Can Someone please direct me as to which section i need in the ADR rules for pod filters and Intercoolers?
I was defected for my pod last friday, although it is in a box. the cop also sent me a traffic infringement notice today for driving vehicle non standard. at the time i was defected he told me anything non standard is illegal including using non factory type tyres. obviously i knew this was b/s so contacted my solicitor straight after.
anyway please help this is already going to court!
This is the pod box.. the cop said it was as much of a defect as the pod itself as it was non standard.
Edited by MintR33
https://www.sau.com.au/forums/topic/96115-need-adr-rules-apap-please-help/
AFAIA the ADR's don't specifically cover pod filters or intercoolers, they are actually EPA issues to do with intake modifications effecting emissions. According to VicRoads, at least, pod filters are not an 'engineering issue.....refer the EPA'.
Suggest you contact engineers (not the desk drone) at your local rego authority (wherever you are) as well as the EPA.
The only way I see you can win your case is if you provide proof you have not exceeded emissions levels set by the ADR's your car is complied to. The reason is, you have modified the standard emissions system which is proven by the manufacturer to pass relevent emissions standards.
Seeing as this is an expensive test that you will have to incur the cost of, and pod filters are widely regarded not to offer significant power gains, I would just remove it.
The first page of a google search will show you the emissions composition for the relevant ADR standards here:
www.npi.gov.au/handbooks/aedmanuals/pubs/motorvehicles.pdf
Edited by drunkenmaster
I agree, cops usually enforce RTA regulations and not ADRs. Ask to speak to the engineers at RTA and they should set you straight about what's what. Keep a level head and they are usually easy to get along with. An infringement for non standard? Was it specific? Just about every car on the road is non standard in one way or another, try to find out the parameters they use to determine this. And WRITE DOWN EVERYTHING THAT YOU ARE TOLD BEING CAREFUL TO NOTE NAMES AND TIMES. Another source is tech help at the NRMA believe it or not, you'd be surprised at what these guys know.
Good luck
paul its a small town with a few cops (leeton, nsw)
he does have 2 live there n the cop will keep hounding him. if he gets the law on his side he can then write down times that he gets pulled over etc from this cop and put an harassment order on him. this makes the police in his town stay away from him for 6 months unless it is warranted. this has happened b4 to one of my mates who lives in vic.
Yes, thats pretty much the reason for it. this is by no means the first time i have been targetted for doing nothing more than driving a skyline in a place where V8's are the dominate species.
I'm sick of letting it slide because all that is happening now is they are taking advantage of me, thinking i am just going to give in each time.
Small town, and them pulling out the ADR one...
Out of interest, did you sleep with this said policemans daughter and get caught recently?
I think you will find he's pretty much spot on with the ADR thing. But you must have done something to really annoy them to pull that one on you.
I thought the air pod was more of an EPA noise issue than an EPA emissions issue.
Atleast that's what my engineer said - something about cops pulling bullshit about pods because it's linked to noise, but he also said the noise and pod logic only really applies to rotories because they are very loud through pods.
Either way good luck good on ya for goin to court.
first thing. is it engineered?
the reason pods are ilegal is. they dont offer the same flame traping properties as a sealed air box. and noise emissions i think.
(yes its not like a backfire is going to go all the way down 2 or so metres of plumbing and a turbo!)
to make it legal it has to be "out of site"that is what my engineere said for him to engineer it.
i think you may of got bent over by an ignorent cop.(there are plenty)
it usaly helps if you put your mechanics licence next to your licence in your wallet so they see it. no more gay defects after i did that!!
by the sounds of it you need to be armed with a enginereres cirt folder.
    • Take a couple of the big ones back to "work", leave them in the big bin.   Will make a good boom when the garbage truck emptys it out... I've heard from another source about the boom when they had put I believe it was a 4cylinder engine in the big bins at Richmond base...
    • That idea has crossed my mind, I do a 5km walk everyday, this does take me past some bushland......I think you may be onto something 😉  That, plus 1 rock on every bin night might do the trick, it may take a year, but it could save me a couple of grand The only issue is the big 'Boonies", I have a few that weigh around 30-40kg, maybe they should be the first to go into the raised garden bed,  and then let the next owner deal with them....my daughter gets the joint when I kick the bucket, mums the word mate......LOL Noice......
    • Wow. Did you call the car a Nissan Skyline?
    • You're retired Mark, on bin night, go for a walk, kind of like you're doing the beep test. Put one rock in the first neighbours, come back, get another rock, go to the second neighbours, repeat over many weeks. All rocks eventually gone...
    • No chop chop of anything mate, it is what it is, plus, I don't want any air that isn't either going through the cooling stack or intake getting into the engine compartment increasing under bonnet pressure  Yeah, the Mazda Speed aftermarket intake above is less than ideal for multiple reasons, the requirement to remove the bumper every time you need to service the filter, and also smaller in diameter than the NC1 OEM one Weirdly, Mazda Speed is part of the Mazda motorsport division, "form over function" and $$$$$ for Mazda from unsuspecting punters I suspect  After some googling about them it seems they added no power, but do increase some induction noise Meh In other news, the electricians have been busy today at the house, and are back tomorrow finishing up all the security stuff and exterior lighting, they also added some lighting on the garage ceiling, which will come in handy when working in the garage when it's not freezing out there My Birdies raised garden bed also arrived today as well, which I'll put together and place tomorrow, it's a big tall Bessie, 74cm high, 92cm wide and 214cm long, this will come in handy as I am starting to get "stockpiles" of good soils from doing landscaping, some of the clean rock, namely the river stone, will go into the bottom of the bed for drainage, as well as the old Apricot tree that was out the back,  and when it's full, I'll grab another one, I will be growing enough veggies to keep me both busy as well as supplementing the shopping list I'm also awaiting another quote for a new Colourbond front fence, as the "1980 style cemented in rock edging" that was there and "fashionable at the time" looked arse, and my god, the amount of cement used to fix the rock was insane, it took 1.5 days for me to break out 12 meters of the stuff by hand, trim the bushes back to the fence line and dump it out the back of the joint to deal with at a later date,I will soon need a skip bin to tip it all Unfortunately they did alot of the cemented in rock around the joint, which I hate, so a few pallets of retaining wall blocks for around the front and back where the cemented in rock is will be required to bring it up to a standard, and look, that I will be happy with 12 meters worth of rock and cement Finished smashing the fence line and ready for a fence to be installed, yes, the lawns need some TLC and thickness, the previous owner trimmed the grass to the roots 😢, the TLC I can provide, and nature over time will do the rest And there's probably about another 40 meters worth of this landscaping abomination left to do around the front and back gardens, I'm guessing maybe 3 or 4 tons worth, tip fees for this will be a killer Meh, all in all I'm having fun and keeping busy, plus, it's good PT
