/#findComment-1717085
Just saw your post now. B)
https://www.sau.com.au/forums/topic/94896-body-kits/page/2/#findComment-1717653
i like any kits as long as it comprises of all parts - side skirts/rear and front bar and not one without the other if you know what i mean. in saying that, i love the 400R which is why i love the r33 so much. do luck sits in 2nd place.
https://www.sau.com.au/forums/topic/94896-body-kits/page/2/#findComment-1717745
    • Yep, the closest base tune available was for the GTT, I went with that and made all the logical changes I could find to convert it to Naturally Aspirated. It will rev fine in Neutral to redline but it will be cutting nearly 50% fuel the whole way.  If I let it tune the fuel map to start with that much less fuel it wont run right and has a hard time applying corrections.  These 50% cuts are with a fuel map already about half of what the GTT tune had.  I was having a whole lot of bogging when applying any throttle but seem to have fixed that for no load situations with very aggressive transient throttle settings. I made the corrections to my injectors with data I found for them online, FBCJC100 flowing 306cc.  I'll have to look to see if I can find the Cam section. I have the Bosch 4.9 from Haltech. My manifold pressure when watching it live is always in -5.9 psi/inHg
    • Hi My Tokico BM50 Brake master cylinder has a leak from the hole between the two outlets (M10x1) for brake pipes, I have attached a photo. Can anyone tell me what that hole is and what has failed to allow brake fluid to escape from it, I have looked on line and asked questions on UK forums but can not find the answer, if anyone can enlighten me I would be most grateful.
    • It will be a software setting. I don't believe many on here ever used AEM. And they're now a discontinued product,that's really hard to find any easy answers on. If it were Link or Haltech, someone would be able to just send you a ECU file though.
    • Yes sir am asking is there possible way from aem tuner from wiring pins
    • Have you checked cam to crank timing and confirmed balancer marks are correct?
