  • Replies 50
Posted Images
jason, just put an aftermarket front bar on it if you want to make it 'angry' so to speak. your car looks very nice as it is mate, love the height and well as how the wheels sets of the entire appearance of the car.
I'd have got a R33 if they weren't $30,000 when I got my R32
The $10,000 dollar differance was they clinching factor for me
I'd swap my 32 for a 33 any day, even with around 200rwkw, I like the feel of a R33, feels more solid and has that big car pressence on the road
R32's interior is dated now while R33 still looks pretty good
either one is going to cost you a shitload if you want to go quicker than stock
Reckon you shouldn't rule out the R33 GTS25T 4dr Sedan, it's a solid option as well. You might find one that comes close to your budget, there aren't as many around, they look great and go as well as anything else around.
Mine came with some wierd ass side skirts and a Nismo style rear spoiler but I'm personally not fussed about the S1 front bar. I actually think that it looks quite alright, even better with the centre section cut out to show off your FMIC (must get around to that one day). And the added bonus, no ground clearance problems like the bigger bars.
Tastefully lowered with a nice set of rims finishes them off nicely.
Plus they don't tend to attract as much of the "wrong" kind of attention!! :(
Good luck with your decision......but I don't reckon you'd be disappointed regardless of which model 'line you end up choosing.
:D
i have a s1, they are gay from the front but for the extra cash is it really woth it?, as it is pretty much the only difference between the two.
you can make it angry! :P
Main diff is the headlights n bonnet between the s1 n 2. but making a S1 look tough can be done by a vented bonnet n 400r front bar :)
Main diff is the headlights n bonnet between the s1 n 2. but making a S1 look tough can be done by a vented bonnet n 400r front bar :D
yer, maybe s2 vented bonnet s2 hedlights and s2 400r front bar!!
altho there is those eyelid things for s1 33... :D
and not to forged the boot lip.. :) i love them, need to get one. :D
Edited by DriftR_33
its an addiction, there are so many differenent things you can do to improve these cars!
I agree.
Drop RB30DETs in them with a nice set of 264cams, gt3540 .82, 3.5" exhaust and have 20-22psi by ~3500rpm, maybe a shade over.. :blink:
or.. If you really want it to rev its nuts off and make 400rwkw...
RB30DET, forged rods/pistons, ati balancer, 272 cams, gt3540 1.06, 4" exhaust and dial in hrmm maybe 26psi, that should be in by a 4000rpm or a shade over and rev nicely to 7.5-8k.
Nice to dream.
Edited by Cubes
    • The fab work can be as simple as a couple of silicon hoses and clamps to the factory piping.
    • Just sounds like either way you need to do some fab work to get everything to fit, so why limit yourself at that point? If the GCG high flow option is zero effort in and out swap though I'd probably do that. It's almost certainly lowest risk, lowest cost, etc. The HKS GTIII-RS option that Kapr mentioned is laughably expensive for what it is, they charge the exact same for two turbos on the RB26 so their margins are off the charts on that thing.
    • Intake manifold is not a part of the issue. The turbo bolts to the exhaust manifold. That is easy. But close your eyes and picture the physical situation. That is a T3 flange on the manifold and a T3 flange on the turbo. As long as any new turbo has a T3 flange on the exhaust housing, that exhaust housing will bolt to the exhaust manifold. This places the exhaust housing in the same place as the stock one. But now move your mental attention a little further forward. The location of the compressor housing is set by the length of the turbo's core. The stock turbo had a long core. Let's say that it is..... 100mm long. So that would place the compressor housing 100mm forward of the exhaust housing. But a highflow, might well have a centre core that is shorter. Let's say that it is only 70mm long. Now the compressor housing will be 30mm further back in the engine bay than the stock one. This DOES move the turbo's compressor outlet backwards. It also moves the compressor's inlet backwards. You will very likely have to do some work to both the inlet and outlet piping to make everything connect again. I am not say this to make it out to be a bigger deal than it is. I am just pointing out that "bolt on" is sometimes not quite bolt on. The highflow from GCG that Murray linked above (https://gcg.com.au/turbo-charger-upgrade-skyline-gtst-2iu-xtrgts-s1.html ) uses a core that is the same length as the stock core, and so does not require this extra work. It will look very much like the stock turbo. No-one uses GTR turbos of any flavour (stock, or aftermarket) in a single turbo application on RB20/25. It's not a thing. Yes, people have been putting on GT3076, GTX3076 (and bigger and smaller versions of those) and G30s (of various sizes) onto RB20/25 since forever. But these are not "bolt on". Everything except the 4 bolts to the exhaust manifold change with these. And genuine Garretts are expensive. Non-gen, like Pulsar, etc, are cheaper, variously as good or nearly as good. But still not bolt on. No-one in the right mind would pay for an HKS turbo. Not in this modern day and age. Well, yes, the GCG highflow. You could ask HG what he can do to make the compressor housing sit in the original location. There are surely others doing highflows around the world. And some of the eBay/Temu ones (as reported by Dose) work and don't die. Bit of a lottery though. I would send your turbo to GCG (here in Oz) to be highflowed if you want a trivial no-extra-work option. But seriously, the work required to change inlet and outlet piping is not that hard. That's a boost control problem, not a turbo problem.
    • Thank you all for the replys 🙂 I know that intake would be different but that is one pipe at it is not that hard to get(custom one). I meant mainly bolt to the stock manifold and the turbo elbow. I looked and many sites/forums but they are just "old" with some old HKS turbos from GT-R i guess? What about some Garrets?  Or any other turbo? Is there even a turbo which i can just bolt on? 😄 And yeah i know about that new HKS but that is like 2000k USD without taxes/shipping in here   Iam getting a touch up tune but my "problem" is that on the "not" hot day iam getting peaks around 0,9 bar...and when it was around 15 Celsious i saw peak around 1 bar which is just too much for stock turbo. And of course turbo is old and i like to get some new one for a piece of mind 🙂
    • I'm working on the assumption that our friend Jasmine here is a Russian (or, possibly Ukrainian) spammer/spambot, based purely on the number of such that I have been having to neuter in the last few weeks. IP address for the OP above was in WA. But that could have been via VPN. Posting at quarter to 4 in the morning is a good sign of being from somewhere in Europe. The last Jasmine that I kicked in the cooch was IP addressed in Ukraine. Even that could have been via VPN, and the bitchbot could have been from Russia, Serbia, China or anywhere. Regardless, was a spambot, so I killed it with fire. The fact that our new friend Jasmine here did not respond in any way to my tart query strongly suggests to me that this OP was just the establishment phase of a user able to be activated for spamming in a week, or 3 or 10.
