Guys,
A quick heads up on our 2006 Motokhana Dates as part of our clubs Motokhana Championship. At this stage we have booked all four events at the DECA facilities in Shepparton but we are looking into some "local" alternatives to maybe change one or two of the events.
But the dates for the year are:
Round 1: Saturday Feb 25th
Round 2: Saturday May 27th
Round 3: Saturday Aug 26th
Round 4: Saturday Nov 18th
Sup Req's and Entry forms will be posted up about 1 month before each event.
Cheers.
https://www.sau.com.au/forums/topic/98396-2006-motokhana-dates/
Guys,
Cheers.
Local alternative sounds good.
i think im going to be participating this time rather then volunteering :rofl:
it just looked like too much fun!!
hopefully i'll have that day free.
EDIT:: OMFG!!! its on the day of mine and josies engagement!!! :_( i swear im never going to be able to attend a DECA day.
Can't do the Feb one unfortunately and will be back in time (just) for the May one. Looking forward to some more auto subaru action! Had the 200,000km service done today and was expecting a couple of nasties from DECA but nothing. :(
Pricing roughly: 1 tank of fuel inc the day itself ($50)
2 days accomodation max of $80 per night
Friday night dinner inc a couple of drinks- $30
Saturday night Dinner + fish bowl $60
Drinks saturday night around $100
Breakfasts for me were usually Mars Bars and Iced Coffee so $10
Great company and being able to terrorise a country town in a good way - Priceless! :(
Prices are rough guides only and may or may not be indicative of actual spending especially after 9pm on Saturday night.
Seriously though, great fun and worth the few extra $$ on top of a normal weekend for the company and the experience.
  • 6 months later...
    • I hadn't thought about the variable power steering assist. Presumably, it will always be the same level of assist as you get in an S14. The R32/3/4 are either helliishly heavy (at low speeds) if the solenoid is not powered at all, or hellishly too light (at high speed) if it is powered all the time. I presume that it is PWM controlled on those cars. I hadn't thought about the S cars not having variable assist. ugh. What crappy plebby cars they must be!
    • Hmm yeah that is a good point. It looks like it'll just bolt in with no real issue besides maybe the bushings being different. My other concern was that 2 pin plug that I assume is used in some way to control the rack solenoid depending on the speed signal from the ecu. The DMAX rack doesn't even have that plug though so, don't think it'll matter. Might just order the rack and see how it goes. Will update this when I figure something out
    • I'd say it's a fair bet that the feed and return fluid lines will be in different enough spots that you would need to come up with a way to cut the originals short and adapt with new hard line adaption or braided teflon hoses or somesuch. But really, you have the car, you have the photos of the DMAX rack - you should be able to go out there and see for yourself whether they're in the same or different spots.
    • I've been doing some looking around and honestly was just considering throwing a new rack at it. I saw that the dmax silvia rack bolts up into the 33 with the silvia bushings but not sure if the high pressure lines will sit in the correct spot. I believe other version of the 33 rack are the same/similar to the racks that can be opened up without as much fuss so I assume the dmax rack would fit but any ideas?
    • I've never played with one, but I would expect that you are correct. That slot looks like it is intended to be used to unscrew the end, and the flats on the body would be better than grabbing it around the round bit with a pipe wrench. So, yeah, probably unscrews. You'll probably have to make a tool to drive in that slot.
