its munted, if it boots again be ready to get all the files off it quick smart.
data recovery programs usually only work if the drive works, try booting using Heirin (sp?) it has tools to fix up all major brand hard drives, might get her up n running again
i have a few paper weights like ur drive
I used to work in a computer shop and we used to wrap the drive in newspaper and chuck it in the freezer for 15 minutes or so. This seemed to give them a limited life to do some last minute grabbing.
That trick is limited to only a few models. Basically Seagate and a couple others started using a cheaper substrate for the IC's. Only problem is, once the substrate warmed up to 60'c, it became conductive causing a huge short circuit inside the HDD controller. Putting it in the freezer would cool the chip long enough to transfer any data off and onto a new drive.
-D
Luke I wouldn't even bother trying to boot off it again, you might really stuff it.
Pull it out and stick it into a machine that already has a boot drive and operating system in it then drag files across.
+1 to this. Your drive may only have an issue with the partition table. If you run a scandisk on the HDD from another drive you can sometimes recover it. At the least you'll want to find out if there are any reported errors from the drive itself.
-D
-D
We use that trick as well
but the HDD in antistatic bags and leave it in the freezer over night
and surprise surprise you can get possibly 30-45minutes of proper activity happening and get most data off that
after the 3rd or 4th time the HDD will be just as good as being under a 10 tonne press lol
thats how we destroy our work HDD's b***hes
might just be the MBR, does it get past post at all? if so u could fix it useing the windows disk
if it booted it wouldnt be MBR. MBR either works or doesn't.
Corrupt file tables will cause sporadic boot failure as data is written in places where it shouldnt be, or data is read from corrupted blocks.
-D
^^^ I've got the Logitech Pro9000 web cam - inbuilt mic, HD quality and great for skype HD video calls. Also, has some novelty features that your kids will like eg. a character face overlay that mirrors your expressions and face tracking. But, for something cheaper the Logitech S7500 has similar features to the above except no auto focus and slightly lower mp camera.
hrmm....I really like the twin pack idea and price of the Swann but I also like the hi-res capabilities of the Logitech Pro9000 & Orbit (Sphere) models
My vote is with logitech, since I've been using them for a long time. Theyre rock solid
-D
EB Games are having a massive sale atm fyi. Many games and other items are 2 for $50.
I picked up Assassin's Creed and Crysis Warhead for a grand total of $50 yesterday. Bargain - especially since Assassin's Creed was still priced at $89.94 and Warhead at $49.95.
Now I say good bye to another large chunk of my rarely available free time :D
+1, I have two of these, one for home and the other for work / on the road.
Great unit, never had any issues, GOOD quality video, not like most cams I've seen.
Not cheap, but webcams seem to be an item where you do get what you pay for.
hey Chops we should do another beer with Andrew sometime.
thanks for all the responses guys, I've checked a few reviews and am definitely leaning towards the logitech (buy it once I suppose)....just have to decide whether to get the Pro9000 or Orbit (Sphere)
If anyone here uses steam, just be careful of someone with the username Mor.B.Z.Wojtaz // zagram mixa // and if you get sent a link to here http://newsteams.tk/ - DO NOT LOG IN, its a scam website to steal your steam details. A mate received a message from him saying he had won a free copy of left4dead and GTA4, and to claim log into that site, but hopefully everyone here is smart enough.
Also on a side note, Pete, how are those hard drives?
    • Mixing things up - installed some leather recaros to match the leather seat covered rear seats. Interior looks pretty schmick now except for some slight wear on the steering wheel which I will monitor and address if it becomes worse or actually noticeable!
    • Didnt realise RB's had more then 1 head.
    • I'm normally copping my own abuse from neglecting my daily drivers. "Those suspension bushes will last a bit more", "Don't worry about the oil leak, just keep topping it up". The project cars I'm always doing things slowly on them as I'm wanting them to be done better, and neater, and nicer. Luckily I don't have to deal with 18 year old Matt's "Learning to wire" stuff in the project cars. And there's only one piece of wiring I'm displeased about in the Landcruiser, and it's about to be cut out... However, the box loads of parts that have been going through this place lately for the Landcruiser... Brake pads Brake Rotors Full handbrake overhaul Wheel Bearings Seals Swivel hubs Steering Boxes Half the suspension joints Shocks Air bags (Ones to go in the rear springs for towing) Water pump Timing kit Lower timing case Harmonic Balancer Radiator Lots of other little seals and shits Gas struts for the bonnet New power window switches And god knows what else I've forgotten... Ha ha ha I have my fingers crossed the pinion seals don't start leaking on the diffs, that the transfer case doesn't leak, and the gearbox input shaft doesn't leak, nor the rear main seal. As they're about the only seals I haven't replaced in the driveline! I'm seriously eyeing off buying new caliper rebuild kits front and rear brake calipers... I'll probably recheck all the valve clearances soon too, and hopefully, it should be all good and sweet to haul some long distance trips again!
    • Every time I pull my 3x gauges out of the console and see the crack-addict way that I did the wiring, and I just can't bring myself to tear it all apart and "make it nice", because it is currently working. In fact, the last time I was in there I probably made it worse.
    • The best part is when you own the car long enough that you look back and find your OWN ham fisted amateur shit!
