You will need a 3 inch turbo back exaust( get one of those split dumps from the guy on this forum), fmic(can get a good cheep one from another guy on this forum), a fuel pressure reg and a Power fc ( get it of the same guy that sells you the fmic). Hope that helps.
really cheap?
Chinese ebay turbo dump + 3" exhaust + bashed cat.
chinese copy ebay intercooler
simarks boost controller
Jarcay DFA.
Please note that the dump pipe might split and the intercooler might not flow and cool enough. You get what you pay for. Just save up.
However, simarks boost controller works well, and so does the DFA, if you put it together right.
You don't need an aftermarket fuel pump or fuel pressure regulator.
I have HKS style dump pipe & exhaust, R34 intercooler, K&N panel filter and Power FC with boost controller kit.
Made 207 rwkw (hub dyno) at 0.7 bar (10 psi).
Total cost including tuning approx $3,400 ($NZ)
You pay for what you get. If you do it on a budget you wont get quality..
words to live by
sure the fuel pump doesnt make any extra power, but i woudlnt want to push the stocko that hard, coz if it lets go, your engine aint going to like it
Also helps to see a good tuner aswell
i went from 187rwkw to 201, just because i was running rich as.
I also have
Power FC
FMIC
AVCR
Split Dump
Panel filter
3" hiflow cat
Running on 12psi
Some money spent on getting things were fixing up performance joints mistakes . i have been to APC, FIST, Mercury (just for power run) and Chiptorque,
im gonna try matty Spry next and thats it.
ok ive got a fmic , 3'' cat back exhaust , pod filter , and one of them turbotech boost controller but never turned it up so still running stock , also i got a power fc but still in the box hehe so is a fuel pump that important? i want 2 put a split dump n hi flow cat but if the fuel pump is more important den i should get that first
also it should be important to note that mods based on a $ per kw gain at the start is very high, then as you progress it drops signifcantly. the first few mods are really cheap and give really good gains. then as you progress up the power tree, usually past 160rwkw it becomes more expensive per kw gain.
ie piggyback vs standalone and so on
    • I got back to Japan in January and was keen to get back on track as quickly as possible. Europe is god-awful for track accessibility (by comparison), so I picked up a first-gen GT86 in December just to have something I could jump into right away. The Skyline came over in a container this time and landed in early January. It was a bit battered after Europe, though—I refused to do anything beyond essential upkeep while it was over there. The clutch master cylinder gave out, and so did the power steering. I didn’t even bother changing the oil; it was the same stuff that went in just before I left Japan the first time. Naughty. Power steering parts would’ve cost double with shipping and taxes, so knowing I’d be heading back to Japan, I just postponed it and powered through the arm workout. It took a solid three months to get the car back on the road. Registration was a nightmare this time around. There were a bunch of BS fees to navigate, and sourcing parts was a headache. I needed stock seats for shaken, mistakenly blew 34k JPY on some ENR34 seats—which, of course, didn’t fit—then ended up having the car’s technical sheet amended to register it as a two-seater with the Brides. Then there’s the GT86. Amazing car. Does everything I want it to do. Parts are cheap, easy to find, and I don’t care what anyone says—it’s super rewarding to drive. I’ve done a few basic mods: diff ratio, coilovers, discs, pads, seat, etc. It already had a new exhaust manifold and the 180kph limiter removed, so I assume it’s running some kind of map. I’ve just been thrashing it at the track non-stop—mostly Fuji Speedway now, since I need something with higher speed after all that autobahn time. The wheels on the R34 always pissed me off—too big, and it was a nightmare getting tires to fit properly under the arches. So I threw in the towel and bought something that fits better. Looks way cleaner too (at least to me)—less hotboy, less attention-seeking. Still an R34, though. Now for future plans. There are a few things still outstanding with the car. First up, the rear subframe needs an overhaul—that’s priority one. Next, I need to figure out an engine rebuild plan. No timeline yet, but I want to keep it economical—not cutting corners, just not throwing tens of thousands at a mechanic I can barely communicate with. And finally, paint. Plus a bit of tidying up here and there.
    • I assume clearances were all a-okay?
    • Shock tower brace is in +5Kw....LOL
