  • 4 weeks later...
Rotorua Import Pro Shop (RIPS) - Stock internal Long motor,
POWER FC Pro
RIPS Plenum,
Stock throttlebody
Z32 AFM
Blitz Pod
Turbosmart T Piece controlling boost
XR6 Turbo - GT3540 IW with the 1.06 rear Standard Flapper and actuator
Custom Dump into Kakimoto JASMA Catback
Boost Worx Stainless Highmount,
Just Jap GTR Style 100mm Cooler
3" Cooler piping
HKS Cam Gears (Not yet installed)
Tial 50mm BOV
550cc Sard Injectors
Bosch 044 and ARE Surge setup
Maxed out the brand new Z32 @ 255kw which is disappointing but the car does feel really good :P
Clutch needs to be upgraded again before i go any further anyway so once i get that sorted it will be more boost and more power
FYI Car was tuned by Sam (DrDrift) and i have gotta say I would not hesitate to recommend him to anyone - Great tuner and a great guy
I only had 2 hours of tuning with him if he had of had more time available we coulda started messing around with AFM's but I just said get it driving nice for me and i will sort it out for when he next does a QLD tour
Edited by dano4127
did some dyno work yesterday.lol
p.s. figures are bhp @ the flywheel.
well some of you know the car by now, and as i have have fitted a new turbo it was time for a tweek on the map..
still got some misfire issues and could only run 1.9 bar boost, but heres, the graph.
spec is.
rb30 block fully prepped with spool rods and cp forged pistons
n1 oil/water pumps,
jun stage one cams 264/272 9.7mm lift
1000ccs injectors,
twin in-tank tomei pumps feeding both ends of the rail, 8mm return to tank fitted.
gt4094r turbo, 50mm turbosmart gate, 4" downpipe.
plus usual bits lol.
Edited by rockabilly
R33 with 26/30. HKS cams, standard throttle body, 1000cc Sards, Single 044, Dash 8 fuel lines, surge tank etc, Headwork, Larger exhaust valves, N1 Oil pump, 42R huffer.
Made 525rwhp (390rwkw) on 18psi and pump fuel. Having spark problems so will need splitfires or better.
In R34 road car with full interior etc
R.I.P.S RB30, forged internals
R.I.P.S RB26 head, tomei 290 cams
GT42 turbo
900kw (1200hp) at engine, best measured at 4 wheels on rolling road with wheelspin 720awkw (960awhp)
First time I'd ever driven the car was its first ever pass at the drags:
Should run low 9s with some practice and she weighs 1740kg.
Rob
  • 2 months later...
  • 2 months later...
RB25/30 Series 1 R33
Tomei 256 Deg Poncams
550cc injectors
Custom 20mm fuel rail
CP Forged Pistons and Rings
Haltech E6K - shortly for sale !
ECU limited to semi-sequential ignition
High flowed stock turbo - OP6 Hitachi internals - 500 hp bb core
Single 911T fuel pump and surge tank
Heavy duty clutch
Series 2 gear box
My first results (Post #8) were done on a Hub Dyno and power converted to flywheel kw. Would have been around 220 rwkw.
Now making 273 rwkw and 971 Nm torque with the cams , injectors and 20 psi.
Booked in next week for ECU upgrade - Haltech Sport 2000
Gonna tune with full sequential ignition
Also replacing stock plenum with a Plazmaman + 72mm throttle body
Will be interesting to see how much we'll get out of this turbo - for sale later this year !
Also planning on a GT3071R/0.83 AR and tuned manifold in a few months.
Edited by conan7772
  • 3 weeks later...
My turn;
Full built motor, jun oil pump etc
^^^Thats the old motor and setup.
Here's the current setup;
-Stock head ports
-Tomei cams 270 IN and EX, 10.25mm lift IN and EX
-Tomei buckets
-Tomei springs
-Tomei head restrictor
-Adj cam gears (still set to zero though :P )
-Mahle 87mm pistons
-Spool rods
-ACL Race bearings
-Fully prepped crank inc collar
-JUN oil pump
-N1 water pump
-Fully prepped block (no hardbloc used)
-BCNR33 N1/24U balancer
-Custom 8plus litre oil sump (baffles, gates etc)
-Alloy radiator
-Header tank
-Splitfires
-Custom fuel rail
-1000cc injectors
-3 x Bosch 044's and custom lines, speedflow fittings, huge undercar surge tank etc
-Nismo adjustable FPR
-ARC airbox
-ARC intercooler, Hard pipe kit
-HKS thermostat controlled oil cooler and relocator
-HKS GTRS Turbo kit (ceramic coated)
-Stock GTR manifolds (ceramic coated)
-Tomei dumps (ceramic coated)
-HKS front pipes (ceramic coated)
-Oil return from head
-All balanced of course!
Plus the rest of the usual gear (R3C Osgiken clutch, ProfecB specII EBC etc)
Had dramas with a recently purchased Autronic so tuned on old ECU. Limited to 18psi due to map resolution, tune took all of 45minutes in total. Will retune as soon as the Autronic is fixed and increase boost and ignition, also cams will be dialled in.
This graph is torque vs power; Needs more boost, but is already MUCH more usable then the old setup
New motor and turbo setup is already coming together, wont be long now until its in the car and tuned :blink:
  • Like 1
Car back on the road and run-in tune tweaked a little.
Still a run-in tune.
rb30det + GT3076R = BEST "all round" COMBO: Just ask Cubes :blink:
Just realised that i haven't updated my results.
Officially the engine is now out flowing the turbo, but i will not change the combo for anything.
Below is my full tune as it stands now.
The car has been booked in for next week to get the following done:
- Change exhaust and see if any gains are made. Currently i have the more quiet exhaust fitted and would like to compare this result with the Apexi cannon exhaust system i have laying around.
- Play with my cam gears. I still have VVT active, but have modified the std gear to also be adjustable.
- Clean up the afr. Dips too low up in the higher rev range.
- Play with the boost settings, to come on harder on high boost.
- Most important: Find a pair of tyres that will hold traction on the dyno. So far i have tried 4 different pairs of tyres and all have lost traction on full boost at high rpm. I have tried: Hankook K104's, Bridgestone RE55s, Toyo T1R's and another pair of cheap ass tyres from another 33. Anyone know of a good pair of dyno tyres????
OS RB32/26
OS Rods
CP Custom pistons
Modified Pins
Nisspeed Sleeves
Nisspeed Spec Head
Nisspeed Spec Cams
Garrett -10's
Dry Sump
Motec M800
MSD coils
832hp @ 8290rpm and 22psi (maybe a little more in her)
Also 649ftlb torque at 5000rpm and 300ftlb @ 2900 and 400+ @ 4000
This is actually John Munro's new engine for his track GTR...don't even think he knows the results yet
Edited by BoostdR
  • Like 1
RIPS RB30/26 streetable engine
Stock RIPS prepped 2wd block, no filler or braces, fully water cooled.
Stock RIPS prepped crank
RIPS 2wd wet sump, tomei oil pump
RIPS RB26 head, brand new with tomei parts
RIPS inlet plenim with 90mm TB
RIPS custom exhaust manifold
GT45 turbo
Twin turbosmart 50mm progates
75hp NOS kit
1100whp @ 9000rpm, 2 bar on C16, 8.05 @ 172.3mph
Rob
  • 5 weeks later...
25/30 + high flow
As before (post 70) but,
New Haltech Sport 2000 installed.
Full sequential ignition.
Cross over induction removed.
Front faceing Plazmaman plenum and 72mm throttle body.
Engine now quite louder, sounds angry through the plenum.
Gained an extra 11.4 kw and 3 N.M. torque.
Now 284 rwkw and 974 Nm.
Had to turn down boost in 1st and 2nd.
Turbo hits too quick and hard.
3rd gear is outstanding. Get to 4000 rpm, cams start to work, brutal.
Here's the absolute limit of a high flow T28
Edited by conan7772
GT45 turbo
75hp NOS kit
1200whp @ 9000rpm, 2.1 bar on C16, 7.86 @ 177.4mph
  • Like 1
  • 4 weeks later...
RB25/30 - 1997 series 2 R33 GTS25T
- Ported R32 RB25DE head
- 20thou+ sleeved series 2 RB30 block
- CP pistons
- Nissan factory rings
- Custom modified imported Chev V8 billet rods....chunky !
- cyro-ed & balanced crank with modified oil drive collar
- Tomei bearings
- Tomei oil pump
- N1 water pump
- Custom grind hush-hush-spec cams
- Tomei cam gears
- Custom GCG-built Garrett GT3566R bb turbo - 1.06 rear housing
- Custom ceramic-coated steam pipe turbo manifold
- TiAL wastegate
- Wastegate plumbed back into 3inch exhaust
- 3 inch stainless exhaust with high-flow cat (by Liverpool Exhaust)
- TiAL BOV
- Custom Mr Enforcer high volume inlet plenum with 80mm Ebay billet throttlebody (works a treat ! no play no problems what so ever)
- Dedicated oil return for head
- Flojet 12v oil drain pump for turbo
- Twin fan-forced PWR oil coolers
- Excedy twin plate clutch
- Haltech E11V2 ECU
- Modified RB25DET harness
- Spitfire coils
- 800cc Sard injectors
- Sard FPR
- 3x Bosch 044 with surge tank
- Wait for it ...... $99 EBAY CHINESE EL-CHEAPO FMIC !!! (Yes ! you read right ! This was probably the very first mod on this car and she's still kickin along!)
Last dynoed 14 months ago 432rwkw and 437rwkw using home-brew Toluene (approx 30% by volume) & 98
Engine will be rebuilt & re-dynoed when I put her in for a re-spray in 6 weeks. Will post dyno graph.
Edited by smok74
  • 1 month later...
rb30 block
ported RB26 head & exhaust manifolds
Garrett low mount -10's
RIPS custom sump
Cometic head gasket
Mahle piston & ring set
Argo rods
Camtech/Kelford billet cams
Performance valve springs
ARP main/head studs
N1 oil/water pump
Bosch 044 lift pump with 2 external Bosch 044's & surge tank
PFI dual entry fuel rail
Delphi Rochester 1000cc injectors
Ross Metal Jacket harmonic balancer
OS Giken cam gears
Power FC
Run-in tune = 270.9awkw @ 6500rpm on 10psi (cams are @ 0degrees).
...i will post final results after my full power run tune!
Marko.
    • Any update on this one? did you manage to get it fixed?    i'm having the same issue with my r34 and i believe its to do with the smart entry (keyless) control module but cant be sure without forking out to get a replacement
    • So this being my first contribution to the SAU forums, I'd like to present and show how I had to solve probably one of the most annoying fixes on any car I've owned: replacing a speedometer (or "speedo") sensor on my newly acquired Series 1 Stagea 260RS Autech Version. I'm simply documenting how I went about to fix this issue, and as I understand it is relatively rare to happen to this generation of cars, it is a gigantic PITA so I hope this helps serve as reference to anyone else who may encounter this issue. NOTE: Although I say this is meant for the 260RS, because the gearbox/drivetrain is shared with the R33 GTR with the 5-speed manual, the application should be exactly the same. Background So after driving my new-to-me Stagea for about 1500km, one night while driving home the speedometer and odometer suddenly stopped working. No clunking noise, no indication something was broken, the speedometer would just stop reading anything and the odometer stopped going up. This is a huge worry for me, because my car is relatively low mileage (only 45k km when purchased) so although I plan to own the car for a long time, a mismatched odometer reading would be hugely detrimental to resale should the day come to sell the car. Thankfully this only occurred a mile or two from home so it wasn't extremely significant. Also, the OCD part of me would be extremely irked if the numbers that showed on my dash doesn't match the actual ageing of the car. Diagnosing I had been in communication with the well renown GTR shop in the USA, U.P.garage up near University Point in Washington state. After some back and forth they said it could be one of two things: 1) The speedometer sensor that goes into the transfer case is broken 2) The actual cluster has a component that went kaput. They said this is common in older Nissan gauge clusters and that would indicate a rebuild is necessary. As I tried to figure out if it was problem #1, I resolved problem #2 by sending my cluster over to Relentless Motorsports in Dallas, TX, whom is local to me and does cluster and ECU rebuilds. He is a one man operation who meticulously replaces every chip, resistor, capacitor, and electronic component on the PCB's on a wide variety of classic and modern cars. His specialty is Lexus and Toyota, but he came highly recommended by Erik of U.P.garage since he does the rebuilds for them on GTR clusters.  For those that don't know, on R32 and R33 GTR gearboxes, the speedometer sensor is mounted in the transfer case and is purely an analog mini "generator" (opposite of an alternator essentially). Based on the speed the sensor spins it generates an AC sine wave voltage up to 5V, and sends that via two wires up to the cluster which then interprets it via the speedometer dial. The signal does NOT go to the ECU first, the wiring goes to the cluster first then the ECU after (or so I'm told).  Problems/Roadblocks I first removed the part from the car on the underside of the transfer case (drain your transfer case fluid/ATF first, guess who found out that the hard way?), and noted the transfer case fluid was EXTREMELY black, most likely never changed on my car. When attempting to turn the gears it felt extremely gritty, as if something was binding the shaft from rotating properly. I got absolutely no voltage reading out of the sensor no matter how fast I turned the shaft. After having to reflow the solder on my AFM sensors based on another SAU guide here, I attempted to disassemble the silicone seal on the back of the sensor to see what happened inside the sensor; turns out, it basically disintegrated itself. Wonderful. Not only had the electrical components destroyed themselves, the magnetic portion on what I thought was on the shaft also chipped and was broken. Solution So solution: find a spare part right? Wrong. Nissan has long discontinued the proper sensor part number 32702-21U19, and it is no longer obtainable either through Nissan NSA or Nissan Japan. I was SOL without proper speed or mileage readings unless I figured out a way to replace this sensor. After tons of Googling and searching on SAU, I found that there IS however a sensor that looks almost exactly like the R33/260RS one: a sensor meant for the R33/R34 GTT and GTS-T with the 5 speed manual. The part number was 25010-21U00, and the body, plug, and shaft all looked exactly the same. The gear was different at the end, but knowing the sensor's gear is held on with a circlip, I figured I could just order the part and swap the gears. Cue me ordering a new part from JustJap down in Kirrawee, NSW, then waiting almost 3 weeks for shipping and customs clearing. The part finally arrives and what did I find? The freaking shaft lengths don't match. $&%* I discussed with Erik how to proceed, and figuring that I basically destroyed the sensor trying to get the shaft out of the damaged sensor from my car. we deemed it too dangerous to try and attempt to swap shafts to the correct length. I had to find a local CNC machinist to help me cut and notch down the shaft. After tons of frantic calling on a Friday afternoon, I managed to get hold of someone and he said he'd be able to do it over half a week. I sent him photos and had him take measurements to match not only the correct length and notch fitment, but also a groove to machine out to hold the retentive circlip. And the end result? *chef's kiss* Perfect. Since I didn't have pliers with me when I picked up the items, I tested the old gear and circlip on. Perfect fit. After that it was simply swapping out the plug bracket to the new sensor, mount it on the transfer case, refill with ATF/Nissan Matic Fluid D, then test out function. Thankfully with the rebuilt cluster and the new sensor, both the speedometer and odometer and now working properly!   And there you have it. About 5-6 weeks of headaches wrapped up in a 15 minute photo essay. As I was told it is rare for sensors of this generation to die so dramatically, but you never know what could go wrong with a 25+ year old car. I HOPE that no one else has to go through this problem like I did, so with my take on a solution I hope it helps others who may encounter this issue in the future. For the TL;DR: 1) Sensor breaks. 2) Find a replacement GTT/GTS-T sensor. 3) Find a CNC machinist to have you cut it down to proper specs. 4) Reinstall then pray to the JDM gods.   Hope this guide/story helps anyone else encountering this problem!
    • So this being my first contribution to the SAU forums, I'd like to present and show how I had to solve probably one of the most annoying fixes on any car I've owned: replacing a speedometer (or "speedo") sensor on my newly acquired Series 1 Stagea 260RS Autech Version. I'm simply documenting how I went about to fix this issue, and as I understand it is relatively rare to happen to this generation of cars, it is a gigantic PITA so I hope this helps serve as reference to anyone else who may encounter this issue. NOTE: Although I say this is meant for the 260RS, because the gearbox/drivetrain is shared with the R33 GTR with the 5-speed manual, the application should be exactly the same. Background So after driving my new-to-me Stagea for about 1500km, one night while driving home the speedometer and odometer suddenly stopped working. No clunking noise, no indication something was broken, the speedometer would just stop reading anything and the odometer stopped going up. This is a huge worry for me, because my car is relatively low mileage (only 45k km when purchased) so although I plan to own the car for a long time, a mismatched odometer reading would be hugely detrimental to resale should the day come to sell the car. Thankfully this only occurred a mile or two from home so it wasn't extremely significant. Also, the OCD part of me would be extremely irked if the numbers that showed on my dash doesn't match the actual ageing of the car. Diagnosing I had been in communication with the well renown GTR shop in the USA, U.P.garage up near University Point in Washington state. After some back and forth they said it could be one of two things: 1) The speedometer sensor that goes into the transfer case is broken 2) The actual cluster has a component that went kaput. They said this is common in older Nissan gauge clusters and that would indicate a rebuild is necessary. As I tried to figure out if it was problem #1, I resolved problem #2 by sending my cluster over to Relentless Motorsports in Dallas, TX, whom is local to me and does cluster and ECU rebuilds. He is a one man operation who meticulously replaces every chip, resistor, capacitor, and electronic component on the PCB's on a wide variety of classic and modern cars. His specialty is Lexus and Toyota, but he came highly recommended by Erik of U.P.garage since he does the rebuilds for them on GTR clusters.  For those that don't know, on R32 and R33 GTR gearboxes, the speedometer sensor is mounted in the transfer case and is purely an analog mini "generator" (opposite of an alternator essentially). Based on the speed the sensor spins it generates an AC sine wave voltage up to 5V, and sends that via two wires up to the cluster which then interprets it via the speedometer dial. The signal does NOT go to the ECU first, the wiring goes to the cluster first then the ECU after (or so I'm told).  Problems/Roadblocks I first removed the part from the car on the underside of the transfer case (drain your transfer case fluid/ATF first, guess who found out that the hard way?), and noted the transfer case fluid was EXTREMELY black, most likely never changed on my car. When attempting to turn the gears it felt extremely gritty, as if shttps://imgur.com/6TQCG3xomething was binding the shaft from rotating properly. After having to reflow the solder on my AFM sensors based on another SAU guide here, I attempted to disassemble the silicone seal on the back of the sensor to see what happened inside the sensor; turns out, it basically disintegrated itself. Wonderful. Not only had the electrical components destroyed themselves, the magnetic portion on what I thought was on the shaft also chipped and was broken. Solution So solution: find a spare part right? Wrong. Nissan has long discontinued the proper sensor part number 32702-21U19, and it is no longer obtainable either through Nissan NSA or Nissan Japan. I was SOL without proper speed or mileage readings unless I figured out a way to replace this sensor. After tons of Googling and searching on SAU, I found that there IS however a sensor that looks almost exactly like the R33/260RS one: a sensor meant for the R33/R34 GTT and GTS-T with the 5 speed manual. The part number was 25010-21U00, and the body, plug, and shaft all looked exactly the same. The gear was different at the end, but knowing the sensor's gear is held on with a circlip, I figured I could just order the part and swap the gears. Cue me ordering a new part from JustJap down in Kirrawee, NSW, then waiting almost 3 weeks for shipping and customs clearing. The part finally arrives and what did I find? The freaking shaft lengths don't match. $&%* I discussed with Erik how to proceed, and figuring that I basically destroyed the sensor trying to get the shaft out of the damaged sensor from my car. we deemed it too dangerous to try and attempt to swap shafts to the correct length. I had to find a local CNC machinist to help me cut and notch down the shaft. After tons of frantic calling on a Friday afternoon, I managed to get hold of someone and he said he'd be able to do it over half a week. I sent him photos and had him take measurements to match not only the correct length and notch fitment, but also a groove to machine out to hold the retentive circlip. And the end result? *chef's kiss* Perfect. Since I didn't have pliers with me when I picked up the items, I tested the old gear and circlip on. Perfect fit. After that it was simply swapping out the plug bracket to the new sensor, mount it on the transfer case, refill with ATF/Nissan Matic Fluid D, then test out function. Thankfully with the rebuilt cluster and the new sensor, both the speedometer and odometer and now working properly!   And there you have it. About 5-6 weeks of headaches wrapped up in a 15 minute photo essay. As I was told it is rare for sensors of this generation to die so dramatically, but you never know what could go wrong with a 25+ year old car. I HOPE that no one else has to go through this problem like I did, so with my take on a solution I hope it helps others who may encounter this issue in the future. For the TL;DR: 1) Sensor breaks. 2) Find a replacement GTT/GTS-T sensor. 3) Find a CNC machinist to have you cut it down to proper specs. 4) Reinstall then pray to the JDM gods.   Hope this guide/story helps anyone else encountering this problem!
    • perhaps i should have mentioned, I plugged the unit in before i handed over to the electronics repair shop to see what damaged had been caused and the unit worked (ac controls, rear demister etc) bar the lights behind the lcd. i would assume that the diode was only to control lighting and didnt harm anything else i got the unit back from the electronics repair shop and all is well (to a point). The lights are back on and ac controls are working. im still paranoid as i beleive the repairer just put in any zener diode he could find and admitted asking chatgpt if its compatible   i do however have another issue... sometimes when i turn the ignition on, the climate control unit now goes through a diagnostics procedure which normally occurs when you disconnect and reconnect but this may be due to the below   to top everything off, and feel free to shoot me as im just about to do it myself anyway, while i was checking the newly repaired board by plugging in the climate control unit bare without the housing, i believe i may have shorted it on the headunit surround. Climate control unit still works but now the keyless entry doesnt work along with the dome light not turning on when you open the door. to add to this tricky situation, when you start the car and remove the key ( i have a turbo timer so car remains on) the keyless entry works. the dome light also works when you switch to the on position. fuses were checked and all ok ive deduced that the short somehow has messed with the smart entry control module as that is what controls the keyless entry and dome light on door opening   you guys wouldnt happen to have any experience with that topic lmao... im only laughing as its all i can do right now my self diagnosed adhd always gets me in a situation as i have no patience and want to get everything done in shortest amount of time as possible often ignoring crucial steps such as disconnecting battery when stuffing around with electronics or even placing a simple rag over the metallic headunit surround when placing a live pcb board on top of it   FML
    • Bit of a pity we don't have good images of the back/front of the PCB ~ that said, I found a YT vid of a teardown to replace dicky clock switches, and got enough of a glimpse to realize this PCB is the front-end to a connected to what I'll call PCBA, and as such this is all digital on this PCB..ergo, battery voltage probably doesn't make an appearance here ; that is, I'd expect them to do something on PCBA wrt power conditioning for the adjustment/display/switch PCB.... ....given what's transpired..ie; some permutation of 12vdc on a 5vdc with or without correct polarity...would explain why the zener said "no" and exploded. The transistor Q5 (M33) is likely to be a digital switching transistor...that is, package has builtin bias resistors to ensure it saturates as soon as base threshold voltage is reached (minimal rise/fall time)....and wrt the question 'what else could've fried?' ....well, I know there's an MCU on this board (display, I/O at a guess), and you hope they isolated it from this scenario...I got my crayons out, it looks a bit like this...   ...not a lot to see, or rather, everything you'd like to see disappears down a via to the other side...base drive for the transistor comes from somewhere else, what this transistor is switching is somewhere else...but the zener circuit is exclusive to all this ~ it's providing a set voltage (current limited by the 1K3 resistor R19)...and disappears somewhere else down the via I marked V out ; if the errant voltage 'jumped' the diode in the millisecond before it exploded, whatever that V out via feeds may have seen a spike... ....I'll just imagine that Q5 was switched off at the time, thus no damage should've been done....but whatever that zener feeds has to be checked... HTH
