got mine bak
need an EBC cause my boost curve is shit atm u can feel the lag more cause its gota build up (no boost controller atm)
so get EBC might make bit more power but no to bad atm :P
206.9rwkw @ 14.5psi
A31 1988 Cefiro
Mods: Fresh STD rebuilt RB20 engine ~5000kms so far
Boostworx remapped STD ECU (still untuned for new turbo), Bosch 040, Hybrid front mount, very quiet exhaust (3inch), Garret T3G turbo ~15psi, Blitz pod and HKS EBC 2.
Now making 214RWKW at 15psi, dyno sheet to be updated soon
Edited by Ceffy_SA
1990 r32 gtst
gt3071r
550cc injectors
walbro fuel pump
tuneagent exhaust manifold
full exhaust system with custom dump
just jap cooler with custom piping
sm4 autronic ecu
stock internals
the car made 248.7rwkw but its now tuned at 241.4rwkw
ill try and post up dyno sheet but my scanner is playing up.
Thought I'd post up my old RB20 results for all to see :P
Car consisted of:
- internally standard RB20DET (silvertop)
- s1 RB25 turbo
- china fmic + piping
- Xforce split dump pipe
- 3" front pipe
- 3" decat pipe
- 2.75" cat back into canon
- 044 pump mounted intank
- generic metal pod filter
- Greddy Profec B spec2 (haven't spent much time smoothing out the boost curve)
This was untuned running 12psi (ignore the red line, that was when we tried to run 14psi, it made ~260rwhp but started to ping up high)
Edited by bubba
Mods:
Hks 2530
hybrid front mount
3 inch split dump> high flow cat (catco? i think) > trust power extreme 2
550cc siemens injectors
EMS Stinger 3
turbosmart boost tee
bosch 040
low run 12.5 psi
high run 17.5 psi
stoked goes well :P
  • 3 weeks later...
Internally stock rb20
turbo back exhaust straight through
apexi pod
hks evc
apexi safc2
stock turbo,injectors, afm
30 degree day.
237rwhp or 177rwkw
update soon with z32, hiflow33 turbo, bigger injectors.
img_Z050632_0001.pdf
RB20
garrett GT35-40R turbo
port and polished head
600hp fuel pump
750cc injectors
trust 600X300 front mount
apexi power fc engine management
3'' exhaust turbo back
k&n pod filter with cool air induction
Mathew Spry tuned it and it made 380 rwhp at 19psi and ran a 12.3 at 128mph.
RB20DET
standard Internals
177,000+Kms
272hp atw @1.2k boost
MODS:
Apexi Power FC
HKS 2535
External Wastegate 45mm? I should have measured it...
550 Denso injectors
Z32 AFM
Old style BLITZ? FMIC
Bosch pump
3in from turbo, hi flow(ed) cat
just got the car.
loosing boost at top end due to cheap bleed valve.
Im measuring 550km on one tank (40L) with highway driving. 350km for city driving...
Thanks to the guys at Hyperdrive!
Edited by ZOKU
1992 R32 GTS-t Manual
Stock turbo
FMIC
3" cat back
pod filter
20psi
BP ultimate 98
Every thing else STOCK ah yes slipping clutch
271HP 202Kw
Edited by Steve-o 45LDE
R31 Nissan Skyline
Engine: 1992 R32 RB20 Silvertop
Mods: 600x300x76 Intercooler
Custom 2.5in Stainless Cooler Piping
Stainless 3in Exhaust
3in Front/Dump Pipe
High Flow Just Jap 3in Cat
GFB Bleed Valve set to 14psi bleeding back to 11psi
HKS Pod Filter
Everything thing else is stock. Car was tuned by 'The Speed Lab'.
174.1kw
  • 3 weeks later...
RB20DET stock
HD Industries ex manifold , VL T3/T04 , Tial 38mm waste gate , bosch 044 fuel pump , bosch 363 injectors ,
Motec M800 , Custom plenum , 70mm throtle body , 600 x 300 x 105 FMIC
233 rwkw at 16lb boost
the 159kw was when it was powered by a L20B Turbo
STU
Edited by RB20DET BLUEBIRD
stock RB20
Hks 2530 @ 1.3bar (2510 rebuilt with garrett spec 2530 sized turbine)
GTR injectors
Blitz dualSBC
EMS
HKS dump into 3" zaust 2 mufflers no cat
600x300 fmic
lil disappointed but the motor is very tired
289.4rwhp @ 6100rpm
384.6 Nm torque @ 4600rpm
dyno sheet coming.
92' R32 GTS-t
Mods:
- Internally standard RB20
- GKTech split dump+front 3"
- 3.5" cat-back
- Apexi Pod
- Hybrid Front-Mount
- Bosch 040 Pump
- Running on standard boost = 159.0rwkw - Pretty happy with that.
Cheers,
Steve.
    • I know why it happened and I’m embarrassed to say but I was testing the polarity of one of the led bulb to see which side was positive with a 12v battery and that’s when it decided to fry hoping I didn’t damage anything else
    • I came here to note that is a zener diode too base on the info there. Based on that, I'd also be suspicious that replacing it, and it's likely to do the same. A lot of use cases will see it used as either voltage protection, or to create a cheap but relatively stable fixed voltage supply. That would mean it has seen more voltage than it should, and has gone into voltage melt down. If there is something else in the circuit dumping out higher than it should voltages, that needs to be found too. It's quite likely they're trying to use the Zener to limit the voltage that is hitting through to the transistor beside it, so what ever goes to the zener is likely a signal, and they're using the transistor in that circuit to amplify it. Especially as it seems they've also got a capacitor across the zener. Looks like there is meant to be something "noisy" to that zener, and what ever it was, had a melt down. Looking at that picture, it also looks like there's some solder joints that really need redoing, and it might be worth having the whole board properly inspected.  Unfortunately, without being able to stick a multimeter on it, and start tracing it all out, I'm pretty much at a loss now to help. I don't even believe I have a climate control board from an R33 around here to pull apart and see if any of the circuit appears similar to give some ideas.
    • Nah - but you won't find anything on dismantling the seats in any such thing anyway.
    • Could be. Could also be that they sit around broken more. To be fair, you almost never see one driving around. I see more R chassis GTRs than the Renault ones.
    • Yeah. Nah. This is why I said My bold for my double emphasis. We're not talking about cars tuned to the edge of det here. We're talking about normal cars. Flame propagation speed and the amount of energy required to ignite the fuel are not significant factors when running at 1500-4000 rpm, and medium to light loads, like nearly every car on the road (except twin cab utes which are driven at 6k and 100% load all the time). There is no shortage of ignition energy available in any petrol engine. If there was, we'd all be in deep shit. The calorific value, on a volume basis, is significantly different, between 98 and 91, and that turns up immediately in consumption numbers. You can see the signal easily if you control for the other variables well enough, and/or collect enough stats. As to not seeing any benefit - we had a couple of EF and EL Falcons in the company fleet back in the late 90s and early 2000s. The EEC IV ECU in those things was particularly good at adding in timing as soon as knock headroom improved, which typically came from putting in some 95 or 98. The responsiveness and power improved noticeably, and the fuel consumption dropped considerably, just from going to 95. Less delta from there to 98 - almost not noticeable, compared to the big differences seen between 91 and 95. Way back in the day, when supermarkets first started selling fuel from their own stations, I did thousands of km in FNQ in a small Toyota. I can't remember if it was a Starlet or an early Yaris. Anyway - the supermarket servos were bringing in cheap fuel from Indonesia, and the other servos were still using locally refined gear. The fuel consumption was typically at least 5%, often as much as 8% worse on the Indo shit, presumably because they had a lot more oxygenated component in the brew, and were probably barely meeting the octane spec. Around the same time or maybe a bit later (like 25 years ago), I could tell the difference between Shell 98 and BP 98, and typically preferred to only use Shell then because the Skyline ran so much better on it. Years later I found the realtionship between them had swapped, as a consequence of yet more refinery closures. So I've only used BP 98 since. Although, I must say that I could not fault the odd tank of United 98 that I've run. It's probably the same stuff. It is also very important to remember that these findings are often dependent on region. With most of the refineries in Oz now dead, there's less variability in local stuff, and he majority of our fuels are not even refined here any more anyway. It probably depends more on which SE Asian refinery is currently cheapest to operate.
