Yes a number of people are having trouble posting.
What is happening for me and some others is that you click post and the post actually gets recorded straight away but the window doesn't refresh with the new post.
I have tested this by using a different window and going to the thread straight after posting where I can see my post even though in the other window the hour glass is still turning over and it looks almost like you haven't pressed post.
People are double posting a bit cos of this.
thanks again guys.
  • Replies 178
The 'View New Posts' function is broken for me. Keep getting this message:
"Sorry, but we did not find any matches to display. Try again and broaden your search criteria. If you were searching for new posts since your last visit, it's possible that there are none to show."
....but there are certainly new posts, and doesn't matter how long I leave between tries.
Same result with IE or Firefox.
:P I have the same problem!
Me too
are people still now missing PM's?
D_I_F - reckon you could supply more info cause you seemed to post in here ok.
C
yeah, stupid IE sucks balls.. FF is fine.
I'll see whats happening.
i updated my sig for you IE'ers to make the transition easier.
using FF and the "view new posts" dosen't seem to work... so will be looking into that after the weekend. its something I use personally more than anything else on this forum.
interesting... when I change between skins the number of PM's I can see changes.
Although I get the same error regardless of what skin I use, as fas a new post search is concerned.
The new posts issue must related to dates and times somehow. The most recent post in a search I did at 9.41 tonight was "Yesterday, 01:25 PM"
Oldest post was "1st March, 2006 - 08:42 PM" and my last visit was "your last visit was: Yesterday, 09:42 PM"
all messed up.
    • Block bump. $400. As above cyl 6 needs bore or sleeve.
    • I would think making the argument that the travel is limited by a spring flexing against a spring perch as "the same method". Later on in the document they do state that the spring can't bind on full bump travel and cannot come loose in full rebound travel as well. (which is all very sensible). The laws are actually pretty sensible and reasonable. It's just that the people who enforce and check them don't actually read them or know them accurately. "Oh, coilovers? Instant fail mate. Don't even need to look at it." - Guy who will be instantly reported by me. There is probably merit to people who do get defected for height also get defected for the suspension in that state that allows it. I did never consider the people who are complaining about coilovers being picked on are also running around at 50mm off the floor.
    • I think given SAU's knowledge of E85 we can strongly conclude that 10% ethanol in almost any situation is entirely fine. Almost all of the myths against E85 were overblown, let alone E10.
    • From your link See bold text, is this referring to damper settings, if so that may a issue for "some" inspectors, I cannot see aftermarket coilovers having the evidence that "must be available that its functional performance is equivalent to the original" Maybe just remove the adjustment knows and hope for the best???? Meh 5.2 Suspension travel In all instances, modifications to a vehicle’s suspension must ensure the integrity of the system and not compromise the ride quality. At least two thirds of the original suspension travel should be maintained in both directions (rebound (i.e. extension) and bump (i.e. compression)), and rebound must be limited by the same method used by the vehicle manufacturer or if this is not practicable due to the nature of the modification, an equivalent method. If an alternative method is used, evidence must be available that its functional performance is equivalent to the original.
    • They actually don't - They adhere to VSB14 rules just like Victoria. The rules are against CABIN adjustable height, and it quite clearly states that the height has to be within parameters. I asked the VASS engineer to confirm this when I got my car engineered and they refused to engineer the coilovers because they didn't meet the requirements for requiring engineering. (mine are height adjustable.) People "Not wanting to bother" with "Actually reading/knowing/adhering to the rules" should result in fines and immediately losing the ability to issue blue slips and/or RWC's in Vic.
