Ive just put a Power FC on an R33 Gtst along with a bigger turbo. Now since i finished putting the turbo and power fc in, when i rev the car in neutral it will either stall or the revs will start fluxuating. So when im pulling up to a set of light if i slow the car right down then put the clutch in its ok, but if i put it in while the revs are still up it will either stall or the revs will fluxuate.
We tuned it on the dyno like this but my tuner said it could be because i didnt have my factory BOV plumbed in. So i plumbed it back up to the intake and it didnt fix the problem at all. The only pipe i havent connected up on the BOV is this little thin one i think its called a 'hot pipe' or something.
Any help would be greatly appreciated.
Thanks, Mike.
https://www.sau.com.au/forums/topic/107387-car-stalling/
ensure the bov is connected as it was in the factory setup
without it, it will most likely stall each time.
if its still screwed and your idle sucks you can perform a factory reset to sort out the idle, but you will loose your tune if you do that so get someone to copy it for you before it gets done. but the bov will certainly make it still, incorrect or misconfigured
https://www.sau.com.au/forums/topic/107387-car-stalling/#findComment-1981299
you said you fitted a bigger turbo , did you also fit a new dump pipe? if so is the o2 sensor in the new pipe, it may also be damaged or blocked, even not plugged in. check all that also.
I had a similar issue but with everything stock - replaced the o2 sensor and hey bingo , no more stalling.
https://www.sau.com.au/forums/topic/107387-car-stalling/#findComment-1983776
stock bov has 2 things attached to it.
1.) vacuum line (connects to the little nipple on top of the bov). this line can be taken from many places.. try fuel pressure regulator line or one of many other vacuum lines near the plenum.
2.) the PLUMBACK hose.. it is the largish hose that goes from the front of the bov back to the air intake pipe.
you can see the plumback hose in this pic..
https://www.sau.com.au/forums/topic/107387-car-stalling/#findComment-1984539
Bought my car with a TurboSmart atmo BOV on it. Did the same thing, but only if I pulled up hard with the clutch slammed in and the brake on. Bought a used standard BOV, stuck it on, never looked back =-]
https://www.sau.com.au/forums/topic/107387-car-stalling/#findComment-1985903
hey guys thanks for the replies, i tried the standard computer last night and it still didnt fix it at all. So it must be something that has been tampered with since the conversion. All I can think of is the o2 sensor and the BOV. Ive plumbed in the BOV but i havent checked the o2sensor.
Is there any way of checking to see if it is working correctly?
I also had to replace the dump pipe so im gonna have a go at stuffing around with the O2 sensor. The O2 sensor seems to be pretty close to the back of the turbo ATM rather than down a little. Could this be a problem?
Thanks for all the replies, Mike.
https://www.sau.com.au/forums/topic/107387-car-stalling/#findComment-1988681
the 02 sensor will have nothing to do with your stalling. its used for closed loop feedback. if you still dont believe me go and unplug and drive around, nothing will change. it will simply waste a bit of fuel
https://www.sau.com.au/forums/topic/107387-car-stalling/#findComment-1989589
True that, i drove around knowingly for 30000 kms with a stuffed o2 sensor made no diff when i replaced it!
https://www.sau.com.au/forums/topic/107387-car-stalling/#findComment-1990595
    • I appreciate the detailed explanation, think I understand now. I spent the better part of last night reading what I could about shuffle and potential solutions. I had replaced the OEM twin turbo pipe with an alternate Y pipe that is separated further away from the turbo. The current one is from HKS and I had a previous pipe that was separated even further away, both have shuffle. I had heard that a divider can be welded in to the OEM pipe to remove turbulence, and figure that aftermarket pipes that are more separated would achieve the same thing. From what I read, most people with -10 turbos get shuffle due to their size, though it's a bit less common with -5s on a standard RB26. I think Nismoid mentioned somewhere it's because OEM recirculation piping is common in Australia with -5 cars. It seems that the recommendation tends to vary between a few options, which I've ordered in what I think is most feasible for me:  1. Retune the MAP or boost controller to try to eliminate shuffle 2. Install OEM recirculation piping 3. Something called a 'balance pipe' welded onto the exhaust manifolds. I don't know if kits for this are available, seems like pure fabrication work 4. simply go single turbo My current layout is as follows: Garrett 2860 -5s HKS Racing Suction intake MAF delete pipes HKS racing chamber intake piping hard intercooler piping,  ARC intercooler HKS SSQV BOV and pipe Haltech 2500 elite ECU and boost solenoid/controller HPI dump pipes OEM exhaust manifolds HKS VCAM step 1 and supporting head modifications Built 2.6 bottom end All OEM recirculation piping was removed, relevant areas sealed off I'll keep an eye out for any alternative solutions but can get started with this.  Only other question is, does shuffle harm the turbo (or anything else)? It seems like some people say your turbo shafts will explode because of the opposing forces after a while and others say they just live with it and adjust their pedal foot accordingly.
    • That worked out PERFECTLY! Thank you big time to JJ. He was able to swap me his stock diff. He drove all the way to me as well. Killer! Removal & install was pretty straightforward. The diff itself is HEAVY. So that’s a 2 man job.  Man does the car drive nice now! Couldn’t have worked out any better 👌
    • I'm interested,do you still have it?
