Selling My Car & Getting A New One
Hey guys as much as i will regret selling my skyline i think its the best things after spending thousands of dollars there is not much i can do, with all these rules coming into place restricting us from powerfull cars im thinking about selling my car. :):):(:(:(
I was thinking of buying a subaru forester TURBO, I was thinking of going with black, dumped on big chromies making this a show car etc you get my drift.
Im just so confused on what to get any 1 got any ideas.
Peace
EDIT: Yes i am on my P'S
Edited by MRDVS
https://www.sau.com.au/forums/topic/98100-selling-my-car-getting-a-new-one/
how much power does a subaru forester make ? i think that itself might be over the limit also. And if they do end up banning turbo cars altogether, well then your still driving illegally.
How long do you have till you get off your p's ???
You have been driving the car around legally for the amount of time you have owned it. Well assuming you have an r33.
Dont drive stupidly or in dodgy areas late at night (chapel street) etc ... and you should be pretty fine.
even if they do bring in the no turbo law, i doubt they will be able to make it apply to those who already have their P's or those that already own a turbo car. just like it is in NSW, those people are exempt.
you have that pink 33 yeah? you're already breaking the law by driving it, so whats the difference
No its not pink lol my phone makes it look pink but it does have a pearl anyway with that out of the way, its not the power to weight issue i just cant b f*kd having to worry about shit now, i dont give f*k bout the law but oh wells.
But i do think it is time to sell my car now anyway :)
Dezz, the law already applies to you because most Skylines are already illegal to dive with P's. Once the new laws are passed, the cops will be acting on them and enforcing the old ones.
The police have been very lax in enforcing the power to weight laws, but wait and see what happens once a bit of media attention, on the laws, occurs.
Dezz: Driving a R33 gts-t has been illegal (on P's) for at least 10 years, as these power to weight laws where around well b4 i got my P's, 10years ago.
Other Skylines are also illegal, to dive with P's, but as stated b4, in the last 6yrs cops have not really enforced this law. 10yrs ago you would have been "taken to the cleaners" for driving V8's, let alone our hi-powered turbo engines, which in most cases are housed in a lighter body.
yeah a forester would be a good choice if you want good power.
its a shame they're having the restrictions now.
be a good pimpin' wagon and good as a practical run around.
I'm not too sure which cars are restricted but I know there are some NA cars worth having, DC2 integra, Corolla Sportivo or even a fully worked AE86.
so whats the law exactly say.? is it just a fine? or do they take your car.? a cop can give you a fine for n e thing. i got one once for crossing the whit line in the middle of the road. "Failing to keep left". i swear i didn't cross the line. what can you do.?
Forester would be a good choice as the are ausi and heeps of parts 4 them or get a no turbo 1 now then get a front cut sti from jap and change it
sudys better than v8s holden fords i think
james
think the fine for power/weight is like $100 or something
if your just gonna get a fine. then i wouldn't even bother getting a new car. i tell you i would rather a power to weight fine. than cop a roadworth or an epa. cops usually dont go the double fine, if your nice. obviously if your an ass you gonna get every fine they can think of.
Edited by mook1
    • Hi,  Just joined the forum so I could share my "fix" of this problem. Might be of use to someone. Had the same hunting at idle issue on my V36 with VQ35HR engine after swapping the engine because the original one got overheated.  While changing the engine I made the mistake of cleaning the throttle bodies and tried all the tricks i could find to do a throttle relearn with no luck. Gave in and took it to a shop and they couldn't sort it. Then took it to my local Nissan dealership and they couldn't get it to idle properly. They said I'd need to replace the throttle bodies and the ecu probably costing more than the car is worth. So I had the idea of replacing the carbon I cleaned out with a thin layer of super glue and it's back to normal idle now. Bit rough but saved the car from the wreckers 🤣
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
