  • Replies 57
1)AWDMAT
2)IB6UB9
3)MARK R33
4)Benm (maybe)
5)Blk180
6)bunta
7)9kprm
8)nipples
9)reddrifter
10)toasty added
11)jaystar added
12)oblivion
13)vex
Ive asked the supplier if more than 10 can do for the same price and he has agreed. Am waiting for the right gear boot to be sent to me still. let you guys posted with fit etc. thanks aaron
ps: as soon as fit is done will be closing this group buy and organising payment etc
will have pics up tommorrow...and for both..the finish is excellent..but the fit isnt 100% with what i wanted it to be..and yeh looks like leather..just real thin!...ill post up pics n people wanting can decide if they want or not..either way is kool with me
Sorry guys been bit busy will have pics up ASAP and people wanting i will pm you again for confirmation so i can let the guy know how many..so i can maybe get it dropped bit lower..let you guys know
ok guys couldnt get further discount of supplier, will definately have pics up tommorrow of the one i have used for my car. Appologies to people about being slow, as i have been trying to source sum parts for my car etc. Anyways people wanting their boots please pm me so ill know exactly how many to order. thanks
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
    • I haven’t yet cut the chassis, maybe I switch to a reverse flow. I’ve got the Intercooler mounted as I already had it but not cut yet. Might have to speak to an engineer
    • Yes that’s another issue, I always have a front mount, plus will be turbo plus intake will big hasstle. I’ve been told if it looks stock they’re fine with it by a couple others who have done it ahahaha.    I know @Kinkstaah said the stock gtt airbox is limiting but I might just have to do that to avoid a defect so it atleast looks legit. Or an enclosed pod so it’s hidden away and feed air from the snorkel and below Intercooler holes like kinstaah mentioned. Hmm what to do
