Hi guys,
Today I tried to install a couple of apexi pods in my r32 gtr, but as i was unscrewing the bolts from the air flow meter which joins to the air box, the plastic bits are so brittle that it broke and fell apart. <_< So now i only have 1 bolt holding it in place. And there is a bit of a gap on one side of the air pipe. My question is, is it still okay to drive? or will a small gap suck in too much dust in the engine etc?
Also how much is a replacement AFM??
Thanks guys! I need help!
Edited by PhilGTR
https://www.sau.com.au/forums/topic/98005-afm-cracked/
Phil I'm just taking a pluck here, but if there is air making its way past the AFM without passing through it, you may have dramas as the meter will not be forwarding the right info to the ECU. About the only place I would drive it (if it were me) would be to the wreckers to buy a replacement.
Z32 meters (used) go for $200-250. R32 GTR? Not sure, vaguely remember seeing them for $80-100 (as no-one wants them).
https://www.sau.com.au/forums/topic/98005-afm-cracked/#findComment-1780965
Hey Phil what did you end up paying for an RB26 meter?
I didn't know if you had the OEM ECU or PFC - Z32 needs an aftermarket computer. Not 100% here but pretty sure it is because the Z32 meter measures airflow in smaller voltage increments therefore you can tune the motor more finely. Meh, I forget :O
10-4 Troy, for some reason I thought it was broken after the unit. 15 year old plastic sucks, my adaptor/plug-in bit is cracked and taking the coils off sucks too - worried something is going to snap off.
https://www.sau.com.au/forums/topic/98005-afm-cracked/#findComment-1782042
Hey!
Well i will be depositing $150 including delivery for 2 x standard afm's. The cheapest i could get them so far.
I only have the stock ECU and not planning to make too much power. so stock ones will do me for now :D
I didn't know if you had the OEM ECU or PFC - Z32 needs an aftermarket computer. Not 100% here but pretty sure it is because the Z32 meter measures airflow in smaller voltage increments therefore you can tune the motor more finely. Meh, I forget :D
https://www.sau.com.au/forums/topic/98005-afm-cracked/#findComment-1783074
    • Shouldn't need a "base map" for anything other than guidance to ignition tuning. You just need the engine capacity right, the injector size right, and something, almost anything, for a VE map. On an NA engine, fuelling is almost completely a function of load signal & rpm. It should run and drive with a completely flat fuel map. It will be too lean under load, but that's easily fixed. We used to tune all ECUs without any base map. There were no such things (until someone had tuned a near stock engine on one, and then they had a "base map".
    • What did you actually buy/how much did it cost? When I got mine in like.. 2017...? 2019? the aim was to run Torque for gauges via ODB2 and things like Track Addict/Laptimers/Dashcam/Reversecam/Spotify etc. Mine never broke, but I wonder if you've got the same needs (it sounds like it). Cause I liked the idea of being able to do anything with it. That said, yours also cost 3x the cost of what I spent so... food for thought.
    • For me there is a massive difference in manufacturer or big brand crippled android (Sony, Kenwood etc) vs the sort of thing I've installed here, which is basically just a tablet in DIN form factor with open Android, and the other model of course is mirroring - Android Auto/Carplay. I hate the locked down manufacturer and AA options where they decide what apps I'm allowed to install, including the Launcher but also importantly things like Ecutek (for this car) or Real Dash (Stagea) are not supported. Plus those crippled versions tend to be slower due to both overheads and lower spec hardware. On the other hand, when this breaks I'll likely be in trouble for support....but how is that different to owning an Infiniti anyway
    • Yeah, Duncan is helping sell me back to Android devices. I've hated the whole Android head units due to their speed issues. Even in my old Hyundai Kona (2022 model), it behind the scenes was Android, and slow and shitty to start up. Once running wasn't bad, but still a good 15 to 30 seconds.
    • My roof rails are off atm on the E39 until the rust is fixed. I did find another little bit of surface rust under the rails when I took them off. As @soviet_merlin said I'd just leave them alone unless you're planning on ensuring they're properly sealed. I was on the fence about leaving them off as the delete is still a thing in BMW E39's but I feel like the car is missing something (er, it is, der) with them off and I'm looking forward to putting them back on.
