  • Replies 116
Hi Jonathan,
A/C was working fine according to condition report, but of course it has been de-gassed as per all recent imports so you'd need to do this. Ran the car for a short stint prior to commencing the wreck so there were no apparent problems.
you could call my mechanic ( David Griffiths from Griffiths Performance Autos) on 03 6278 8418 - he'll give you the run down on as much of this as he can.
can also get most of this stuff delivered pretty cheaply too.
cheers,
Jeremy
Have you got the turbo manifolds off the GTR, I am after the two actual manifolds and the pipe that joins the turbos to intercooler that has twin turbo written on it? please PM me as I dont allways get time to check back and stuff moves down so quickly on this forum :S
Sent PM about AVS and Manaray wheels...
Also, out of interest, they all fitted on a GTS-T?
hi mate, have you got pics of those r32 front bars? or a place where i can look at them :huh: . cheers andrew
PM sent guys
can you send me info also on the AVS 17 x 11 rims and tyres, ie are they off a 32gtr and what ofset are they. if i was to fit them on a std r32 gtr how far will they stick out? also where are they now? you stated some parts are in TAS,Mel and Bne.
Ronin, Not sure if I still have the badge. if so, I'll do it for the $30 you asked, will find out tomorrow.
GTR32 - sent PM. $120 delivered.
Jetman - sent reply to you.
Jaqule - can supply you with RB20DET unit, as well as bonnet and guards!!
and bump for new parts and price drops. cheers,
J
Hi All,
BOoStEr - please check your consignment at https://titrack.tollipec.com.au/Login.ASP?W...e&WCE=Login&WCU
your tracking number is 8279348618. eta to you Thurs.
gee04c - George. Your guard and ECU was picked up this afternoon. Will have consignment note PM'd to you tomorrow.
Ryno - Ooops. sorry mate. PM sent and goods will be picked up tomorrow. will advise of con note at the time.
my_gtr32 - Peter, calipers were bagged inside a car I'm freighting from Hobart to Melbourne ( they're well hidden, don't worry...). Will arrive thursday and I'll call you to deliver them then.
cheers,
Jeremy
    • I wanted to try and preserve the front bumper as long as possible, they're not cheap and are made to order in Japan. Taking inspiration from my previous K11 Micra build where I made an undertray for the Impul bumper, I did the same for this BN Sports bumper but a little slimmed down.  This time round I only made a 'skid plate' (if that's the correct wording/term) for just the bumper surface area, the Micra version covered the gap like an undertray. Starting off with a sheet of mild steel approx. 0.9mm thick 4ft x 2ft in size. I traced around the bumper, cut it out and cleaned the edges. Luckily I was able to get two halves from one piece of metal In the video I installed it as is, but I've since then I've removed it to spray and add a rubber edging trim. The rubber trim is suitable for 1-2mm and it's a really nice tight fit. The bolts had to be loosened due to the plates being too tight against the bumper, the trim wouldn't push on I used some stainless M6 flat headed bolts for a flusher finish (rather than hex heads poking down), I believe this style fastener is used for furniture too incase you struggle to source some. The corner's are a little wider, but this may be an advantage incase I get close to bumping it  The front grill got some attention, finally getting round to repairing it. Upon removal one fixing pulled itself out of the plastic frame, one side is M8 that fixes inside of the frame, where as the other side is M5. Not knowing I could get replacements, I cut down an M8 bolt, threaded it inside the frame along with a decent amount of JB Weld.  The mesh was replaced to match the bumper. One hole on the bonnet/hood had to be drilled out to 8mm to accommodate the new stud, once the glue had set it could be refitted. I think the reason the grill was double meshed was to hide the horn/bonnet latch (which makes sense) but I much prefer it matching the bumper Bumper refitted and it's looking much better IMO The Youtube video can be seen here: https://www.youtube.com/watch?v=bVZP35io9MA
    • The video for the servicing and fuel filter change can be seen here: https://www.youtube.com/watch?v=uLJ65pmQt44 One of the main jobs I wanted to do before the car officially went on the road, was to remove the awful looking blue silicone hoses. There's nothing wrong with having coloured silicone hoses, but I realise as I'm getting older I prefer monotone engine bays with a splash of colour on the engine cover(s). I cover this in a lot more detail in the Youtube video, so unfortunately there's limited photos of the process. The intercooler, upper radiator, boost vacuum and upper breather hoses were all changed to black silicone with mikalor clamps. The only blue left is a blanking cap at the back of the inlet manifold and the GReddy pulleys (which will be replaced for stock when the cambelt gets replaced) While the intercooler pipes were off I gave them a quick clean/polish too A before photo I do have a replacement air filter on its way. Fuse box covers were painted blue, they're now satin black Another job on the list while the bumper was off, is to add some mesh https://live.staticflickr.com/65535/54737966256_99b28bfa30_c.jpg[/img] I was hoping to use some thin wire to secure it, but it seems I've misplaced it and the wire I had was too thick to twist easily. I ended up using cable ties for the time being https://live.staticflickr.com/65535/54737131882_c2b7989dcc_c.jpg[/img] Was pleasant to see this https://live.staticflickr.com/65535/54737131627_8b2aab13b3_c.jpg[/img] The last thing to do was to fix the front grill and re-mesh that to match but I ran out of time The Youtube video can be seen here: https://www.youtube.com/watch?v=R4FsF6tgizE&t=23s
