  • Replies 75
  • 3 weeks later...
Here are some pix of the RB34 stroker:
The crank still needs the main journals ground, then final balance, shotpeen, nitride, and give it a good polish and clean.
Any comments or questions appreciated.
Chris
The crank is a customised standard item, the rods are custom h beams but the pistons are off the shelf .040" OS (87mm) with a 22mm pin.
I will post up some more pix of the crank when its done.
Ive taken all the casting dags off the webs of the crank, but now rust has formed on it from sitting around too long. :(
I might bore out an rb30 block soon, see what size bore i can sleeve it to aswell.
RB36 maybe???
ill probably get shot down for this but,
If your off your p's why bother?
Drop in a v8 if you dont like turbo 25's or 26's? Seems like a complete waste of money. Throw in a lexus v8 or something and they are about $1000!
Sorry I don't understand, if there is something im missing please feel free to tell me
even if the v8 is only $1000 you would still have all the other engineering costs of custom engine mounts, different gearbox or adaptor plate, wiring would be a pain. so the cost could end up being similar to building the rb34de
then in the end you dont end up with a skyline cus its not all nissan.
NA_r33 is different cus he used a nissan V8 :D
of all the N/A skyline motors rb30de has to be the best of the easyily built N/A. rb34de can only be better :laugh: plus the sound of the rb34.. mmmmmmmm
once he gets it all done. im sure if you went for a ride in it you would understand why he did it.
thats what i have done with all the people who said why you spending all that $$ just to run it as N/A. now they like it ;)
The reason i have developed an RB34:
Im an engine reconditioner so all the machining etc i do,
is to my standard and it doesnt cost me anything.
I am building 2 of these RB34's the other one will be a large single turbo (GT3540) and more than likely have full boost by 3000 RPM.
But if you dont understand ross80 then....
You obviously have some interest in a NA 6?
The strokers will be reliable - they are being built with new forged components with extra attention on radii with 20% more bearing area and other critical operations.
If you build/tune your turbo engine right u shouldnt destroy them....Obviously.
You keep blowing standard engines i assume?
ive been scared by some rb30e na before
the guy i bought my wheels off had full 2.5 exhaust, no cat and extractors, cam, xf tb proted plenum 3" intake, unifilter and no ac
i got a stocker rb30 with a bolt on turbo kit and i allmost lost to that :0 i was loaded up with people and wheels tho
I win out of the L series motors L24e injected upgrade fuel pump and injectors l26 nismo cams grinded for more Duration modified microtech d5 and double valve springs just need my flat top pistons hardened valves and extractors and i am finished conservative estimate 125kw current once finished probaly close to 150-160kw :O
I think theres another NA engine from Nissan that gets completely over-looked,
the VG30DE. I know it's a vee, but my NA sounds real sweet. :domokun:
With little mods you can get over 200kw @ flywheel.
Over engineered and tough as, with serious mods and Nos, who knows?
Stock internals on a TT can handle nearly 400+ kw.
All you need is big enough bay. >_<
ps; that yellow NA zed in those HPI dvds runs 10 sec 1/4.
the VG30DE. I know it's a vee, but my NA sounds real sweet. :P
All you need is big enough bay. :D
Using NOS like that Z has sortof makes it not an NA accomplishment, unfortunately. Also, the thread is specifically about straight 6s - not saying they are better.
  • 1 month later...
    • Brooooo Please send ABS control unit schematic Please! R33 gts25t ABS (Its two plug ecu, black and white) wire colors possible? [email protected]
    • Don't even try to run it on the stock ECU if you're going to have the boost controller bring boost above ~10 psi. I've already told you that. If you use the Nistune ECU, you will need to CAREFULLY read the available documentation for Neo tuning, and read some threads on the Nistune forums, to discover the various things you have to do to prevent the ECU from going bananas when the boost is too high. The is a table associated with th boost sensor that must be modified to prevent it from shitting the bed. This is just one of the things that you will need to do to the tune in Nistune, because the Neo turbo ECU will be expecting to see a number of things (such as the TCS) that are not there, and you have to block the DTCs on those. It is totally not surprising to me that you are having the problems that you are, but the solutions to these problems have been known for >15 years. So just get it done.
    • Hi. Sry iam not a mechanic and iam not at the car atm so i dont know 100% but they told they measure those and even try to change those. AFM they have two. Coils are new a they have my old one too. Plugs too. ECU...we have 25 NEO stock and Nistune 25 NEO.   But i dont know if any one those could be the problem and why/if/what can cause this, Only thing they did not check is fuel...but that walbro 255 is new(like 1,5 years)... That fuel pressure gauge idk...but i let them know Any suggestions?   EDIT: how can they know if it is like you say he ECU pull power when it reaches a specific boost level that is too high? Tha car has boost controler
    • Can you clarify what you mean by boost cut, do you mean it misfires both when under load (driving) and when stationary and out of gear? Or does the ECU pull power when it reaches a specific boost level that is too high (boost control issue)? Does it occur at idle with no throttle? When you say "the ECU is OK", what ECU is it and why do you think it is OK? Have you used the NEO ECU, and if so do you have a MAP sensor attached? Same for the AFM, why do you think it is OK? Do you have any way to put a fuel pressure gauge on it (even just a mechanical one between the fuel filter and fuel rail)?
