It's been like 2 - 3 weeks now with no Ultimate. I've had to use some Synergy 98 & Optimax.
I want Ultimate again! Anybody who always uses ultimate but is having to use another fuel feeling the difference? speak up.
I think Optimax has been slower, 3rd gear 12psi just isn't pulling as quick I think.
https://www.sau.com.au/forums/topic/98459-bp-ultimate/
I have been using vortex98 for the last few tanks and fuel economy is exactly the same.
The car does pull harder in 2nd and 3rd!!
I was suprised but my car runs better on vortex98 than ultimate or optimax.
https://www.sau.com.au/forums/topic/98459-bp-ultimate/#findComment-1789549
I'm of the understanding that most of the east coast has got an Ultimate shortage, with stocks to be restored at the end of December or early January.
I've been giving Synergy 8000 a go, I'm on my 3rd or 4th tank, I've noticed that power seems to be ever so slightly up, though my fuel economy has dropped slightly.
https://www.sau.com.au/forums/topic/98459-bp-ultimate/#findComment-1789694
yep, there's been none in my town for at least 3 weeks (2 BP's, both out).
is really beggining to sh*t me cos i gotta drive 15 mins down the road to get optimax, or remember to fill up when im passing a shell/mobil out of town.
tried vortex and wasn't real keen, my knock levels went higher than i've ever seen them (although was a warmish day and car is tuned for ultimate).
https://www.sau.com.au/forums/topic/98459-bp-ultimate/#findComment-1791718
Well ive been running on synergy 8000 and recently swapped to optimax extreme.. and as far as im concerned it kills bp ultimate. I've got noticable power differences, specially after re-setting the ecu.
Though will good to be back to ultimate again, no ethanol or anything to worry about:)
Dayne
https://www.sau.com.au/forums/topic/98459-bp-ultimate/#findComment-1793330
i think the "Ultimate" part in BP ultimate's name has a lot of people fooled lol
I think you'll find most workshops agree you can tune the hardest on Ultimate for any pump 98 fuel in Aust.
#1 Ultimate
#2 Synergy 8000
#3 Optimax
Some people say Synergy is a tad better than Ultimate but usually Ultimate is the prefered fuel for tuners trying to get the most outa it. I got the most power & lowest knock out of my car tuned on Ultimate.
Edited by geno8r
https://www.sau.com.au/forums/topic/98459-bp-ultimate/#findComment-1793466
how do you go about resetting the ECU?
Disconnect the battery, press the brake pedal to drain all the remaining power. Maybe leave it for a while then just hook the battery back up.
And I've been using Optimax since they went out of Ultimate and to be honest there is no difference at all imo. :(
https://www.sau.com.au/forums/topic/98459-bp-ultimate/#findComment-1794029
i ran my car on ultimate all the time and i found it pulled harder, had better economy and ran better, less lumpy in the idle. Using vortex and sh*t like that made my car crap, noticed it clutch kicking at pt.g last week.
GO BP ULTIMATE!!!!!!!! please come back to me
https://www.sau.com.au/forums/topic/98459-bp-ultimate/#findComment-1794053
Sounds like you guys over east are just getting what we went through over here about a month ago. The refinery had a problem so they couldn't produce anything but normal unleaded, so most stations were without 98 for a few weeks. Over east was still ok because they stockpile it I guess. Now that it's normal over here, that was probably the priority so all the fuel has probably came to us. :)
It won't be too long I imagine. Unless there are BP refinery's over east, I would think there would be which would mean I'm babbling shit.
You lot are complaining but over here Ultimate is the only 98 fuel we can get so it hurt us a LOT more!!!
https://www.sau.com.au/forums/topic/98459-bp-ultimate/#findComment-1794884
Ultimate is more expensive than extreme 100 here in QLD... On any given day BP is at least 2 cents dearer than shell at aspley and virgina....
So i stopped going to get fuel from BP along time ago...
I had the fc tuned on optimax and found extreme to knock a bit more but the extra 50km;s per tank has not rally made me a fan... ill stick to 98 plus i get 4c off a litre at shell also...
So thats a saving of about 3 bucks a tank... I also get a 600ml coke when i fill so thats a free coke in my books....
50-60 litres of fuel for the car and 600ml of coke for me....
https://www.sau.com.au/forums/topic/98459-bp-ultimate/#findComment-1796224
    • Lamb roast on Saturday will be different 🥲
    • They are under bucket shims. Tomei provides a test shim kit and then any measurement of shim required.
    • I always wondered how you were supposed to buy a set of 24 buckets and somehow magically have every single one of them yield exactly the desired clearance. I would have thought you'd need to assemble a cam with either 12 "sample" or "example" buckets of known top thickness (or a single such sample/example 12 times over!!) measure clearances at every valve, and then do the usual math to work out what the actual "shimness" of each bucket needed to be, before buying the required buckets to make up he thicknesses that you didn't have on hand.
    • I now seem to be limited in power due to my rev limit/hydraulic lifters in my built RB25. I'm looking into converting over to Tomei solid lifters. Question for anyone that has done the conversion. I was always under the impression that when using the Tomei solid lifter conversion, you would also require new valves (Longer or shorter stems, I can't remember which).  I don't know where I got this idea, as so far I see no mention of this in any of the Tomei documentation. It just states I need the Tomei solid buckets, solid lifter cams and upgraded springs. As my head is already built, all I would need is another set of 1000$ Kelford cams, 500$ buckets and about 4H hours of my time installing and I'm off to the races!?!? There's no way it's that simple, I must be missing something?
    • I couldn't agree more. I should have started from the get-go with a NEO or solid bucket conversion. I started looking into converting over to solid lifters yesterday. Now for some reason I was always under the impression that when using the Tomei solid lifter conversion, you would also require new valves (Longer or shorter stems, I can't remember which).  But I see no mention of this on any of the Tomei documentation. It just states that I need the Tomei solid buckets, solid lifter cams and upgraded springs. As my head is already built, all I would need is another set of 1000$ Kelford cams, 500$ buckets and about 4H hours of my time installing and I'm off to the races!?!? There's no way it's that simple, I must be missing something?
