  • Replies 297
Posted Images
Just finished painting my rocker covers and re-doing my coilpack cover.
When i first got my car i painted my coilpack cover dark blue (it was meant to look anodized).
I took off my rocker cover to get them chromed, the realized how much that would cost.
Went down to repco and bought some paint and though F it, i'll do it myself.
So after a couple hours of sanding, a few coats of paint, and copious amounts of clear, i am ver happy i chose not to chrome them.
Pics don't do it justice.
1st pic - When i first sprayed my coil pack cover
2nd pic - After finishing rocker covers
3rd pic - re-sprayed coilpack cover
*Notice the difference in colour of the coilpack cover
looks good paul - cam covers look std only better haha
blue is definately better than the 2nd pic
is that the metal cast blue? post back if you encounter any discolouration issues with it if it is, i've used the red on a mates RB20 and it went orange after a few months ;)
so i went and redid them in powdercoat
is that the metal cast blue? post back if you encounter any discolouration issues with it if it is, i've used the red on a mates RB20 and it went orange after a few months :D
that looks really good man...
oh, and mine look heaps different to standard...
mainly coz of the clear coat... looks like plastic instead of metal.
i haven't ever had a problem with it before... so i really hope i don't now that you've said it...
im used to seeing cam covers in sandblasted form lol - instead of that little bit of goldish coating they have from the factory
nothing shows off those flakes and the colour than looking at it in person.
yeah might be a problem with the red and not the blue
  • 1 month later...
  • 2 months later...
Here is mine, done by the good ol Craved Coatings :D.
Shitty lighting so you can't really see it too well.
Doing the middle in a Wrinkle Black. Should be finished off this weekend. Will post pics up once its done :)
  • 3 weeks later...
    • http://calfinn.com.au/product/1500kg-standard-trolley-jack-cj-2t-c/1500kg-standard-trolley-jack-cj-2t-c   I have this and fits under a S3 33 GTR with no issues. Purchased in 2009 and not one issue. It was $950 back then. Not cheap but something so important isn’t worth cheaping out on.
    • Just trying to get my head around this. At 5psi of boost, you turn on your wmi pump, and then you're using a 3000cc injector, to allow flow upto the actual engine, where you have your 6x200cc injectors and a 500cc injector. If the above is correct, what advantage are you obtaining by having the 3000cc injector blocking flow, is this just incase a line breaks between that injector and the motor you can stop flow immediately? Or are the 6x200cc and 500cc less injectors and just spray nozzle?
    • Welcome! New member myself, but I had an R33 back in 2002. Best advice I could give, based on my experience: if you're running the factory turbo, be very conservative with boost. I made the mistake of just fiddling around with the boost controller and cranking the boost for fun, and the end result was my intake pipes popping off frequently from the constant deluge of oil that was being blown into the recirc by the stressed-out turbo, which itself was siphoning oil from the engine and farting it out both sides of its centre bearing (or something to that effect). If I could do it all again, I would have gotten a new turbo and had a tune dialled in professionally and then just left it alone! Funny you mention the metal shavings in the gearbox, as I had the same thing - the probe plug (magnetic drain plug, essentially) would come out caked with shavings. At least it was doing its job. Not sure if that's just sacrificial wear and part of the deal, or if my gearbox was shagged, but I wasn't abusing it. Enjoy the R33 - they're a dying breed, and if they weren't $35k+ on CarSales in Queensland, I might have picked up one of those again, instead of the 370GT I own now (though I'm loving the 370GT, that big 3.7L V6 just hits different).
    • Howdy folks. I owned an R33 back in 2002, which was thoroughly beyond my capacity (financially speaking) to maintain/insure, so we parted ways in 2004. Fast forward 21 years (to literally yesterday, in fact) and I'm now the proud owner of a 2007 V36 370GT. I'm happily surprised by how much power the VQ37VHR makes, compared to the RB25DET, considering the latter is turbocharged. I had planned to add a turbo at some point but I'm on the fence about whether I'll even need it (though I do love the sudden onset of extra torque). Any other 370GT owners around the traps, I'd love to hear about your experiences with this car (good and bad).
    • Perhaps the answer is... more jacks!* *proper jacks must be used.
