  • Replies 40
I just did a net search and this movie sounds like its going to be crap. Its got bow wow in it for god sakes. There not even going to bring back vin diesel as planned. "The fast and the furious - tokyo drift' is the name they have called it. I was so lookking forward to this movie but I think they killed the franchise with this one. check it out
http://www.imdb.com/title/tt0463985/
not happy jan!!!!!!!!!!!!
AWD cars are supposably not alloweing japanes drift tournaments because they are to easy to drift in.
when i heard that it supprised me to.
i can understand that.. one of there ratings is on speed.. awd's can drift alot quicker than rwd cars so that's why i'd imagine they'd be banned in tournaments.. either that or just give them a awd catagory
Great another movie that will spawn a generation of kids who think they can drift in their parents cars, which will then result in media bashing car enthusiasts
whats new about that?
this movie is going to be horriblle..... its bad enough with all the nissansilvia wankjobs
No, audis rule. Go do some decent research.
Whatever happens tho, 90% of us will go see the movie just to see how much of a laugh it is, or how stupid it is or whatever. The people that make the movie dont care, as long as they make a motza on it.
Didnt you know that Japanese car manufacturers lack creativity so they must copy European rivals?
Honda has been copying BMWs for ages now they moved onto Audi...
Nissan 350Z does look like Porsche and so on.
Probably the only real car that Nissan designed to look unique is the R32-34 skylines...
The accord Euro is designed in Europe if I'm not wrong.....
if you ask me I find Japanese has the most original car design. if you look at the audi, Ferrari, Lambo they all look the same
    • So, version 4 intake is on its way I was looking at these a while ago but at around $200 or more it was a little pricey for something that might not work, but, I had it in my watch list, but, I got a message saying it was on special, and I had a code thingie to use, it eventually came in at $120 delivered, so BAM, BUY NOW.....LOL I'll need to have a look when it arrives but I feel it will "look" better than what I currently have, as it comes with a PCV fitting, so I will be able to get rid of the alloy pipe that goes to the throttle body with the PCV fitting  Well, that's what the voices in my head are telling me  Oh, and this happened today Yeap, it was a Trojan, and it was cheap, so I headed back to the hardware store and actually spent a little bit more on a heavy duty,  one that was actually recommended by a plumber mate, a Cyclone one with a fibreglass handle that is actually rated for clay The broken shovel will eventually be "modified" into a short handle shovel
    • When you pulled it off, there is no signs of blown head gasket? Is it possible you have some other issues going on? Possible cracked blocked? Or do you think it's straight up lifting the head? Did you check what the head was torqued to before pulling it down (To see if possibly they're stretching, or starting to break threads out etc)?
    • Seems like a decent result for a modded JZX110. They are bulky in comparison to the 100 and 90 models (which I'd prefer myself) but they are getting very few and far between here in JP these days. Thanks for the detailed review and the import process into the UK. I also have a car which I'm hoping to export from Japan at some stage so it's good to know if someone from the UK was interested in it. By the way the corrosion underneath is par for the course for cars which were located in/near the mountains or along the Japan sea coastline. They get huge amounts of snow every winter and the sodium chloride is used on the roads. Many cars have some kind of rubber like treatment underneath but they tend to limit it to the wheel arches underbody and fuel tank. Suspension arms and sub-frames will have similar corrosion to your JZX110 which is a common sight. See it all the time and car dealers here generally don't even mention it unless asked.
    • If the sound goes away when you clutch in, the 1.5/2 way diffs are just shit, and you are a normal person. The diff is likely "fine" but driving at anything under 30kmh is a violent horrible experience. It would be exaggerated with solid diff bushings and subframe bushings if you have those.
