Can Someone please direct me as to which section i need in the ADR rules for pod filters and Intercoolers?
I was defected for my pod last friday, although it is in a box. the cop also sent me a traffic infringement notice today for driving vehicle non standard. at the time i was defected he told me anything non standard is illegal including using non factory type tyres. obviously i knew this was b/s so contacted my solicitor straight after.
anyway please help this is already going to court!
This is the pod box.. the cop said it was as much of a defect as the pod itself as it was non standard.
Edited by MintR33
https://www.sau.com.au/forums/topic/96115-need-adr-rules-apap-please-help/
AFAIA the ADR's don't specifically cover pod filters or intercoolers, they are actually EPA issues to do with intake modifications effecting emissions. According to VicRoads, at least, pod filters are not an 'engineering issue.....refer the EPA'.
Suggest you contact engineers (not the desk drone) at your local rego authority (wherever you are) as well as the EPA.
The only way I see you can win your case is if you provide proof you have not exceeded emissions levels set by the ADR's your car is complied to. The reason is, you have modified the standard emissions system which is proven by the manufacturer to pass relevent emissions standards.
Seeing as this is an expensive test that you will have to incur the cost of, and pod filters are widely regarded not to offer significant power gains, I would just remove it.
The first page of a google search will show you the emissions composition for the relevant ADR standards here:
www.npi.gov.au/handbooks/aedmanuals/pubs/motorvehicles.pdf
Edited by drunkenmaster
I agree, cops usually enforce RTA regulations and not ADRs. Ask to speak to the engineers at RTA and they should set you straight about what's what. Keep a level head and they are usually easy to get along with. An infringement for non standard? Was it specific? Just about every car on the road is non standard in one way or another, try to find out the parameters they use to determine this. And WRITE DOWN EVERYTHING THAT YOU ARE TOLD BEING CAREFUL TO NOTE NAMES AND TIMES. Another source is tech help at the NRMA believe it or not, you'd be surprised at what these guys know.
Good luck
paul its a small town with a few cops (leeton, nsw)
he does have 2 live there n the cop will keep hounding him. if he gets the law on his side he can then write down times that he gets pulled over etc from this cop and put an harassment order on him. this makes the police in his town stay away from him for 6 months unless it is warranted. this has happened b4 to one of my mates who lives in vic.
Yes, thats pretty much the reason for it. this is by no means the first time i have been targetted for doing nothing more than driving a skyline in a place where V8's are the dominate species.
I'm sick of letting it slide because all that is happening now is they are taking advantage of me, thinking i am just going to give in each time.
Small town, and them pulling out the ADR one...
Out of interest, did you sleep with this said policemans daughter and get caught recently?
I think you will find he's pretty much spot on with the ADR thing. But you must have done something to really annoy them to pull that one on you.
I thought the air pod was more of an EPA noise issue than an EPA emissions issue.
Atleast that's what my engineer said - something about cops pulling bullshit about pods because it's linked to noise, but he also said the noise and pod logic only really applies to rotories because they are very loud through pods.
Either way good luck good on ya for goin to court.
first thing. is it engineered?
the reason pods are ilegal is. they dont offer the same flame traping properties as a sealed air box. and noise emissions i think.
(yes its not like a backfire is going to go all the way down 2 or so metres of plumbing and a turbo!)
to make it legal it has to be "out of site"that is what my engineere said for him to engineer it.
i think you may of got bent over by an ignorent cop.(there are plenty)
it usaly helps if you put your mechanics licence next to your licence in your wallet so they see it. no more gay defects after i did that!!
by the sounds of it you need to be armed with a enginereres cirt folder.
    • But seriously, can we ask for the results of the "tip a bottle of metho into a nearly empty tank" experiment?
    • Hang on. Let me get this straight. The desire is to have coilovers, BC in particular, to be MORE comfortable on Sydney roads than stock suspension? Well, that's obviously not right. BCs have crude damping design at the very best, and typically hard spring rates. BC stands for Billy Cart. And then, the desire is to put in some shitty old worn out stockers, to get it blue slipped and then put the BCs back in? And then.....what? Not worry about getting pulled up by the Plod? Because you seem to have raised a worry about paying for engineering (which actually does solve all your legality problems) and still getting pulled up.... but the only problem there is that if/when that happens you have to show your paperwork at the inspection station. Whereas, if you just swap in borrowed shitty old stockers to get it slipped now, and then you get defected in the future, you have to go find more shitty old stockers then too. You course of action looks like this set of options: Buy brand new stock type dampers, and springs. probably cost a bit more than $1k all up, but will last for the remaining life of the car. Put them in, pass inspection, drive on them forever more. Hell, they could even be really nice Bilsteins and Kings or other lower&stiffer springs if you wanted. Get the car engineered as is. ~$1k. Buy new Shockworks coilvers (or MCA) and also pay for engineering. You're spending a lot more here. But these will be the best things that you could drive around on.
    • Might be worthwhile hitting up Facebook's groups, I know most of them contain terrible people and scammers - however you might be able to find someone that's in Sydney with factory suspension you could purchase and/or hire. Just do not send any form of money anywhere, in person cash only.
    • Thanks @Duncan Ride height is fine. I think it's almost stock tbh. Happy to share a pic. I don't actually have a regular mechanic as haven't lived in Sydney too long. Could you or anyone recommend any shops in Sydney?
