Gb: R33 Gts-t And Gtr And R34 Gtt Radiator Guides
Hey ppls.
As many of you may already know, I seem to be the Radiator guide king.
I've just drawn up the R33 GTR and R33 GTS-T Radiator guides to be made from Aircraft Grade 1.0mm Aluminum.
They will be of the same high quality as my R34 GTT guides and will cost pretty much the same.
I'm bending up the prototypes in the next week or so, but would like to get an idea of numbers of how many people would like them.
The price will be close enough to $80 + Freight, but the more people, the merrier.
SO, Who's in?
R33 GTS-T
2BNVS...........................berkeley nsw 2506..........................PAID
Dezz..............................Hoppers Crossing 3029, Vic.............PAID
bilbo117........................................................................
....Paying Monday
Dynamix
GTS-T V-Spec..........Balcatta, WA 6021.................................PAID
Mavric.....................Melbourne Pick Up.................................PAID
Trust33....................Address Received.................................PAID WITH ANODISING
ZXFIRE....................Sydney, 2170, N.S.W............................PAID
GTRgeoff.................Melbourne Pick Up.................................PAID
Greg.......................Melbourne Pick Up.................................PAID WITH ANODISING[/
Freeman..................Newcastle, 2287, N.S.W........................CONFIRMED
Babia......................Melbourne Pick Up.................................PAID
Sydneykid...............Sydney, NSW, 2234
Deceeve..................Mt.Pritchard, NSW , 2170......................CONFIRMED
wolverine................NSW..................................................PAID
Lordsnipe................West Perth, 6005, W.A.........................PAID
Alpine Stars.............Perth, 6000, W.A
(B1) MR_fanny.........Melbourne Pick Up...............................PAID
Trick x 2..................Hope Valley, SA, 5090.........................CONFIRMED
Total 22
R33 GTR
Cooper....................Morphett Vale SA 5162..........................PAID
Trick........................Hope Valley, SA, 5090...........................CONFIRMED
Total 2
R34 GTT
darn756
woldo......................Kings Park, 3021, VIC, standard Bar.............PAID
Mr Sniper911...........Loxton, 5333, S.A, STD Bar..........................PAID
GT25T.....................cabramatta, 2166, NSW, Nismo Bar..............PAID
kralster...................Victor Harbor, 5211, S.A STD Bar...............PAID
SKY 34.....................Cannington, 6107, W.A BOMEX Bar.............PAID WITH ANODISING
JapanDyno x 10..........Germany, Pick Up when in Aust
HLT4Eva...................Melbourne Pick Up.....................................PAID
Total 16
BASS OUT
  • Replies 520
id be in.... question though, how they normally come with the hole for the bonnet latch can u make one thats flush like no gaps for the latch since i dont have mine anyway?
ben...
Is there a thread or perhaps you can tell me yourself:
What are the benefits of such guides?
Is there a real-world difference?
Is there a quantitative performance increase (eg dyno/400m times)?
Edited by Wink
Okay,
What the air guide does is stops the air from going through your grill and up over the top of your radiator.
It forces air through the radiator and increases the cooling capacity of your radiator.
Also, it looks cool and gives you somewhere to put stickers.
Hey Bass.Do they sit good on aftermarket front bars.
My bar is aftermarket and the headlight is missing the plastic mounts that the stock grille usually sits on.And because of that there really is no place for the front of the deflector to sit.
Would it be easy to make a mount for one of these myself??
answers
They bolt onto the radiator support panel, so there's no real problem with aftermarket front bars.
My experience with the R34 GTT, is that the brs are very similar with only slight differnces between the stock and aftermarket bars.
Nothing a quick blast with an angle grinder or a hand file can't fix.
I have designs currently for R34 GTT with Nismo, stock and aftermarket front bars.
I have designs for R33 GTS-T and GTR
I have not yet got R32 or R31 bars.
These I will look at soon.
Oh, and you need to tell me what model of car you have and whether you have stock or aftermarket front bars.
So like, R33 GTS-T SII stock bar.
or R33 GTR series III stock bar.
Cheers
Pete
what are the differences between your product and the UAS one or are they equivalent?
also, if there is enough interest would you be interested in making a guide that goes the whole length of the engine bay? ie covers the tops of the headlights as well. i'll try and dig up a pic if you're not sure what i mean. it may be too much mucking around to make it though.
Thanks
Greg
Yep, they will be equivalent or better to the UAS. I'll make them as best I can.
Greg. I've thought about making the extended version, but doing it in Aluminum will be very trickey, and difficult/expensive to send. Making it from say FRP or Carbon Fibre isn't what I'm into. Although I know it can be done this way, I'm no expert in it.
There isn't much airflow benefit in doing it that way, but it sure looks good!!
BASS OUT
    • Oh, also, forgot to add these photos I believe.
    • Thought i'd update on this. I was able to get in contact with Craig Lieberman and later on Darryl Alison (owner of Kaizo Industries). Darryl was able to help me verify that my car was in fact one of theirs and is helping me find more info on mine !
