Meaning what ?
Well there are a few competitors who arent happy about him running non original wheels, especially since they are larger in diameter and width over what they use to run.
A guy in Vic has about finished his restoration of a Gibson R31 and the expense to get the mob in SA to recast the original magnesium wheels so that he complied with the category rules...other ppl have gone to similar extremes and Terry so far has got away with the usign the 18" Simmons :D
As more cars appear in the class, LOL watch the whining start:)
  • 1 month later...
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
    • I haven’t yet cut the chassis, maybe I switch to a reverse flow. I’ve got the Intercooler mounted as I already had it but not cut yet. Might have to speak to an engineer
