This may be a repost but I wanted to give everyone a heads up on this...
I came across this video on another forum: [warning - 24mb]
http://www.crazycarvids.com/showvideo.php?id=335
Its about the use of everyday walkie talkies to interfere with the car alarm signals. Apparently thieves in Germany are using it to get easy access to cars where the owners just press the button and walk away without checking to see the doors are locked.
Alarms and walkie talkies work on the same frequency. This works on all types of cars and alarms even BMW and Porsches. Check it!
https://www.sau.com.au/forums/topic/100940-take-care-when-locking-your-car/
those detachable kits are becoming cheap now too... no need for sterring wheel lock.....
haha go out to dinner with the gf in one arm and sterring wheel in the other :)
I would do this if my car did not have airbags
You could probably just chuck the wheel in the boot.
The mere sight of no steering wheel would deter most car thieves.
I dont know about the rest of you but sometimes whn i lock my car the alarm starts going off for no reason. I just wondering if it happens to anyone else, one of my mates seems to think that it is because the car is still running and the vibrations set of the alarm.
sounds like ur shock sensor is too sensitive, my mates TT soarer would set off the alarm when it was idling with the turbo timer on.
just adjust it so its not so sensitive. if your cars idle sets it off then it probably means other cars with loud exhausts driving past will set it off too.
Some car alarms set themselves off in the hot weather due to an expansion of air inside the cabin.
Sensors read this as movement, and set the alarm off.
It can sometimes be remedied by cracking open a window a few mm, but relates back to that COGS said about sensitivity settings.
I love driving around the underground car parks and setting car alarms off with my exhaust note...
Nobody pays attention to car alarms any more.
People don't even want to look in the direction where an alarm is going off, in case they see someone stealing a car.
People don't want to be inconvenienced by seeing something which may require that they waste their time and lose wages by having to make a court appearance because some asshat wanted a free ride.
We discovered this one first hand when the batteries in the remote died...
crowded car park, we open the car manually due to being unable to disarm the alarm, the alarm goes off and keeps going off.... people walk on by, but don't look in the direction the noise is coming from!
Even while someone had his head under the dash with legs poking out the door trying to find the fuse to shut the siren up, people just continued to pass on by.
again....... nobody cares about alarms.
visual deterrents is where it's at.
I'd love to get one of those detatcheable steering wheels but my gf would refuse to carry it around in her bag while we are at the shops. She already carries around my stereo face and sometimes keys, imagine a steering wheel as well! :lol: I always check to see if the doors have locked after I leave as well.
"I'm somewhere where I don't know where I am!"
    • It says 300ZX, does that make it an Aus delivered car? Funny how back in the day I just couldn't care less about Z32's and these days I am just in love with them. Back when Nissan was into pushing the envelope. 🤣
    • Hi guys, just after some guidance with an R34 sunroof that has stopped working correctly. It still opens and closes perfectly fine, but it no longer tilts/vents up or down. As a result, the rear of the glass now sags a bit as it drops down slightly in order to retract into the roof, but now it can't pop upwards into a flush position. I’ve probed the pins on the back of the switch connector with a multimeter and it seems like both switches (for open/close and tilt/vent) still work correctly. Any ideas on what it could be, or where I should even start in terms of diagnosing? I'm sure someone's had this issue before but I haven't been able to find anything online relating to this specific issue, most of the issues are with the seals leaking or the motor failing entirely. Thanks in advance!
    • Do you have some data like fuel pressure? It's really hard to say if you're still fighting a fuel system issue at this point. Could be something weird like the FPCM dipping out.
    • Yeah in that case, pulling the dent out. Event a very slight dent can create a lot of work filler-wise and there is a strong chance the panel won't be the factory shape when you are done (as the dent will result in a new high point created somewhere, then everything is brought up to that new high point... but the panel shouldn't be that high if that makes sense).  So you've filled and primed the panel and it is flat, why would you go back and remove the primer and add more filler?
    • Something else I have been faffing with while the car was off the road is making the AC work. Assuming the car isn't at a thermal limit the idea of having AC while waiting in line to go on track sounds delightful. I have actually been lugging around the weight of the entire system since 2018 when the RB25NEO went in without it working at all.  The main reason was in the first few events before I got around to re-gassing it the rubber hose that runs under the manifold had the factory heat wrap/sleeve fail resulting in this: ~2 years ago I purchased a complete used R32 AC line set but when I finally went to install it the line i needed was different where the expansion section is I found a local place that was able to replace the rubber section and re-crimp. They also added some modern heat sleeve to the hose Tight fit but fingers crossed this is the last physical piece of the puzzle needed
