How To Replace Rear Tail Light S1 Stagea?
SOB
 Share
Hi all, I'm in need of help on how to replace my rear passenger tail light assembly. If some one has a procedure & photos of the steps would be much appreciated.
Cheers Shane
Nothing on the inside as far as I remember. Just two 10mm bolts on the inside near the rubber seal and one or two clips on the outside that need a firm tug. Not too hard though you don't want to damage the wiring harness.
Went thru a lot of this chasing my bros dodgy tail light bulbs
They are a sod to get out. Take the two bolts out. You can see them when you lift the tailgate. The assembly can then be prised out with a BIG screwdriver. The assembly is located by two "pins" The upper pin is a push fit into the body, but the lower one is about 6mm dia. and is knurled so it is a bloody tight fit. Be patient and it will come out.
Thanks heaps guys appreciated. I will try to remove this arvo when I get home from work. Gotta love this forum so many poeple willing to give up their knowledge to help out.
Cheers Shane
 Share
