Boost cut?
Just a theory: When you are at a constant 5000rpm the turbo is well on boost, then the jab of the throttle causes the turbo to spike, engaging the ecu to activate the boost cut. Not sure if i am just spinning shit :lol:, but i have also felt that if i keep the revs at 4000rpm, in 2nd, then poke the throttle, the response is so much greater and the arse end steps out harder. I do not have any problems though, but my car is not exactly standard :(.
https://www.sau.com.au/forums/topic/98357-miss-rb20det/#findComment-1787171
Isn't the proper term fuel cut?...and as to why the car might be missing...there could be several reasons...the plugs could be F##ked or the gap might be too big...when running higher boost...its always a good idea to have the plugs regapped to 0.8mm...i'd reckon this should be the first thing to check...good luck...
https://www.sau.com.au/forums/topic/98357-miss-rb20det/#findComment-1787709
You may be hitting the fuel cut circuit in the ecu, just wtch your boost gauge and see whats happening without crashing :angry:
We had an R32RB20DET on dyno last week which kind of had the same problem. Ended up being ignition coils on 2 cylinders. They looked cooked around the sealed solid resin area. Check it out
https://www.sau.com.au/forums/topic/98357-miss-rb20det/#findComment-1788070
Hey Turbine do you know where you can get your coils tested for free ???
You could do this yourself. Check the manual it should tell you how to test them. I dont run the standard nissan coils in my 20 so I cant help much their.
https://www.sau.com.au/forums/topic/98357-miss-rb20det/#findComment-1788706
Sorry guys should have gave more info. I'm running bcpr6es NGK's which are gapped at 0.8 (be lucky to have done 1000klms on them) and i'm running F.E.T high capacity coil packs...
I'm thinking boost/fuel cut.... Just never came to my mind until someone mentioned it up there /\....
Gonna remove the boost T, and also going for a run with my mates air/fuel wideban meter to check the mixture this evening..
Only thing is, my wastegate runs 13psi stock, i installed the boost T wound all the way out to try and bring on boost sooner but keep the 13psi boost. I did think that it would prob creep to 14psi etc. I'll let you all know how i go anyway, many thanks for the ideas!!!
https://www.sau.com.au/forums/topic/98357-miss-rb20det/#findComment-1788954
Well i would think that it is not called fuel cut either, as the last thing a manufacturer would do is lean the fuel mixtures at high rpm.
ECU detects high boost level and cuts the ignition, so technically it is an ignition cut :lol: :)
Read the first post carefully:
When going through the gears normally my car boosts fine with no hiccups. But tonight i tried staying in high revs in 2nd at a constant rpm (lets say 5000rpm) then flooring it and the car started missing. It only does it when i do this?
Any ideas or suggestions?
Cheers
Jayson
Fault does not occur until he keeps the revs at a certain rpm, then pokes the throttle. If it was plugs or coils, the spark would break down when he is driving the car hard, not only when using this techneque.
https://www.sau.com.au/forums/topic/98357-miss-rb20det/#findComment-1790156
they dont lean the engine fuel mixtures out at hi rpm the ecu cuts the power to the injectors so there is no fuel to burn that why its called fuel cut
are u sure its not pre ignition
https://www.sau.com.au/forums/topic/98357-miss-rb20det/#findComment-1790327
like someone above mentioned, it only happens when holding the car in high revs then stepping on it.. This causes a massive surge of boost/fuel as the turbo is in it's prime ready to boost and it was casuing boost/fuel/ignition cut or whatever it is.
Basically... removed the bleed valve, problem sorted now.. WHich is farken awesome as now i can drift it at Sunday's drift day!!! yey
But with a bit less power ;)
Thanks for all your info and advice
Edited by Mase
https://www.sau.com.au/forums/topic/98357-miss-rb20det/#findComment-1791445
    • Bit difficult to follow. Have a look below and see what the standard R32 layout was like. Note there was a restrictor in place immediately before "turbocharged pressure control solenoid" that, if removed, magically got you 1 bar boost.
    • I might be way off the mark here.. there must be a T junction under the manifold. That takes manifold pressure through a check valve prior to the T, one side splits out to this bleed off orifice, the other straight to the wastegate actuators.
    • Carrying out some engine due diligence before my first drive in a 260RS that has been in storage for 10+ years, and found two lines that are susposed to be plumbed into the boost control solenoid. One of the lines (the wastegate boost supply line) to actuate the gates, had a bolt in one end blocking it. The other line (main boost signal line) from the very rear of the intake manifold (RB26DETT) and runs up to the boost controller had this pill in the end of it as seen in photos. Other than the obvious (T28 Ceramic turbos might well be cooked)  Can anyone shed any light on if there is any validity at all with this mod, bleeding a constant fixed rate of manifold boost pressure off through this 3mm hole?  Is it deliberate?  Was this a 90s Jap mod done to RB26's? Or has someone just fitted this without any idea of what happens to ceramic T28s if they are not gate controlled?
    • This looks great! Awesome to have the 5 speed with an LSD in this. The Recaro's look like SR2's or SR3's. It's a shame they've been retrimmed as they would have looked sweet in their original colours. I think I'd want my agent to be a little more up front and informative too. I've never imported but I reckon it would make me a little nervous, so the more info the better.
