I am making front lips for r32 GTR, i want your opinion, with your stock lips atttached, how much lower do u guys want ?
it's on the stage where i can still add extra dimensions before i actually set them.
this lips featured Brake vents air catcher, and it will e angry for the r32 :D:O
cheers
and tnak's in advance guys
fred
www.topstage.com
https://www.sau.com.au/forums/topic/98599-r32-gtr-front-lip/
ooh, i need a new one of those lol, mangled my one with my driveway :S being able to go a bit lower would be good but...
would be cool if they were that flexi-fiberglass stuff! thay are pretty low as it is, mine has stock suspension & ride height and took out my lip with my driveway :D
you guys do realise that none of the fibre glass or carbon-fibre or flexi glass will be more durable than the standard one right? the standard one is like a rubbery plastic.
good ol plastic takes those bangs and scrapes i have almost worn all the bottom of one side on my GTR and i've only had it 6 weeks stupid driveway but thank goodness for my job custom carbon i'm gonna make a mould for the 33 GTR lower lip we already have the mould for the 32 GTR lower lip anyone interested contact myself on here or at work Custom Carbon 07 38652014
i have decided to go 20mm lower than stock lip, for the sake of max aero effect. the lip will be made from flexi FRP . it's a new design that is not screwed from underneath the bar that will get ripped on scrapes.
it will be 2 bolt and easy access to remove and attach system.
i will do stock lip soon. Carbon lips are bad news for durability, they are stiff and will brake easily. My new Flexi FRP will take good punishments as well as the newly designed attachment system.
It will be ready soon guys....... safe up now.
guys, say bye to stock lips especially fiberglass one, they are bad news since it's attached under the bar, it will get squashed on your 1st scrapes.
Topstage lips are designed with our easy remove system that actually minimise breakage.
i will post pics of the design shortly.
It’s amassing how many people actually need this bloody thing!
20mm lower sounds nice to me. Mine is already slightly lower then stock so this should look great.
Really looking forward to seeing the final product.
I'd like to see the 20mm lower lip. I have to remove the lip to get my car on the trailer going to events which is a right PITA, so a lip that's quicker and easier to R&R would be great. a bit lower is a bonus for track work. If they look good, I'll take one
  • 4 weeks later...
  • 2 months later...
    • These coils draw 10amps that what i read online
    • I appreciate the detailed explanation, think I understand now. I spent the better part of last night reading what I could about shuffle and potential solutions. I had replaced the OEM twin turbo pipe with an alternate Y pipe that is separated further away from the turbo. The current one is from HKS and I had a previous pipe that was separated even further away, both have shuffle. I had heard that a divider can be welded in to the OEM pipe to remove turbulence, and figure that aftermarket pipes that are more separated would achieve the same thing. From what I read, most people with -10 turbos get shuffle due to their size, though it's a bit less common with -5s on a standard RB26. I think Nismoid mentioned somewhere it's because OEM recirculation piping is common in Australia with -5 cars. It seems that the recommendation tends to vary between a few options, which I've ordered in what I think is most feasible for me:  1. Retune the MAP or boost controller to try to eliminate shuffle 2. Install OEM recirculation piping 3. Something called a 'balance pipe' welded onto the exhaust manifolds. I don't know if kits for this are available, seems like pure fabrication work 4. simply go single turbo My current layout is as follows: Garrett 2860 -5s HKS Racing Suction intake MAF delete pipes HKS racing chamber intake piping hard intercooler piping,  ARC intercooler HKS SSQV BOV and pipe Haltech 2500 elite ECU and boost solenoid/controller HPI dump pipes OEM exhaust manifolds HKS VCAM step 1 and supporting head modifications Built 2.6 bottom end All OEM recirculation piping was removed, relevant areas sealed off I'll keep an eye out for any alternative solutions but can get started with this.  Only other question is, does shuffle harm the turbo (or anything else)? It seems like some people say your turbo shafts will explode because of the opposing forces after a while and others say they just live with it and adjust their pedal foot accordingly.
    • That worked out PERFECTLY! Thank you big time to JJ. He was able to swap me his stock diff. He drove all the way to me as well. Killer! Removal & install was pretty straightforward. The diff itself is HEAVY. So that’s a 2 man job.  Man does the car drive nice now! Couldn’t have worked out any better 👌
    • I'm interested,do you still have it?
