Wow, they are some nice brakes....
I got DBA4000's fitted to my car not long ago and i have to say they are much better than my old, warped brakes. They werent standard R32 GTR brakes I dint think because the were cross drilled. These look so poor compared to those AP's and Brembos :domokun:
  • 1 year later...
hey brian. thanks heaps for sorting out my teathing problems with my f40 brembos and your custom 355mm two piece rotors on my gtr.
still shakes a little but is bearable.
ps. im getting some k-type alcons to replace the brembos so i can sell te old set up as a complete kit.
I have a set of Brembo F50's (355mm) on my R32 GTR and they are a $5000 proposition for the fronts only.
Definate improvements in feel on the track however standard Brembo pads seem a little more road than track orientated.
What type of aluminum are AP calipers made from? Are they forged? heat treated? cast then machined or billet?
They are a 2 piece caliper. So the material grade is less important than for a 1 piece as the steel through bolts are ALOT stronger & stiffer at elevated temps.
Try the APRacing website.
Brian, What would you use to duct cool air to the rotors, mine seem to get hot and cause a bit of fading by the end of 3 hot laps.
Cheers
Paul
Good question, i'm interested in ducting as well..... and what people have done.
    • It would be different if the sealant hadn't started to peel up with gaps in the glue about ~6cm and bigger in some areas. I would much prefer not having to do the work take them off the car . However, the filler the owner put in the roof rack mount cavities has shrunk and begun to crack on the rail delete panels. I cant trust that to hold off moisture ingress especially where I live. Not only that but I have faded paint on as well as on either side of these panels, so they would need to come off to give the roofline a proper respray. My goal is to get in there and put a healthy amount of epoxy instead of panel filler/bog and potentially skin with carbon fiber. I have 2 spare rolls from an old motorcycle fairing project from a few years back and I think it'd be a nice touch on a black stag.  I've seen some threads where people replace their roof rack delete with a welded in sheet metal part. But has anyone re-worked the roof rails themselves? It seems like there is a lot of volume there to add in some threads and maybe a keyway for a quick(er) release roof rack system. Not afraid to mill something out if I have to. It would be cool to have a cross bar only setup. That way I can keep the sleek roofline that would accept a couple bolts to gain back that extra utility  3D print some snazzy covers to hide the threaded section to be thorough and keep things covered when not using the rack.
    • Probably not. A workshop grade scantool is my go to for proper Consult interrogation. Any workshop grade tool should do it. Just go to a workshop.
