Upgrade Log
ToDo:
Add bug tracker
Complete 'how to use this site' documentation
Add contact links page for club and site contacts
Add group images (Shan)
Add header to Gallery
New Banner software (better performance)
Add Hover Preview (disabled due to issues)
Changelog:
Photopost upgraded to 5.3 (22/02/06)
Invision Powerboard upgraded to 2.1.4 (22/02/06)
Invision Blog upgraded to 1.2.2 (22/02/06)
Removed 4 unused styles (22/02/06)
Installed Help Desk (22/02/06)
Installed Topic Preview Hover to default style (22/02/06)
Added new banner script to default style (22/02/06)
Created firefox search plugin (22/02/06) - link can be found on search results page
Added non-default styles (25/02/06)
Changed email notification subject lines (Shan) (25/02/06)
Added Trader Ratings (27/02/06) (Currently importing existing data)
Add Smilies pack (27/02/06)
https://www.sau.com.au/forums/topic/106812-sau-upgrade-log/
  • Replies 178
you never used to have to click fast reply. always used 2 be there.
and why does it put all your posts in one?
like... say you post, then post again before someone else has posted. it puts them all in one post ;)? never used 2 do that.
https://www.sau.com.au/forums/topic/106812-sau-upgrade-log/#findComment-1970706
Just a couple of small points.
* Forum topic emails now no longer have the topic in the email subject.
* For a long time, emails informing of a PM waiting have read You have a new personal message from "" (i.e. it doesn't actually say who its from). If you're fiddling, can you perhaps see if you can get the senders name to appear.
* I use the thread tracking feature a lot. When I click on 'Track Thread', the default option selected is always "Delayed Emailed Notification". Is there a preference that can be exposed that allows me to set the default to some other option (namely "Immediate Email Notification")?
Cheers,
Lucien.
https://www.sau.com.au/forums/topic/106812-sau-upgrade-log/#findComment-1971436
I have email subscription setup to default to immediate. I turn it off for whore threads.
But I have noticed since the upgrade for every post in a thread that I have immediate email subscription, I recieve 3 emails with the exact same thing in it...?
https://www.sau.com.au/forums/topic/106812-sau-upgrade-log/#findComment-1971504
when they changed that a while ago to make the subjects show up...it was a lot better that way...was easy to delete multiple notifications for the same thread and just click 1 link then read the thread...
hopefully we can go back to that? not a fan of the way it is after this upgrade...
https://www.sau.com.au/forums/topic/106812-sau-upgrade-log/#findComment-1971852
like... say you post, then post again before someone else has posted. it puts them all in one post :P? never used 2 do that.
Its to stop people like Dezz from posting 50 times in a row to increase post count.
https://www.sau.com.au/forums/topic/106812-sau-upgrade-log/#findComment-1971925
Hey Christian,
Only thing im finding really annoying, when quoting or using the more options you can just hit TAB then ENTER to make the post.. you have to scroll down then click it... any way this can be changed?
or I could just get used to using ALT + S
https://www.sau.com.au/forums/topic/106812-sau-upgrade-log/#findComment-1972083
god damn the preview post thing is annoying in the for sale section... takes up the whole link and you cant even get into the thread...
You use Firefox?
Hey Christian,
I have always used ALT+S, didnt know it was the default tab. I'll see what I can do during tonights maintenance.
https://www.sau.com.au/forums/topic/106812-sau-upgrade-log/#findComment-1972085
    • That's not a transistor --- it's marked ZD1 which makes it a zener diode. As to what the breakdown voltage is, not enough there to divine.
    • Hi all, Long time since I've posted here. Looking for some advice on what I can remove to further identify the cause of my issues.  I can move the passenger seat forward and back but the knob used to adjust the seat angle is pretty much free spinning, there's very little resistance.  Removing the side cover I can see that the chain is intact but the shaft for the adjustment spins without the gear attached to it moving.  What's my next step for disassembly here? Is this a common fault? Just being a little cautious as I didn't want to start removing bolts for a spring to fly out or something equally as stupid.  Cheers
    • The incentives are mostly the same, yes. Ethanol is cheap compared to the cost of doing 98-100 RON with crude oil alone. 87 to 93-94 AKI all with E10. In 2020 Canada mandated E10 as a part of their "renewable fuel standard" and is supposedly going to go to E15 in 2030. In California where there are only 8 refineries with two threatening to shut down next year it's been over 20 years now of E10 and 91 AKI maximum because there's just not enough refinery capacity or crude oil supply relative to the demand for premium unleaded fuel. And CARB's low carbon fuel standard means functionally none of the diesel available at the pump is made from crude oil anymore. It's almost all entirely 20% biodiesel blended with 80% renewable diesel (hydrotreated vegetable oil) now. The number of gasoline vehicles that support E15 or higher ethanol concentrations is surprisingly low, I can't imagine it being wise to play tricks like this without flex fuel sensors in most of the fleet.
    • It's almost certainly the same as the one next to it. Have a fish around amongst these hits https://www.google.com/search?q=surface+mount+transistor+m33&sca_esv=9cb49794e0b2005d&source=hp&ei=2vJ5aNjTB7Kw0PEPldnS8QM&iflsig=AOw8s4IAAAAAaHoA6qkfmF6XcygtrZ4Vu9f92NXF_RFd&ved=0ahUKEwjYqIPP7MWOAxUyGDQIHZWsND4Q4dUDCA8&uact=5&oq=surface+mount+transistor+m33&gs_lp=Egdnd3Mtd2l6IhxzdXJmYWNlIG1vdW50IHRyYW5zaXN0b3IgbTMzMgUQIRigATIFECEYoAEyBRAhGKABMgUQIRigAUjKCFAAWABwAHgAkAEAmAHfAaAB3wGqAQMyLTG4AQPIAQD4AQL4AQGYAgGgAuYBmAMAkgcDMi0xoAfMBLIHAzItMbgH5gHCBwMyLTHIBwU&sclient=gws-wiz
    • South Australia, which is hardly as far behind as the rest pf Oz makes out, and who is also not a paragon of progressiveness (read that as over-legislation) in the area of vehicle standards, has this to say on the subject: Adjustable coil-over suspension Aftermarket adjustable coil-over suspension components are suspension units that incorporate an external thread on the main body and corresponding threaded spring saddle that allows the vehicle's suspension height to be varied. If fitting aftermarket or coil-over suspension components you must submit an Application to modify a light motor vehicle form and a report from a light vehicle engineering signatory (LVES).
