I've seen over 300rwkw from a stock bottom end R33 with GT-RS and cams.  There is a thread on it somewhere here.
can anyone link to this thread? i cant find it via search. OVER 300rwkw from a GTRS is a very big ask, i will believe it only when i see the dyno graph! Thats over 500hp at the engine from a 400ps rated turbo. even with a conservative rating thats still a big ask!
  • Replies 54
http://image-cache.skylinesaustralia.com/f...-1126786146.jpg
well i quess you have your dyno reasults and it was in fast fours as i said But with people on the forum only making 360-390rwkws with two on a gtr :(
Edited by blk180
So if I go to the GT-RS (more than likely) what should be considered while the turbo is being done ??
GT-RS turbo
Dump pipe (HKS Extension pipe)
Tomei Poncams (264s?)
Fuel Pump
Injectors (Blitz seem to be the only direct fits i can find)
Headgasket (Tomei 1.6/1.8mm)
Oil Cooler
Splitfire Coils
adjustable cam gears ?
Z32 afm ?
can't seem to think of anything else.
Edited by Binky1970
nope the 33 greddy plenum doesnt fit the neo......you either need an adapter plate which is almost impossible to get a hold of or drill new threads in the cylinder head to make the 33 one fit. The second option is not one I would like to take....so im still searching for that elusive adapter plate.
Correct on the Greddy plenum... I also investigated this and found the same information. The stock plenum works fine though up to about 600hp, it just doesn't look as cool as the greddy plenum :lol:
hahha your car will be right if you just run 0.6 bar of boost ie stock boost. I have been to wakie many times with my car and have never had a problem. But I have heard of reports of 34s running stock turbo and running 0.8 bar or more and blowing up their turbos.
lol then i must have some kind of freak turbo because mine sees 0.9 Bar every time i drive it, and it's been fine at that boost level for over 18months, with a few track days too B) New HKS GT series turbo coming soon though :D
O/T guys but you could rate the GT-RS (esentially badge engineered Garrett GT2871R 52T with T3 flange and Skyline specific dump pattern) as ~ 420Hp compressor and 330 Hp turbine side . That exhaust housing is only .64ARR so 300Kw of exhaust flow ?
That GCG Hi Flow would be very cost effective particularly as you already have the R34 Neo type exhaust housing , one out one in and no orphan bits needed . Will look dead stock and is rebuildable . How easy is that .
Cheers A .
Edited by discopotato03
you going for an internal gate or an external ?
I think the Plazmaman one might fit the 34s.....as it uses the standard runners.
Just need to find out of the runners are the same on 34s are they are for 33s.
You'll need to find out if its chrome coated too... after all A/M plenums are more cosmetic than performance based unless your making something over what a stock motor is going to handle
:D
480cc will be pushing it @ 300rwkw.
Get the Nismo 550. Bolt it and gives you the required head room
stock boost on a 34gtt is 0.8-0.9 bar. provided it isnt pinging :D
I was lead to beleive its 0.6 or 0.7 ?
I turn it up to 0.9 when I feel like giving it a hit...
R31Nismoid: AFAIK nismo dont have 550cc for 34s.
I think next step up will be 740cc which is a little bit overkill.
Stock boost is 0.5 bar.
I have also never heard of 550cc Nismo injectors for the R34.
Not that I've done the calculations but I think 480's might be a bit small for 300rwkw too.
Are you sure you've got the right GT-RS there discopotato? That doesn't seem right based on what we are seeing on the dynos.
Cheers  A .
I thought the 0.64 turbine was the GTR one and the GTST was 0.8'ish.
Based on what I have seen HKS compressors seem capable of around 10% more than their rated capacity. So my feeling would be that the 420 bhp tops out around 460 bhp. That's 285 rwkw (using the usual 2wd Skylines losses of ~60 kw). It wouldn't take much of a "happy" dyno to read 300 rwkw.
:) cheers :D
:) cheers :D
Especially as the 300rwkw was on a dynojet dyno.
In "Ls1-land" we find the dynojet figures to be generally around 10-15% higher than dyno dynamics figures for the same mods.
    • Maybe they'll look to do a bunch of presales to help inject some cash fast for their financial issues...
    • Does it also misfire equally when revving?   Josh is very correct in what you should do. The coilpack harness wiring loom itself is a known problem due to its age and the number of heat cycles it has gone through. Throwing parts at a vehicle to diagnose the issue isn't a smart or good way to do it. Secondly, you may have a bad coil pack, you pop replacements in, they fix that issue, but messing with the harness breaks it, so the issue persists. So now you think "well it wasn't the coil packs" and have to continue chasing your tail, potentially swapping back in your shit coil packs and returning the good ones (yes, I've seen people do this because 'it wasn't the problem' and they want to save money). And suddenly, you've got two issues with the same symptoms...   Diagnose, don't use the spare parts shotgun.
    • Well the articals keep saying a Q50s (Skyline in Japan) with a new Manual gearbox. I like the talk about the new looks with the round tail lights. I hope they bring back the retro look like they did with the Z
    • Off the back of feedback we have decided to mix up this next Motorkhana at Avalon to have some targeted skills practice for beginners to advanced. Saturday 6th September 2025 8:30am Capped 26 entries Standard Entry Fee: $89 Members Entry Fee: $55 (SAU Victoria Only) Entries Close: Friday 5th February  Where: 55 beach road Avalon. https://maps.app.goo.gl/HNUE3EuNue3sJxh38 Entries: Limited to 26 entrants (Passengers allowed over the age of 14 with a signed disclaimer and same safety gear) Disclaimer: Download  Please electronically sign and email to [email protected] or print and hand in and Driver Sign In. To compete in this event you will require A valid  AASA General Speed licence or (Day license via the AASA Website for $50) MA Licenses are no longer accepted by AASA https://aasa.com.au/  A helmet, long sleeve clothing and a 1KG mounted fire extinguisher recommended (But not Mandatory). Further details within Supp Regs on the enty link. Entry Link > https://www.sauvic.com.au/entry/deca/20250906 You can bring and have a passenger in the car but they need to comply to the same safety and clothing as driver. Bring your car and get to battle others, win, lose or draw. I can guarantee you will have lots of fun. Any questions email [email protected] Entry List:
    • Wanna rewrite all of that in, say, 2 or 3 separate sentences, so that we can read it?
