Ok i dont own a gtr but logically hears my guess.
You have 2 intakes, going into 2 turbo's then merging into one pipe either before or after the fmic (never checked which).
So theoretically you could plug the stock vents and add a single one just before the throttle body ah-la rb25.
I'd assume that mixing bovs wouldnt be a good thing due to the fact that they might both respond in very different ways (ie flow totally different amounts, one plumbs back the other doesnt etc etc) for all i know, and that may have carry on consequences.
Anyone care to correct me or confirm this?
keep the stock ones fitted, been covered many times. no need to change
amen brother!
the factory got that part right, why go and mess with it, putting something else on and then putting a new thread up next week asking why your car runs like shit.
I recommend the Brotech Apoxi blow smart adaptor for GTR's this allows you to fit single BOV's in the GTR standard location and retails for only $20 at Autobarn.
I think there is a apoxi blow smart pro version now that has blue LED's on it too.
As this has been tried plenty of times and will be reitterated many more times, stick with the stockies.
Can't be beaten!!
I know Supra's that even change to the stock GTR BOVs coz their so good.
The fastest drag GTR in Vic and the fastest circuit GTR in Vic both use stock BOVs :)
WHy do you want to change them? no point to it unless you want that gay sneezing sound which you will get sick of in about a month. Have a search someone posted here recently he wanted a blow off valve so bad, he put one on and a month later he couldn't wait to get rid of it....
Leewah runns over 600rwkw with stock BOV's. Keep them.
Are you using a stock ECU?
I was was using it on the standard ECU without a problem and still using it with the Power FC.
Ferni: Reason for changing it? honesltly it was an impulse buy from one of my Japan trips :D
never had any trouble with my twin bitz sequential wank master pro valves on the GTR either. it idles fine, runs fine. not worries. it was runing before with a chipped ecu and then with the power FC. I probably would have kept the stock ones if i had them.
Or theres the OS Gaylord type FS-b (fully sick, bro) adaptor, Autobarn now has them for $10.
    • yeah first and reverse is where you will find clutch release issues (whether hydraulic or mechanical) because the difference in revs required is the highest there; particularly changing down from 2nd to 1st when still moving. To be clearer though, it is possible that the clutch release bearing is the wrong height. This is less likely than a hydraulic issue but it is not unheard of when you are mixing and matching
    • Quite right, if you make it to that pension you deserve every cent
    • Hi all, Restoring r33 series 1 rb25det. All the heater hoses were on their way out, have replaced them and put it all back together. After testing I noticed a small leak from behind the head on the actual metal water line to the turbo when cars warm. I tried running a longer hose over it but it kept leaking...   I am about to take the (stock) manifold off again😔 to change the water line does any one have any lines they recommend? I was looking at Aeroflow Turbo Oil & Water Line Set but not sure what everyone else recommends. Car is completely stock but want to upgrade turbo eventually. it looks like ill have to disconnect a lot just to replace these lines so if there's anything else recommended to do please let me know. Thank you in advance!
    • From memory, on the R33 GTSt at least, while everyone says "It's not adjustable", I found when I changed clutches in mine, it just needed a small adjustment on the rod length. But be very wary here, as you could end up trying to push the pushrod in the master too far, or blowing out the slave.   Most likely though, if the master/slave isn't bypassing internally or leaking out, then the throw out is the wrong height compared to the fingers on the clutch, so when it moves to disengage the clutch, it isn't 100% disengaged. You can check part of this out too by jacking the car up, having the engine running, put your foot on the clutch and try to engage 1st gear. If it goes in pretty easy (Compared to the ground) and/or the wheels start turning a fair bit and it takes a bit too much brake pedal to bring them back to a stop, this is likely the issue.  I'm not sure if you can adjust the height of the forks etc in these though, it's been that long since I've touched any RB gearbox.
    • That's all good, I thought I was missing some interesting feature! Maybe @PranK can double check if that is something that is meant to be operating or not.
